path: root/arch/arm/include/asm/arch-omap3/omap3-regs.h
2011-04-27ARMV7: OMAP3: Add GPMC_CONFIGx register value definitionsLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
