path: root/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h
2017-04-17armv8: ls2080a: Drop macro CONFIG_LS2080AYork Sun
Use CONFIG_ARCH_LS2080A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-28arm: fsl-layerscape: Move QSGMII wriop_init to SoC filePrabhakar Kushwaha
MAC number used per QSGMII is not fixed. It may wary from SoC to SoC. So move QSGMII wriop_init_dpmac() to SoC file. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8/fsl_lsch2: Add chip power supply voltage setupHou Zhiqiang
Set up chip power supply voltage according to voltage ID. The fuse status register provides the values from on-chip voltage ID fuses programmed at the factory. These values define the voltage requirements for the chip. Main operations: 1. Set up the core voltage 2. Set up the SERDES voltage and reset SERDES lanes 3. Enable/disable DDR controller support 0.9V if needed Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14fsl: serdes: ensure accessing the initialized maps of serdes protocolHou Zhiqiang
Up to now, the function is_serdes_configed() doesn't check if the map of serdes protocol is initialized before accessing it. The function is_serdes_configed() will get wrong result when it was called before the serdes protocol maps initialized. As the first element of the map isn't used for any device, so use it as the flag to indicate if the map has been initialized. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26armv8: fsl_lsch2: Add LS1046A SoC supportMingkai Hu
The LS1046A processor is built on the QorIQ LS series architecture combining four ARM A72 processor cores with DPAA 1.0 support. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Mihai Bantea <mihai.bantea@freescale.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26armv8: fsl_lsch2: Add SerDes 2 supportQianyu Gong
New SoC LS1046A belongs to Freescale Chassis Generation 2 and has two SerDes so we need to add this support in fsl_lsch2. The SoC related SerDes 2 support will be added in SoC patch. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03armv8: fsl-layerscape: Add support of QorIQ LS1012A SoCPrabhakar Kushwaha
The QorIQ LS1012A processor, optimized for battery-backed or USB-powered, integrates a single ARM Cortex-A53 core with a hardware packet forwarding engine and high-speed interfaces to deliver line-rate networking performance. This patch add support of LS1012A SoC along with - Update platform & DDR clock read logic as per SVR - Define MMDC controller register set. - Update LUT base address for PCIe - Avoid L3 platform cache compilation - Update USB address, errata - SerDes table - Added CSU IDs for SDHC2, SAI-1 to SAI-4 Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Makarand Pawagi <makarand.pawagi@mindspeed.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03armv8: fsl-layerscape: Avoid LS1043A specifc definesPrabhakar Kushwaha
Other than LS1043A, LS1012A also Chassis Gen2 Architecture compliant. So Avoid LS1043A specific defines in arch/arm Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-04-06armv8: LS2080A: Consolidate LS2080A and LS2085AYork Sun
LS2080A is the primary SoC, and LS2085A is a personality with AIOP and DPAA DDR. The RDB and QDS boards support both personality. By detecting the SVR at runtime, a single image per board can support both SoCs. It gives users flexibility to swtich SoC without the need to reprogram the board. Signed-off-by: York Sun <york.sun@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/fsl_lsch2: Add fsl_lsch2 SoCMingkai Hu
Freescale LayerScape with Chassis Generation 2 is a set of SoCs with ARMv8 cores and 2rd generation of Chassis. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/fsl_lsch3: Change arch to fsl-layerscapeMingkai Hu
There are two LS series processors are built on ARMv8 Layersacpe architecture currently, LS2085A and LS1043A. They are based on ARMv8 core although use different chassis, so create fsl-layerscape to refactor the common code for the LS series processors which also paves the way for adding LS1043A platform. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
