We setup SMMU in arch_preboot_os to avoid breaking u-boot driver.
Add a kconfig entry CONFIG_IMX_SMMU to enable it.
So far, the USDHC0-USDHC1 and FEC0-FEC1 are added into sid.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from downstream commit 7da6345919ee59a26cf65b4bc29072eea2fc0909)
(cherry picked from downstream commit 45308e7da90f342c2de7fbec1f8c5b8bd3f1b8e5)
Add sc_rm_set_master_sid to support setting stream IDs.
Add sc_misc_get_temp to support get temperature
Without this definition, fsl_esdhc will access reserved registers
on i.MX chips, so define ARCH_MXC to fix it.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Remove duplicate function declarations from the SCFW API header file.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Add i.MX8QM entry
Add the power domain DM driver for i.MX8, that it depends on the DTB
power domain trees to generate the power domain provider devices. Users
need to add power domain trees with property "compatible = "nxp,imx8-pd";"
When power on a PD device, the driver will power on its ancestor PD
devices in power domain tree.
When power off a PD device, the driver will check its child PD devices
first. Only if all child PD devices are off, then power off the current PD
device. Then the driver checks sibling PD devices. If sibling PD devices
are off, then it will power off parent PD device.
There is no counter maintained in this driver, but a state to hold current
on/off state. So the request and free functions are empty.
The power domain implementation in i.MX8 DTB set the "#power-domain-cells"
to 0, so there is no ID binding with each PD device. We don't use "id"
variable in struct power_domain. At the same time, we have to set of_xlate
to empty to bypass standard of_xlate in uclass driver.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Add i.MX8 support, there are 8 GPIO banks.
This driver is mostly used to avoid build errors.
We use uclass clk driver for clk related operations.
Add iomux configuration api.
Add arch_cpu_init(_dm) mainly to open the channel between ACore and SCU.
Add get_boot_device to detect boot device.
Add print_bootinfo to print the boot device info.
Include i.MX8QXP pin header when CONFIG_IMX8QXP defined,
if no SoC macro defined, report error.
Add imx-regs header file to include the register base definition
Add clk/misc/pad/pm/rm scfw api implementaion for different
drivers to invoke. The low level code is using misc_call
to invoke imx8_scu driver.
Add SCFW macro definition.
