The CSPI/ECSPI register bits do not differ between newer SoCs, instead
of having multiple copies of the same thing for each iMX SoC, define
the bits in the driver.
Cc: Jagan Teki <jagan@amarulasolutions.com>
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
It is bad practice to include common.h in other header files since it can
bring in any number of superfluous definitions. It implies that some C
files don't include it and thus may be missing CONFIG options that are set
up by that file. The C files should include these themselves.
Update some header files in arch/arm to drop this.
Also remove the #ifdef's from clock.h since the Kconfig values defaults
the to old default values in clock.h.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Move most macro definitions and prototypes into
"arch/arm/include/asm/imx-common/sys_proto.h" to avoid duplicated
function prototypes and marco definitions for different i.MX SoCs.
This patch do not remove the sys_proto.h for different i.MX SoCs,
because we need to modify lots of driver code and others. This patch
remove duplicated macros and prototypes and incude "sys_proto.h"
of imx-common for each sys_proto.h of different i.MX platforms.
Then later we should avoid add stuff in sys_proto.h of each platform,
and modify driver to include common sys_proto.h.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Use new formula for get_cpu_rev, since we need to use this formula
to do runtime check for all i.MXes.
This patch moves mx31 to the common timer functions added in commit
8dfafdd - Introduce common timer functions <Rob Herring>
The (removed) mx31 timer code (specifically __udelay()) could deadlock at
the 32-bit boundary of get_ticks(). get_ticks() returned a 32-bit value
cast up to a 64-bit value. If get_ticks() + tmo in __udelay() crossed
the 32-bit boundary, the while condition became unconditionally true and
locks the processor. Rather than patch the specific mx31 issues, simply
move everything over to the common code.
Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Helmut Raiger <helmut.raiger@hale.at>
[trini: Fixup common/cmd_io.c]
Add a fsl_iim driver common to i.MX and MPC.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Define the UID (SoC unique ID) fuses, and the fuses available for the user.
IIM:
- Homogenize prg_p naming (the reference manuals are not always self-consistent
for that).
- Add missing SCSx and bank registers.
- Fix the number of banks on i.MX53.
OCOTP:
- Rename iim to ocotp in order to avoid confusion.
- Rename fuse_data to read_fuse_data, and sticky to sw_sticky, according to the
reference manual.
- Merge the existing spinoff gp1 fuse definition on i.MX6.
- Fix the number of banks on i.MX6.
Use a common watchdog driver for all these cpus.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Some MXC SoCs like the i.MX35 have hosts located at unusual offsets, so prepare
to the introduction of i.MX35 support by defining the ehci-mxc hosts offsets at
SoC level.
The EHCI definitions in i.MX31's imx-regs.h are MXC-generic, so move them to
ehci-fsl.h so that all MXC SoCs can use them.
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0
register is actually composed of two bit-fields: one pre-divider and one
post-divider. This patch fixes the CCM access macros and the code using them
accordingly.
i2c didn't work on imx25 due to missing MXC_IPG_PERCLK. Now using
MXC_I2C_CLK on all imx systems using i2c.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
Define default SoC input clock frequencies for i.MX31 in order to get rid of
duplicated definitions.
Define ARCH_MXC for i.MX devices. This is useful to identify features or
behaviors common to all i.MX SoCs.
The i.MX28 is omitted because its architecture is a bit different (like imx/mxc
vs. mxs in Linux).
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
Each i.MX has its own gpio.h, defining the same structure.
The internal GPIO controller has the same layout
(at least for the register used by u-boot) and can be shared.
Tested-by: Matt Sealey <matt@genesi-usa.com>
The following platforms had their config files changed
flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd
and mx53loco.
The video setup for the Epson display is provided. Addtionally
some extra info is displayed next to the Linux logo.
Make get_cpu_rev() publicly available (added to sys_proto.h).
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU
Introduce two new macros to control conditional setup
MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x)
MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x)
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Jason Liu <jason.hui@linaro.org>
This patch modifies mxcmmc.c to be used
not only by i.MX27 but also by i.MX31 boards.
Both use the same SD controller, but have different
clock set-ups.
The i.MX27 imx_get_XXXclock functions are made static to
generic.c and a public mxc_get_clock() function
is provided. Pins, base address and prototypes for
an i.MX31 specific board_init_mmc() are provided.
Some of the i.MX27 clock getters are unused and marked
as such to avoid warnings (./MAKEALL -s mx27), but
the code was left in for future use.
The serial driver for iMX SOCs is continuosly changed if a
new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port>
defines were used only to find the base address for the selected UART.
Instead of that, move the base address to the board configuration
file and drop all #ifdef from driver.
CC: Wolfgang Denk <wd@denx.de>
CC: Fabio Estevam <fabio.estevam@freescale.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
CC: John Rigby <jcrigby@gmail.com>
CC: Matthias Weisser <weisserm@arcor.de>
CC: Jason Liu <jason.hui@linaro.org>
Use proper IO accessor for GPR register.
This allows to initialize DDR memory in C code.
Currently all mx31 boards use assembler code (lowlevel_init.S)
Introduce mx31_set_gpr function for setting the GPR (General Purpose Register) on MX31.
This function can be useful for setting a group of pins into tied to some specific peripherals.
Reuse this function from the linux kernel.
setup_weimcs() and some macros are added to support the setup
for i.MX31 WEIM chip selects. As a compromise between verbosity
and readability an ASCII-art'ish bit comment is used instead of
bitfields.
All i.MX31 boards have been patched to use this approach using a
helper program to verify the changes.
This additionally updates mx31/generic.c by
- replacing __REG() macro accesses with readl() and writel()
- providing macros for PDR0 and PLL bit accesses
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Turn on the watchdog WDZST bit so that watchdog timer does not count during low power modes.
Prior to applying this patch mx31pdk board got watchdog resets because when it booted in the Linux prompt
and there was no activity, the system entered into idle mode while watchdog timer was still active.
Fix this by disabling watchdog timer during idle mode.
Add missing case to be used in common MXC code.
The patch provide the same API used with other i.MX
processors and get rid of mx31_ functions.
Adding support for USB host on imx25 using the internal PHY. Changing the name
of base address define for imx31 to get some unification.
Drop warnings in get_cpu_rev and changes the return value
(a u32 instead of char * is returned) of the function
to be coherent with other processors.
CC: Detlev Zundel <dzu@denx.de>
Drop warning caused by missing prototype for
mxc_hw_watchdog_reset().
Drop warnings due to recent commit
ARM: mx31: Print the silicon version
Commit 5d2c154 (IMX: MX31: Cleanup include files and drop nasty #ifdef in drivers)
renamed mx31-imx-regs.h to imx-regs.h.
Change the file label accordingly.
Use the same method of the Linux kernel to print the MX31 silicon version on
boot.
Tested on a MX31PDK with a 2.0 silicon, where it shows:
CPU: Freescale i.MX31 rev 2.0 at 531 MHz
As exception among the i.MX processors, the i.MX31 has headers
without general names (mx31-regs.h, mx31.h instead of imx-regs.h and
clock.h). This requires several nasty #ifdef in the drivers to
include the correct header. The patch cleans up the driver and
renames the header files as for the other i.MX processors.
The patch add CONFIG_HW_WATCHDOG to be used
with the internal watchdog timer of the MX31
processor. Two function are exported for the
board maintainers:
mxc_hw_watchdog_enable
The board maintainer can decide to use mxc_hw_watchdog_reset as
hw_watchdog_reset, or to implement his own function to reset
the watchdog.
The watchdog timer can be configured with CONFIG_SYS_WD_TIMER_SECS
(value in seconds). The MX31 allows values between 0.5
(CONFIG_SYS_WD_TIMER_SECS = 0) and 128 seconds.
This patch cleans driver code replacing all accesses
to registers with fixed offsets with a corresponding
structure.
Removed warnings generated in the mx31_set_pad() function.
