path: root/arch/arm/include/asm/arch-lpc32xx
2015-04-10lpc32xx: add support for board work_92105Albert ARIBAUD \(3ADEV\)
Work_92105 from Work Microwave is an LPC3250- based board with the following features: - 64MB or 128MB SDR DRAM - 1 GB SLC NAND, managed through MLC controller. - Ethernet - Ethernet + PHY SMSC8710 - I2C: - EEPROM (24M01-compatible) - RTC (DS1374-compatible) - Temperature sensor (DS620) - DACs (2 x MAX518) - SPI (through SSP interface) - Port expander MAX6957 - LCD display (HD44780-compatible), controlled through the port expander and DACs This board has SPL support, and uses the LPC32XX boot image format. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-10lpc32xx: add LPC32xx SSP support (SPI mode)Albert ARIBAUD \(3ADEV\)
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-10lpc32xx: add GPIO supportAlbert ARIBAUD \(3ADEV\)
This driver only supports Driver Model, not legacy model. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-10lpc32xx: i2c: add LPC32xx I2C interface supportAlbert ARIBAUD \(3ADEV\)
2015-04-10lpc32xx: mtd: nand: add MLC NAND controllerAlbert ARIBAUD \(3ADEV\)
The controller's Reed-Solomon ECC hardware is used except of course for raw reads and writes. It covers in- and out-of-band data together. The SPL framework is supported. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-10lpc32xx: add Ethernet supportAlbert ARIBAUD \(3ADEV\)
2015-02-16ARM: lpc3250: config: add generic board supportVladimir Zapolskiy
The only LPC3250 board works fine with enabled generic board support, add CONFIG_SYS_GENERIC_BOARD right into the arch config header. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2014-11-20ARM: remove CONFIG_ARM926EJS definesMasahiro Yamada
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM926EJS and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-05-15serial: add LPC32X0 high-speed UART devices supportVladimir Zapolskiy
This change adds an implementation of high-speed UART found on NXP LPC32X0 SoCs. Such UARTs are enumerated as UART1, UART2 and UART7. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-05-15arm926ejs: add NXP LPC32x0 cpu series supportVladimir Zapolskiy
This change adds initial support for NXP LPC32x0 SoC series. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
