[trini: Fixup common/cmd_io.c]
Move pinmux configurations for the DA830 SoCs from board file
to the arch tree so that it can be used for all da830 based devices.
Also, avoids duplicate pinmuxing in case of NAND.
Signed-off-by: Vishwanathrao Badarkhe, Manish <manishv.b@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
Tested-by: Sughosh Ganu <urwithsughosh@gmail.com>
This patch adds support for MMC/SD on DA850/OMAP-L138.
Tested-by: Christian Riesch <christian.riesch@omicron.at>
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
Acked-by: Tom Rini <trini@ti.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Christian Riesch <christian.riesch@omicron.at>
Up to now nearly every davinci board has separate code for the
definition of pinmux configurations. This patch adds pinmux
configurations for the DA850 SoCs to the arch tree which may later
be used for all DA850 based boards.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Mike Frysinger <vapier@gentoo.org>
Acked-by: Heiko Schocher <hs@denx.de>
