path: root/arch/arm/include/asm/arch-mxs/regs-lradc.h
2013-04-22imx: Move some header files from arch-mxs to imx-commonStefan Roese
The following headers are moved to a i.MX common location: - regs-common.h - regs-apbh.h - regs-bch.h - regs-gpmi.h - dma.h This way this header can be re-used also by other i.MX platforms. For example the i.MX6 which will need it for the upcoming NAND support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01mxs: prefix register acessor macros with 'mxs' prefixOtavio Salvador
As the register accessing mode is the same for all i.MXS SoCs we ought to use 'mxs' prefix intead of 'mx28'. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01mxs: reorganize source directory for easy sharing of code in i.MXS SoCsOtavio Salvador
Most code can be shared between i.MX23 and i.MX28 as both are from i.MXS family; this source directory structure makes easy to share code among them. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
