path: root/arch/arm/include/asm/arch-ixp
2011-06-23IXP42x PCI rewriteMichael Schwingen
clean up IXP PCI handling: get rid of IXP-private bus scan, BAR assign etc. code and use u-boot's PCI infrastructure instead. Move board-specific PCI setup code (clock/reset) to board directory. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-06-23Fix IXP code to work after relocation was addedMichael Schwingen
- jump to real flash location after reset before turning off flash mirror - fix timer system to use HZ == 1000, remove broken interrupt-based code Signed-off-by: Michael Schwingen <michael@schwingen.org>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
