path: root/arch/arm/include/asm/arch-mx35/imx-regs.h
2012-02-27mxc_spi: move machine specifics into CPU headersEric Nelson
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU Introduce two new macros to control conditional setup MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x) MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x) Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-03MX35: Drop unnecessary prototypes from imx-regs.hStefano Babic
2011-11-03MX35: added ESDC structure to imx-regsStefano Babic
The structure and PLL defines are added to the imx-regs.h file and dropped from board header files. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-30FEC: Move imx_get_mac_from_fuse() definition to fec_mxc.hMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-02-02SPI: mxc_spi: replace fixed offsets with structuresStefano Babic
This patch cleans driver code replacing all accesses to registers with fixed offsets with a corresponding structure. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02Add support for MX35 processorStefano Babic
The patch adds basic support for the Freescale's i.MX35 (arm1136 based) processor. The patch adds also a prototype for the initialization of the FEC(ethernet controller) to netdev.h to avoid warnings. Signed-off-by: Stefano Babic <sbabic@denx.de>
