path: root/arch/arm/include/asm/arch-omap3
2012-02-15omap_hsmmc: Wait for CMDI to be clearTom Rini
Before we can send a command we need both the DATI (command inhibit on mmc_dat line) bit and CMDI (command inhibit on mmc_cmd line) are clear. The previous behavior of only checking on DATI was insufficient on some cards and incorrect behavior in any case. This makes the code check for both bits being clear and makes the error print more clear as to what happened. DATI_CMDDIS is removed as it was unused elsewhere in the code and stood for 'DATI is set, cmds are disabled still'. Fix originally spotted by Peter Bigot. Tested-by: Peter A. Bigot <bigotp@acm.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Andreas Müller <schnitzeltony@googlemail.com>
2012-02-12ARMV7: Fix duplicate use of "b" parameter in ACTIM_CTRLA definitionPeter Barada
ACTIM_CTRLA macro errently passes "b" parameter to ACTIM_CTRLA_TRAS() instead of "c". To make usage more clear, replace all single-letter macro parameters with more descriptive parameter names. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-02-12AM3517: Changed default clock rate for AM3517Schuyler Patton
AM3517: Changed default clock rate for AM3517 Changed #define MPU_M_13_ES2 from 0x1F4 to 0x258, this allows the AM3517 to boot up at 600MHz instead of 500 MHz Signed-off-by: Schuyler Patton <spatton@ti.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@gmail.com> CC: Stefano Babic <sbabic@denx.de>
2012-02-12OMAP3+: Clock: Adding ehci clock enablingGovindraj.R
Adding ehci clock enabling mechanism part of clock framework. When essential clocks are enabled during init phase usb host clocks can also be enabled from clock framework. Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12ehci-omap: Clean up added ehci-omap.cGovindraj.R
Clean up added ehci-omap.c and make it generic for re-use across omap-soc having same ehci ip block. Also pass the modes to be configured from board file and configure the ports accordingly. All usb layers are not cache aligned, till then keep cache off for usb ops as ehci will use internally dma for all usb ops. * Add a generic common header ehci-omap.h having common ip block data and reg shifts. * Rename and modify ehci-omap3 to ehci.h retain only conflicting sysc reg shifts remove others and move to common header file. * pass the board data for beagle/panda accordinly to use ehci ports. Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-01-16overo: add SPL supportAndreas Müller
* implementation based on ti beagleboard/omap3evm * timing data and i2c workaround for revision 0 boards taken from x-loader * run-tested with overo revision 0 and 1 / boot from NAND and SDcard * run-tested with x-loader Signed-off-by: Andreas Müller <schnitzeltony@gmx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3: Add SPL support to omap3_evmTom Rini
Add Hynix 200MHz timing information to <asm/arch-omap3/mem.h>. This also changes CONFIG_SYS_TEXT_BASE to 0x80100000. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3: Add SPL support to BeagleboardTom Rini
This introduces 200MHz Micron parts timing information based on x-loader to <asm/arch-omap3/mem.h> and Numonyx MCFG calculation. The memory init logic is also based on what x-loader does in these cases. Note that while previously u-boot would be flashed in with SW ECC in this case it now must be flashed with HW ECC. We also change CONFIG_SYS_TEXT_BASE to 0x80100000. Cc: Dirk Behme <dirk.behme@gmail.com> Beagleboard rev C5, xM rev A: Tested-by: Tom Rini <trini@ti.com> Beagleboard xM rev C: Tested-by: Matt Ranostay <mranostay@gmail.com> Beagleboard rev B7, C2, xM rev B: Tested-by: Matt Porter <mporter@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3 SPL: Add identify_nand_chip functionTom Rini
A number of boards are populated with a PoP chip for both DDR and NAND memory. Other boards may simply use this as an easy way to identify board revs. So we provide a function that can be called early to reset the NAND chip and return the result of NAND_CMD_READID. All of this code is put into spl_id_nand.c and controlled via CONFIG_SPL_OMAP3_ID_NAND. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3 SPL: Rework memory initalization and devkit8000 supportTom Rini
This changes to making the board be responsible for providing the memory initialization timings in SPL and converts the devkit8000 to this framework. In SPL we try and initialize both CS0 and CS1. Cc: Frederik Kriewitz <frederik@kriewitz.eu> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3: Suffix all Micron memory timing parts with their speedTom Rini
2011-12-06OMAP3: Add optimal SDRC autorefresh control valuesTom Rini
This adds the optimal SDRC autorefresh control register values for 100Mhz, 133MHz, 165MHz and 200MHz clocks. We switch to using this to provide the default 165MHz value. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06omap3: mem: Add MCFG helper macroTom Rini
This adds an MCFG macro to calculate the correct value, similar to the ACTIMA/ACTIMB macros and adds a comment that all of the potential values here are documented in the TRM. Then we convert the Micron value to use this macro. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06OMAP3: Remove get_mem_type prototypeTom Rini
This function doesn't exist for omap3 Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06omap3: mem: Comment enable_gpmc_cs_config moreTom Rini
Expand the "enable the config" comment to explain what the bit shifts are and define out two of the magic numbers. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06AM3517: move AM3517 specific mux defines to generic headerIlya Yanok
AM3517 specific CONTROL_PADCONF_* defines moved from board-specific files to <asm/arch-omap3/mux.h> Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-12-06AM35xx: add EMAC supportIlya Yanok
AM35xx has DaVinci-compatible EMAC. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-12-06start.S: remove omap3 specific code from start.SAneesh V
Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Aneesh V <aneesh@ti.com> Acked-by: Tom Rini <trini@ti.com>
2011-11-15omap: Checkpatch fixesSricharan
Fixing them here so that when the files are reused in subsequent patches for omap5, avoids new checkpatch warnings. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-04omap3: mem: Move comments next to definitionsSanjeev Premi
Calculations for ACTIM_CTRLA amd ACTIM_CTRLB values are defined in 'header' style comments. Moved them along with definitions. Should help maintain consistency between comments and code if any of these are tweaked in future. Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-04omap3: mem: Clean-up whitespacesSanjeev Premi
Consistent use of TABs and align definitions with neighbouring code. Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-04omap3: mem: Define and use common macrosSanjeev Premi
Define common macros to arrive at the values of registers SDRC_ACTIM_CTRLA and SDRC_ACTIM_CTRLB for different memory types. This doesn't make any real change in the execution but helps readability. Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap3/emif4: fix registers definitionIlya Yanok
Fix EMIF4 registers definition. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27OMAP3 SPL: Provide weak omap_rev_stringTom Rini
We add an weak version of omap_rev_string in omap-common/spl.c and while at it drop the omap3 version. Move the prototype over to <asm/omap_common.h> with the other SPL functions. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap3: Add interface for omap3 DMASimon Schwarz
Adds an interface to use the OMAP3 DMA. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap3: Add DMA register accessorsSimon Schwarz
Adding the register definitions for omap3 DMA controller to cpu.h Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap3: Add Base register for DMASimon Schwarz
Adding the base register address of OMAP3 DMA controller. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30omap3: new SPL structure supportSimon Schwarz
Support for the new spl structure. Using the interface defined by Aneesh V for OMAP4 Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30omap3: Configure RAM bank 0 if in SPLSimon Schwarz
OMAP3 relied on the memory config done by X-loader or Configuration Header. This has to be reworked for the implementation of a SPL. This patch configures RAM bank 0 if CONFIG_SPL_BUILD is set. Settings for Micron-RAM used by devkit8000 are added to mem.h Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30OMAP3: Overo: Update GPMC timing for ethernet chipPhilip Balister
The existing timing does not quite meet the minimum requirements in the LAN9221 datasheet. The timing in this patch solves problems noticed on some parts. The patch also combines the CS configuration for the overo and igep0020 boards per request. Signed-off-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12ARMV7: OMAP3: Add 37xx ESx revision numbers.Howard D. Gray
OMAP3: Add 37xx ESx revision numbers. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Howard D. Gray <howard.gray@matrix-vision.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3: Add DSS driver for OMAP3Syed Mohammed Khasim
* Supports dynamic panel configuration * Supports dynamic tv standard selection * Adds support for DSS register access through generic APIs * Incorporated DSS register access using structures. * DSS makefile update Previous discussions are here: http://www.mail-archive.com/u-boot@lists.denx.de/msg27150.html Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04omap3:clock: configure GFX clock to 200MHz for AM/DM37xVaibhav Hiremath
AM/DM37x is another OMAP3 variant, where the GFX clock has been boosted to 192MHz/200MHz. So fix the GFX_DIV value for this change. HW Errata: Due to dependency of TV out clock of 54MHz, it is not possible to configure GFX to 192MHz. So as per HW errats, the recommended GFX clock is 200MHz (=CORE_CLK/2). Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04omap: fix gpio related build breaksAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2011-08-03omap: reuse omap3 gpio support in omap4Aneesh V
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-04armv7: adapt omap3 to the new cache maintenance frameworkAneesh V
adapt omap3 to the new layered cache maintenance framework Signed-off-by: Aneesh V <aneesh@ti.com>
2011-04-27ARMV7: OMAP3: Add GPMC_CONFIGx register value definitionsLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27omap3_beagle: enable EHCI and USB storage.Alexander Holler
The reset sequence/configuration for ehci is highly board specific, so this will be done in the source for the board, instead of introducing several CONFIG_* which would be needed to make those few lines in beagle.c usable across different OMAP boards. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: Add support for DPLL5 (usbhost)Alexander Holler
2011-04-27OMAP3: BeagleBoard: Enable pullups on i2c2.Steve Kipisz
This allows the reading of EEPROMS on the expansion bus without adding external pull-ups. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17OMAP3: SDRC: Introduce Numonyx DDR typeEnric Balletbo i Serra
Introduce Numonyx DDR timings and provide CONFIG_OMAP3_NUMONYX_DDR config options to allow for platform files to setup their timings. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17ARMV7: OMAP: Add new mmc driver compatible with CONFIG_GENERIC_MMCSukumar Ghorai
OMAP boards currently use a legacy mmc driver. This patch adds a new mmc driver which will work with the generic mmc driver in u-boot. This new driver will work with both OMAP3 and OMAP4 boards. This patch does not remove the old driver. It should remain in the tree until all boards that use it switch to the new driver. Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Tested-by: Steve Sakoman <steve@sakoman.com>
2010-09-08ARMV7: OMAP3: Fix broken reset command on OMAP36XX/37XX and OMAP4Steve Sakoman
Using the reset command on OMAP36XX/37XX and OMAP4 caused a hang. This patch uses the reset bit appropriate for each CPU architecture. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP3: Add clock setup for OMAP36XX/37XXSteve Sakoman
This patch configures clocks properly when a 36XX/37XX processor is detected. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP3: Update CPU type detection for AM35XX/OMAP36XX/37XXSteve Sakoman
TI has added new processors to the OMAP3 family. This patch enhances the code in sysinfo.c to detect which family member is present. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-12AM35x: Adding SCM general register definitionsAjay Kumar Gupta
Adding general register structure of system control module (SCM) of AM35x. This would be required to access devconf2 and ip_sw_reset register in musb module. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
2010-08-05ARMV7: Restructure omap3 musb driver to allow code sharing between OMAP3 and ↵Steve Sakoman
OMAP4 Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Modify i2c driver for more reliable operation on OMAP4Steve Sakoman
This patch modifies the init routine to follow the TRM recommendations. It also modifies the i2c_read_byte function to reflect subtle differences between the i2c controller in OMAP3 and OMAP4. Signed-off-by: Steve Sakoman <steve@sakoman.com> Acked-by: Nishanth Menon <menon.nishanth@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Restructure OMAP i2c driver to allow code sharing between OMAP3 and OMAP4Steve Sakoman
This patch modifies the omap24xx driver so that it will also work with OMAP4. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Restructure OMAP mmc driver to allow code sharing between OMAP3 and OMAP4Steve Sakoman
The architecture independent header is moved to drivers/mmc, and the architecture dependent headers reside in asm/arch-omap3 and asm/arch-omap4 Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
