path: root/arch/arm/include/asm/arch-omap4/clock.h
2013-08-28ARM: OMAP4470: Add voltage and dpll dataTaras Kondratiuk
OMAP4470 reference design uses TWL6032 PMIC with a following connection scheme: VDD_CORE = TWL6032 SMPS2 VDD_MPU = TWL6032 SMPS1 VDD_IVA = TWL6032 SMPS5 Set voltage and frequency values according to OMAP4470 Data Manual Operating Condition Addendum v0.7 Signed-off-by: Taras Kondratiuk <taras@ti.com>
2013-06-10ARM: DRA7xx: clocks: Update PLL valuesLokesh Vutla
Update PLL values. SYS_CLKSEL value for 20MHz is changed to 2. In other platforms SYS_CLKSEL value 2 represents reserved. But in sys_clk array ind 1 is used for 13Mhz. Since other platforms are not using 13Mhz, reusing index 1 for 20MHz. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-06-10ARM: DRA7xx: Correct the SYS_CLK to 20MHZSricharan R
The sys_clk on the dra evm board is 20MHZ. Changing the configuration for the same. And also moving V_SCLK, V_OSCK defines to arch/clock.h for OMAP4+ boards. Signed-off-by: Sricharan R <r.sricharan@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10ARM: OMAP2+: Rename asm/arch/clocks.h asm/arch/clock.hLokesh Vutla
To be consistent with other ARM platforms, renaming asm/arch-omap*/clocks.h to asm/arch-omap*/clock.h Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
