Update the mx6sx SDB and AUTO ARD board codes and DTS to support
DM video splash screen.
Both have two video path:
1. LCDIF1 -> LCD panel
2. LCDIF2 -> LVDS channel 0
Signed-off-by: Ye Li <ye.li@nxp.com>
We introduce a new arch-specific flag GD_FLG_ARCH_IMX_USB_BOOT to indicate if it is
USB boot. We check the USB PHY PWD bit at early of boot stage then set that flag
in global variable. So any following calling of is_boot_from_usb will return
correct value.
(cherry picked from commit 50b30746a9aac8785bfe6ea8077c8572b02065c2)
(cherry picked from commit 24906eac79b62e9993b3706d3fb9ee710103aa1d)
(cherry picked from commit efe5ff987833754641f218c5e0834ef5bddf9cf0)
(cherry picked from commit af424e3251fadb3b9b83ac4856ab8d72d44e3da5)
Porting the FSL android fastboot features from imx u-boot v2018.03 to
support all SoCs: imx6/imx7/imx7ulp/imx8/imx8m.
The UUU commands like UCmd and ACmd are also added. Users need set
CONFIG_FASTBOOT_UUU_SUPPORT=y to enable the feature.
Signed-off-by: Frank Li <Frank.Li@nxp.com>
(cherry picked from commit 65120b06a7f750b9b1a6e0db3d2082cc7088d5a8)
(cherry picked from commit 9b149c2a28829fe7017f83981d634157bc31cc94)
(cherry picked from commit 9f99e9de1d37e9f6c02c1b27348ea3dcdab94569)
(cherry picked from commit 6ae1c043431a4987f563026b179b33945a5880ee)
(cherry picked from commit 806c9ba15e8742a23b1b9147d9b85219133b6f10)
(cherry picked from commit 1357b84595d617f6ebc09f23e7b9d14b080f8048)
Debug monitor will print out last failed AXI access info when
system reboot is caused by AXI access failure, only works when
debug monitor is enabled.
Enable this module on i.MX6SX.
Signed-off-by: Anson Huang <b20788@freescale.com>
Signed-off-by: Ye.Li <B37916@freescale.com>
(cherry picked from commit df6ac8531d498021ed379c74fc1847bd2cec7179)
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
(cherry picked from commit 4f4ecdbf6fe2673b8ad117df1a4974bdb7e6aa4a)
(cherry picked from commit e1c98a672e50fd0405686b74dad50680a75a8a9f)
(cherry picked from commit 5265a3052505fae2a212af292412a62b20a16f97)
(cherry picked from commit 9939631045b77617572a74283dd637d5c476cd53)
(cherry picked from commit f778852e518e2819470e7903ec10af9462b99f40)
(cherry picked from commit f7da7a8bc0ec3fbdcb3020ec8699952c94dd0d8d)
(cherry picked from commit 80ea54242f7716e42dc4ae417fc04bc567e5714a)
Add vadc clock enable function.
Signed-off-by: Sandor Yu <R01008@freescale.com>
(cherry picked from commit 721c7a1448c5b7265b597b83d18f8338a27ea213)
(cherry picked from commit 903a59ef941f39b6d7f693dd7c60528e166de079)
(cherry picked from commit dc767fb7d5c155f2a6ef01c4dee808b9c1944fc2)
(cherry picked from commit 0a48932f375a969e6f7e72d171522146981b2135)
(cherry picked from commit b6f962db57c988c31d35e204f638ba3b0c53eb4a)
(cherry picked from commit b28c20cc8d9032a0521274f6bc21d4da414a8a37)
(cherry picked from commit 909929b5b8a6ae7d7f8d8b12e60e0882634550c8)
(cherry picked from commit 99177cd10c0177c1f92abc553ab514be8f3778f6)
(cherry picked from commit 80c9584b23ee3bb0d28bb44c27bc680d43128477)
Since i.MX6QP is a variant of i.MX6Q, have to add CONFIG_MX6QP
with CONFIG_MX6Q in the soc codes for ddr/pin/clock/plugin
(cherry picked from commit a56c1d98d8d56a34ca1226e15fe05b75cd9b3686)
(cherry picked from commit 1fa581642ec8def3fd378b29f8d9b6527358dfe9)
(cherry picked from commit cad8787ee3a37a644e6c981e6b8c9d9748a212de)
(cherry picked from commit 14b75bbfe513e05cc099b78fe8909822e1167a51)
(cherry picked from commit 87f1a3946ec3a5ca55521c31320a799446faa23b)
Update the pins.h for i.MX6SL/UL/ULL to align with v2017.03
(cherry picked from commit 86c6ba24e56e32ad9942b14fe8565651f9a4c3c6)
(cherry picked from commit c3f9a3036f5e2ddebf2fdd3a1b423bf09dfa1a26)
(cherry picked from commit 3bea36bb5b570847ba065fb2da1d53a62d35a31c)
(cherry picked from commit 8cf8b3e39bd2da3a7a7487b439c9ba54680bbc2c)
(cherry picked from commit bab12a7f7c552ec25ce670701ddc2b85019872c0)
Update the CCM and AIPS registers mapping files to align with v2017.03
(cherry picked from commit 4479d29d344c89fe3f0ba73934e72bc6099b6eaf)
(cherry picked from commit 079cfb35c0a898d0cb3f6441c5dc41e06edb6525)
(cherry picked from commit 170a48574588ddcf475811182dc697938da63454)
(cherry picked from commit 9b25d90c6d7035842c1df10e3a24315eeb205946)
(cherry picked from commit cab5e2c3650d202dc4e7fdf01b35af302693ac9a)
Update codes for i.MX6 soc and clock settings to align with v2020.04
(cherry picked from commit 82ecba47271848a339a53eef7e770526bc3b3967)
(cherry picked from commit fa452a1fa374f5a26ed8c178c8c1fb3e383962e5)
(cherry picked from commit d745866a43c0a69e4132c23a29106bfba6a32c9a)
(cherry picked from commit e25ef41b6b62f55ed718669b831b6cd0d5595e90)
(cherry picked from commit 8141deee6914f9ed88a9dc516707ad2101b3a618)
This patch is to support Bus Encryption Engine(BEE) for i.MX 6UL.
Supported feature:
1. SNVS key and soft key
2. CTR and ECB mode
3. Specify address region to bee.
Two commands are included:
bee init [key] [mode] [start] [end] - BEE block initial
"Example: bee init 1 1 0x80000000 0x80010000\n"
bee test [region]
"Example: bee test 1\n"
Mapping:
[0x10000000 - (0x10000000 + size - 1)] : [start - (start + size - 1)]
[0x30000000 - (0x30000000 + IRAM_SIZE - 1)] : [IRAM_BASE_ADDR -
(IRAM_BASE_ADDR + IRAM_SIZE - 1)]
Whatever start is, start - (start + size -1) will be fixed mapping to
Since default AES region's protected size is SZ_512M, so
on mx6ul evk board, you can not simply run 'bee init', it will
overlap with uboot execution environment, you can use
'bee init 0 0 0x80000000 0x81000000'.
If want to use bee, Need to define CONFIG_CMD_BEE in board configuration
header file, since CONFIG_CMD_BEE default is not enabled.
This patch also checks fuse bit 25 of bank 0 word 4 before initialize bee.
The bit: 0 means bee enabled, 1 means bee disabled.
(cherry picked from commit 9d592121bebbdb9ded0009a2703c7cab01edfa70)
(cherry picked from commit cd03ba8327d46178900a63310d5ef3edd8034350)
(cherry picked from commit 6c8ed4a65e73747f38d2e16e8a2b8cb0c7cce4af)
(cherry picked from commit 772a1ed70504667e8ec081f37b9c0f4b3fa6ac11)
(cherry picked from commit 2e0e0060ea8303f6d9e9573fd9262ce24e8f4ae8)
Port LDO bypass SOC codes from v2017 to support the features:
1. Add check for 1.2GHz core speed. If Speed grading fuse is for 1.2GHz,
enable LDO bypass and setup PMIC voltages. LDO bypass is dependent
on the flatten device tree file.
2. We set WDOG_B in set_anatop_bypass() before, because it is the only case, but now
on i.mx6sabreauto board, we didn't use ldo-bypass mode, but have to use WDOG_B to
reboot whole board, so split these code to independent function so that board file
can call it freely.
(cherry picked from commit 6bceaf009718cec856e11106d26e13601631fa4f)
(cherry picked from commit 0e2de4c2d5d2c79e485d164394f03065743ba2c4)
(cherry picked from commit 4160d7362893873d04b8a2d618ad6ff84c411da4)
(cherry picked from commit 95081f7d5cfeebea682c83d6ebc9ae4eefee2a0f)
(cherry picked from commit f541aa3920e76c543003607a2bec45cc84f8d39b)
Change the MACRO name of mcu TCM base address from M4_BOOTROM_BASE_ADDR
to MCU_BOOTROM_BASE_ADDR.
since this MACRO will be used in common code for i.MX chips, the same
MACRO name in other files are also modified.
Change-Id: I433dd78d11c485d0f4cb82bab299f61cb29dce45
Signed-off-by: faqiang.zhu <faqiang.zhu@nxp.com>
(cherry picked from commit e2eb616fdbc4ce6475b084ab11b77cd5dcaa6fd2)
(cherry picked from commit 809d03482c951989769a82e317abbeab9b8e4d8b)
(cherry picked from commit 34a042bb8caa8ecc907f67c383c9ad57519768ee)
Commit 97c16dc8bf098 ("imx: mx6ull: update the REFTOP_VBGADJ setting")
made this macro unused. Then remove it.
Signed-off-by: Dario Binacchi <dario.binacchi@amarulasolutions.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
If reset-gpio is defined by device-tree use that if
CONFIG_PCIE_IMX_PERST_GPIO is not defined.
Note that after this the following boards which define
CONFIG_PCIE_IMX_PERST_GPIO in their board header file as well as their
device-tree should be able to remove CONFIG_PCIE_IMX_PERST_GPIO without
consequence:
- mx6sabresd
- mx6sxsabresd
- novena
- tbs2910
- vining_2000
Note that the ge_bx50v3 board uses CONFIG_PCIE_IMX_PERST_GPIO and does
not have reset-gpios defined it it's pcie node in the dt thus removing
CONFIG_PCIE_IMX_PERST_GPIO globally can't be done until that board adds
reset-gpios.
Cc: Ian Ray <ian.ray@ge.com> (maintainer:GE BX50V3 BOARD)
Cc: Sebastian Reichel <sebastian.reichel@collabora.com> (maintainer:GE BX50V3 BOARD)
Cc: Fabio Estevam <festevam@gmail.com> (maintainer:MX6SABRESD BOARD)
Cc: Marek Vasut <marex@denx.de> (maintainer:NOVENA BOARD)
Cc: Soeren Moch <smoch@web.de> (maintainer:TBS2910 BOARD)
Cc: Silvio Fricke <open-source@softing.de> (maintainer:VINING_2000 BOARD)
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
sel_input value for the following uart5 pins is
different between i.MX6UL and i.MX6ULL:
MX6_PAD_UART5_TX_DATA__UART5_DTE_RX
MX6_PAD_UART5_RX_DATA__UART5_DCE_RX
MX6_PAD_ENET1_RX_EN__UART5_DCE_RTS
MX6_PAD_ENET1_TX_DATA0__UART5_DTE_RTS
MX6_PAD_CSI_DATA02__UART5_DCE_RTS
As sel_input value for the second one is fixed by
the previous commit, fix the rest.
Signed-off-by: Yuichiro Goto <goto@k-tech.co.jp>
The CSPI/ECSPI register bits do not differ between newer SoCs, instead
of having multiple copies of the same thing for each iMX SoC, define
the bits in the driver.
Cc: Jagan Teki <jagan@amarulasolutions.com>
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
Some places use __ASSEMBLER__ instead which does not work since the
Makefile does not define it. Fix them.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
It is bad practice to include common.h in other header files since it can
bring in any number of superfluous definitions. It implies that some C
files don't include it and thus may be missing CONFIG options that are set
up by that file. The C files should include these themselves.
Update some header files in arch/arm to drop this.
The i.MX6DP and i.MX6QP incorporate NoC interconnect logic
which needs to be configured in order to use external DDR memory.
This patch enables the SPL to configure the necessary registers
in accordance with the NXP engineering bulletin EB828.
Co-developed-by: Filip Brozović <fbrozovic@gmail.com>
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
Signed-off-by: Filip Brozovic <fbrozovic@gmail.com>
Make the PMU LDO configuration interface available to board code,
so that board code can reconfigure the internal LDOs of the SoC.
Cc: Eric Nelson <eric@nelint.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Eric Nelson <eric@nelint.com>
Introduce disable_ipu_clock(). This is done in preparation for
configuring the NoC registers on i.MX6QP in SPL.
Afer the NoC registers are set the IPU clocks can be disabled.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
just try to bring up an imx6ull board with console
on uart5 and found, that input_val for pin
MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX is 7 and
not 5 on imx6ull.
With this patch rx works now.
This macro allows to detect whether the boot ROM initialized USB
already (serial downloader). This is helpful to reliably detect
if the system has been recovered via USB serial downloader.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Since commit commit 152038ea1886 ("i.MX6UL: icore: Add SPL_OF_CONTROL
support") the OPOS6UL board doesn't boot anymore. Adding SPL_DM support
makes the board boot again.
Fixes: commit 152038ea1886 ("i.MX6UL: icore: Add SPL_OF_CONTROL support")
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
HW accelerated "hash sha256 ..." command doesn't work on i.MX6UL, we get
"CAAM was not setup properly or it is faulty" error message.
This is due to wrong CAAM base 0x02100000, on i.MX6UL the CAAM base
address is 0x02140000. Fix it.
Note: with this patch applied the "hash sha256" commant still has some
issues on i.MX6UL ("Invalid KEY Command" or other errors). With data
cache off the "hash sha256" command works as expected.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Move i.MX6/7 bootaux code to imx_bootaux.c.
The i.MX6/7 has different src layout, so define M4 reg offset
to ease the cleanup. Redefine the M4 related BIT for share
common code.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
The i.MX 6UL/ULL feature a Cortex-A7 CPU which suppor the ARM
generic timer. This change makes use of the ARM generic timer in
U-Boot.
This is crucial to make the ARM generic timers usable in Linux since
timer_init() initalizes the system counter module, which is necessary
to use the generic timers CP15 registers.
Since commit 051ba9e082f7 ("Kconfig: mx6ull: Deselect MX6UL from
CONFIG_MX6ULL") CONFIG_MX6ULL does not select CONFIG_MX6UL anymore, so
take this into consideration in all the checks for CONFIG_MX6UL.
This fixes a boot regression.
Reported-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Tested-by: Breno Lima <breno.lima@nxp.com>
Tested-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Tested-by: Jörg Krause <joerg.krause@embedded.rocks>
i.MX6ULL has the same WDOG3 base address as i.MX6UL, so take this
into account in the base address definition.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
This commit provides generic function to set the RGMII/HSIC IO voltage
level on iMX6 devices.
Add support for the latest MX6QP wandboard variant.
Based on Richard Hu's work from Technexion's U-Boot tree.
When compiling with W=1 errors are observed:
drivers/pci/pcie_imx.c:517:12: warning: no previous prototype for ‘imx6_pcie_toggle_power’ [-Wmissing-prototypes] __weak int imx6_pcie_toggle_power(void)
drivers/pci/pcie_imx.c:528:12: warning: no previous prototype for ‘imx6_pcie_toggle_reset’ [-Wmissing-prototypes] __weak int imx6_pcie_toggle_reset(void)
Remove these warnings by adding the functions prototypes on arch-mx6/sys_proto.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
When compiling with W=1 the following warning is observed:
arch/arm/mach-imx/mx6/clock.c:1268:5: warning: no previous prototype for ‘do_mx6_showclocks’ [-Wmissing-prototypes] int do_mx6_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
Remove this warning by adding the function prototype into arch-mx6/clock.h file.
This macro allows to detect whether the USB PHY is active. This
is helpful to detect if the boot ROM has previously started the
The idea is taken from the mfgtool support in the NXP U-Boot:
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/commit/?h=imx_v2016.03_4.1.15_2.0.0_ga&id=a352ed3c5184b95c4c9f7468f5fbb5f43de5e412
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Select SION by appropriate macro instead of constant.
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
OPOS6UL is an i.MX6UL based SoM with 256MB RAM, 4GB eMMC and an ethernet
phy. OPOS6ULDev is carrier board for the OPOS6UL.
U-Boot SPL 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09)
Trying to boot from MMC1
U-Boot 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09 +0100)
CPU: Freescale i.MX6UL rev1.0 528 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 40C
Reset cause: POR
Model: Armadeus Systems OPOS6UL SoM on OPOS6ULDev board
DRAM: 256 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Video: 800x480x18
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Instead of initializing 'struct src' to SRC_BASE_ADDR on
every function better to have global define macro.
Reviewed by: Stefano Babic <sbabic@denx.de>
Signed-off-by: Jagan Teki <jagan@openedev.com>
Moving arch/arm/mach-litesom/ to arch/arm/cpu/armv7/mx6/ was requested
in [1] during discussion of chiliSOM support patches.
[1] http://lists.denx.de/pipermail/u-boot/2017-January/279137.html
Suggested-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
The LCDIF Pixel clock mux is not glitchless, so need
to gate before changing mux.
Also change enable_lcdif_clock prototype with a new input
parameter to indicate disable or enable.
Add lcdif clock support for i.MX6SL.
Update register address for i.MX6 SLL
Add i.MX6SLL pinmux header files
This patch extends the imx6 clock code to enable or disable the EIM
slow clock, which in necessary when one wants to use EIM interface t
o read/write from external memory (e.g. NOR).
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
