path: root/arch/arm/include/asm/arch-omap4/mux_omap4.h
2012-05-15omap4+: Avoid using __attribute__ ((__packed__))Aneesh V
Avoid using __attribute__ ((__packed__)) unless it's absolutely necessary. "packed" will remove alignment requirements for the respective objects and may cause alignment issues unless alignment is also enforced using a pragma. Here, these packed attributes were causing alignment faults in Thumb build. Signed-off-by: Aneesh V <aneesh@ti.com>
2011-08-03omap4: support TPS programmingAneesh V
TPS62361 is the new power supply used in OMAP4460 that supplies vdd_mpu. VCORE1 from Phoenix supplies vdd_core and VCORE2 supplies vdd_iva. VCORE3 is not used in OMAP4460. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Add pad mux support for OMAP4Steve Sakoman
Add functional multiplexing support for OMAP4 pads. Configure all the pads for the OMAP4430 SDP and OMAP4 Panda boards Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
