path: root/arch/arm/include/asm/arch-am33xx
2016-10-08ARM: AM437X: Add Silicon ID supportLokesh Vutla
Add silicon ID code for AM437x silicon. This can be used to print the cpu info using CONFIG_DISPLAY_CPUINFO. Also printing "CPU :" along with cpu name in order to be consistent with other OMAP platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-06ARM: Add register defines for am33xx ePWM registerstomas.melin@vaisala.com
Register definitions needed for configuring the ePWM module. Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-22armv7: make gpmc_cfg constLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> [trini: Adapt am33xx, duovero, omap_zoom1] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-09arm, am335x: Enable Spread Spectrum for the MPUHeiko Schocher
Enable Spread Spectrum for the MPU by calculating the required values and setting the registers accordingly. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-09am335x: add some missing CM_CLKMODE_DPLL_SSC macrosHeiko Schocher
add missing CM_CLKMODE_DPLL_SSC_ACK_MASK, CM_CLKMODE_DPLL_SSC_DOWNSPREAD_MASK and CM_CLKMODE_DPLL_SSC_TYPE_MASK defines. Used for enabling spread spectrum. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-09arm, am335x: add some missing GPIO register definitionsHeiko Schocher
add missing: OMAP_GPIO_IRQSTATUS_SET_0 and OMAP_GPIO_IRQSTATUS_SET_1 registers. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27ARM: AM33xx: Add support for Clock SynthesizerLokesh Vutla
The CDCE913 and CDCEL913 devices are modular PLL-based, low cost, high performance , programmable clock synthesizers. They generate upto 3 output clocks from a single input frequency. Each output can be programmed for any clock-frequency. Adding support for the same. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-05-27board: AM335x-ICEv2: Add DDR dataLokesh Vutla
AM335x ICEv2 contains a 2Gbit(128Mx16) of DDR3 SDRAM(MT41J128M16JT-125), capable of running at 400MHz. Adding this specific DDR configuration details running at 400MHz. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-04-18ARM: AM43xx: Fix BOOT_DEVICE_USB IDLokesh Vutla
commit 62c5674ea136a ("omap: SPL boot devices cleanup and completion") cleans up the boot device ids for amx3xx soc. But mistakenly updates wrong device IDs for AM43xx USB. Fixing the same here. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-11am33xx changed BOOT_DEVICE_SPI to correct valueVogt, Christof
Changed BOOT_DEVICE Code for SPI on AM33xx. According AM335x reference manual page 4960 (SPRUH73L-October 2011-Revised February 2015) Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-11-17ARM: am43xx: Enable QUAD read and EDMA support for ti_qspiVignesh R
Enable TI_EDMA3 and QUAD read support for ti_qspi on am43xx, this increases read performance to 4 MB/s. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-09-11bitops: introduce BIT() definitionHeiko Schocher
introduce BIT() definition, used in at91_udc gadget driver. Signed-off-by: Heiko Schocher <hs@denx.de> [remove all other occurrences of BIT(x) definition] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-28ARM: AM43xx: Add functions to enable and disable USB clocksKishon Vijay Abraham I
Added functions to enable and disable USB clocks which can be invoked during USB init and USB exit respectively. Cc: Roger Quadros <rogerq@ti.com> Cc: Tero Kristo <t-kristo@ti.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-17ARM: AM43xx: Add support for disabling clocks in ubootKishon Vijay Abraham I
Add do_disable_clocks() to disable clock domains and module clocks. These clocks are enabled using do_enable_clocks(). Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-12gpio: am43xx: expand gpio supportNikita Kiryanov
AM43XX SoCs support up to 192 GPIO signals. Make this amount available to the driver. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-07-27omap: SPL boot devices cleanup and completionPaul Kocialkowski
This cleans up the SPL boot devices for omap platforms and introduces support for missing boot devices. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-27omap-common: Common boot code OMAP3 support and cleanupPaul Kocialkowski
This introduces OMAP3 support for the common omap boot code, as well as a major cleanup of the common omap boot code. First, the omap_boot_parameters structure becomes platform-specific, since its definition differs a bit across omap platforms. The offsets are removed as well since it is U-Boot's coding style to use structures for mapping such kind of data (in the sense that it is similar to registers). It is correct to assume that romcode structure encoding is the same as U-Boot, given the description of these structures in the TRMs. The original address provided by the bootrom is passed to the U-Boot binary instead of a duplicate of the structure stored in global data. This allows to have only the relevant (boot device and mode) information stored in global data. It is also expected that the address where the bootrom stores that information is not overridden by the U-Boot SPL or U-Boot. The save_omap_boot_params is expected to handle all special cases where the data provided by the bootrom cannot be used as-is, so that spl_boot_device and spl_boot_mode only return the data from global data. All of this is only relevant when the U-Boot SPL is used. In cases it is not, save_boot_params should fallback to its weak (or board-specific) definition. save_omap_boot_params should not be called in that context either. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-04-23arm: am437x: mux: Update mux namesBryan De Faria
Correct and complete the mux names following AM437x Technical Reference Manual. Signed-off-by: Bryan De Faria <bdefaria-ext@adeneo-embedded.com>
2015-04-14board: ti: AM43xx: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in am43xx board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14ARM: AM43xx: Enable clocks for USB OTGSS and USB PHYKishon Vijay Abraham I
Enabled clocks for dwc3 controller and USB PHY present in AM43xx. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-16clock_am43xx:Set the MAC clock to /5 for OPP100Steve Kipisz
When EMAC is in the boot order, the boot ROM sets OPP50 and the MAC clock is set to /2. SPL needs to change it to /5 for Ethernet to generate the correct txclk. This patch sets it correctly. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
2015-01-13arm: am437x: Enable hardware leveling for EMIFJames Doublesin
Switch to using hardware leveling for certain parameters on the EMIF rather than using precalculated values. Doing this also means we have a common place now between am437x and am335x for setting emif_sdram_ref_ctrl with a value for the correct delay length. Tested-by: Felipe Balbi <balbi@ti.com> Tested-by: Tom Rini <trini@ti.com> Signed-off-by: James Doublesin <doublesin@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-12-04arm: am33xx: Handle NAND+I2C boot-device the same way as NANDStefan Roese
Re-map NAND&I2C boot-device to the "normal" NAND boot-device. Otherwise the SPL boot IF can't handle this device correctly. Somehow booting with Hynix 4GBit NAND H27U4G8 on Siemens Draco leads to this boot-device passed to SPL from the BootROM. With this change, Draco boots just fine into main U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Samuel Egli <samuel.egli@siemens.com>
2014-11-06am335x: make get_board_rev() function weakIgor Grinberg
Current get_board_rev() function returns a hard coded value which is obviously incorrect for the majority of boards. Allow boards to provide a correct implementation by making this function weak. In addition open code the trivial and useless BOARD_REV_ID define and adjust the comment. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-07-28Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-25ARM: omap: clean redundant PISMO_xx macros used in OMAP3pekon gupta
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform +-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+ Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-07-25am335x_evm / gumstix pepper: Correct DDR settingsTom Rini
As noted by clang, we have been shifting certain values out of 32bit range when setting some DDR registers. Upon further inspection these had been touching reserved fields (and having no impact). These came in from historical bring-up code and can be discarded. Similarly, we had been declaring some fields as 0 when they will be initialized that way. Tested on Beaglebone White. Reported-by: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Ash Charles <ash@gumstix.com> Signed-off-by: Tom Rini <trini@ti.com> Tested-By: Ash Charles <ashcharles@gmail.com>
2014-07-09usb: phy: omap_usb_phy: implement usb_phy_power() for AM437xFelipe Balbi
Newer AM437x silicon requires us to explicitly power up the USB2 PHY. By implementing usb_phy_power() we can achieve that. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-07-07am43xx: Tune the system to avoid DSS underflowsCooper Jr., Franklin
* This is done by limiting the ARM's bandwidth and setting DSS priority in the EMIF controller to ensure underflows do not occur.
2014-07-07am43xx: Update EMIF DDR3 Configuration for AM43x GPFranklin S. Cooper Jr
* Boot failures have been discovered due to a combination of routing issues and non optimal ddr3 timings in the EMIF * Since ddr3 timings are different after significant board layout changes different timings are required for alpha, beta and production boards. Signed-off-by: Franklin S. Cooper Jr <fcooper@ti.com>
2014-06-06arm:am33xx: Add a scale_vcores() hookTom Rini
Similar to OMAP4/5 we need to scale the voltage up prior to changing the clock frequencies up higher. Add a similar hook to start with. Signed-off-by: Tom Rini <trini@ti.com>
2014-06-06arch-am33xx: Add defines for timer0-7Hannes Petermaier
For usage of timer6 within B&R we need this defines to enable clock modules and clk-source. Also the 'Timer register bits' are expanded. By the way we add defines for all timers within AM335x SoC. Cc: trini@ti.com Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-05-23armv7:TI: Add <asm/ti-common/sys_proto.h> and migrate omap_hw_init_contextTom Rini
The omap_hw_init_context function (and assorted helpers) is the same for all OMAP-derived parts as when CHSETTINGS are used, that's the same and our DDR base is also always the same. In order to make this common we simply need to update the names of the define for DDR address space which is also common. Cc: Sricharan R. <r.sricharan@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-05-13am33xx: add SSC enable macroYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2014-03-28spl: Fix guardian macros in spl.hMarek Vasut
Fix the macros guarding the spl.h header for various platforms. Due to a typo and a propagation of it, the macros went out-of-sync with their ifdef check, so fix this. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-03-04mtd: nand: omap: move omap_gpmc.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: merge duplicate GPMC data from different arch-xx headers ↵pekon gupta
into common omap_gpmc.h Each SoC platform (AM33xx, OMAP3, OMAP4, OMAP5) has its own copy of GPMC related defines and declarations scattered in SoC platform specific header files like include/asm/arch-xx/cpu.h However, GPMC hardware remains same across all platforms thus this patch merges GPMC data scattered across different arch-xx specific header files into single header file include/asm/arch/omap_gpmc.h Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: remove redundant platform specific header: arch-xx/omap_gpmc.hpekon gupta
Currently there are two sets of omap_gpmc.h header files (a) arch/arm/include/asm/omap_gpmc.h common header file for all platforms, containing defines and declarations used by GPMC NAND driver. (b) arch/arm/include/asm/arch-xx/omap_gpmc.h SoC platform specific header file containing defines like ECC layout. This patch removes platform specific arch-xx/omap_gpmc.c because: - GPMC hardware engine is common for all SoC platforms hence only (a) is enough - ECC layout is now defined in omap_nand.c driver itself based on ecc-scheme selected. Hence all ECC layout declarations in (b) are redundant. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21ARM: AM43xx: GP-EVM: Correct GPIO used for VTT regulator controlDave Gerlach
Schematic indicates GPIO5_7 is to be used for VTT regulator control rather than GPIO0_21 so modify enable_vtt_regulator to reflect this. Without this some boards will experience DDR3 corruption and fail to boot. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> [trini: Rework patch against mainline] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21Add support for B&R KWB MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH KWB Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at> Cc: trini@ti.com
2014-02-21am335x: Initial support for Silica Pengwyn boardLothar Felten
This patch add support for the Silica Pengwyn board [1] The board is based on a TI AM3354 CPU [2] All jumpers removed it will boot from the SDcard, the console is on UART1 accessible via the FDTI -> USB. The on board NAND flash is supported and can act as boot medium, depending on jumper settings. USB Host, USB Device and Ethernet are also provided but untested. [1] http://www.silica.com/product/silica-pengwyn-board.html [2] http://www.ti.com/product/am3354 Signed-off-by: Lothar Felten <lothar.felten@gmail.com> [trini: Move CONFIG_BOARD_LATE_INIT into am335x_evm.h, drop unused spi0_pin_mux from Pengwyn support] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-18am43xx: Add qspi supportSourav Poddar
Add QSPI definitions and clock configuration support. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-29Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-24spl: common: Support for USB MSD FAT image loadingDan Murphy
Add SPL support to be able to detect a USB Mass Storage device connected to a USB host. Once a USB Mass storage device is detected the SPL will load the u-boot.img from a FAT partition to target address. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2014-01-24ARM: AM335x: Enable DDR dynamic IO power downSatyanarayana, Sandhya
This patch enables dynamically powering down the IO receiver when not performing a read on boards using DDR3. This optimizes both active and standby power consumption. This bit is not set on EVM SK and EVM 1.5 and later boards. Setting the same. This has been tested on PG2.0 EVM1.5, EVM1.2, EVM-SK, BBB. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com>
