path: root/arch/arm/imx-common
2015-08-02imx-common: timer: add i.MX6UL supportPeng Fan
Add i.MX6UL GPT timer support. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul: Add i.MX6UL CPU typePeng Fan
Add MXC_CPU_MX6UL for i.MX6UL CPU type which is got at runtime from DIGPROG register. But the value has been occupied by MXC_CPU_MX6D which is not real id from DIGPROG register, so change i.MX6D to value 0x67 which was not occupied. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-08-02imx: add cpu type for i.MX6QP/DPPeng Fan
Add cpu type for i.MX6QP/DP. This patch also fix is_mx6dqp(), since get_cpu_rev can return MXC_CPU_MX6QP and MXC_CPU_MX6DP, we should use: (is_cpu_type(MXC_CPU_MX6QP) || is_cpu_type(MXC_CPU_MX6DP)). Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-06-27imx: mx6 correct is_soc_rev usagePeng Fan
is_soc_rev should return a bool value, so use "==", but not "-", change (is_soc_rev(CHIP_REV_1_0) > 0) to (soc_rev() > CHIP_REV_1_0). This patch also add space between "&" for cpu_type(rev) macro. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-06-08imx: drop warning: unused variable 'max_freq'Stefano Babic
max_freq in print_cpuinfo is used only with imx6. Signed-off-by: Stefano Babic <sbabic@denx.de>
2015-06-08dm: gpio: vf610: Add GPIO driver supportBhuvanchandra DV
Add GPIO driver support to Freescale VF610 Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-05-28Revert "imx: drop warning: unused variable 'max_freq'"Stefano Babic
This reverts commit a0117a5e416629932becf079589f5e1859eab90a. Signed-off-by: Stefano Babic <sbabic@denx.de>
2015-05-27imx: drop warning: unused variable 'max_freq'Stefano Babic
2015-05-26arm, imx6, i2c: add I2C4 for MX6DLHeiko Schocher
add I2C4 modul for MX6DL based boards. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-19imx: mx6: add display of CPU temperature grade in print_cpuinfo()Tim Harvey
When CONFIG_IMX6_THERMAL is defined print the CPU temperature grade info along with the current temperature. Before: CPU: Temperature 42 C After: CPU: Automotive temperature grade (-40C to 125C) at 42C CPU: Industrial temperature grade (-40C to 105C) at 42C CPU: Extended Commercial temperature grade (-20C to 105C) at 42C Cc: Stefan Roese <sr@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Heiko Schocher <hs@denx.de> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jon Nettleton <jon.nettleton@gmail.com> Cc: Jason Liu <r64343@freescale.com> Cc: Ye Li <b37916@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Peng Fan <b51431@freescale.com> Tested-by: Nikolay Dimitrov <picmaster@mail.bg> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: mx6: display max cpu frequency in print_cpuinfo()Tim Harvey
Display the max CPU frequency as well as the current running CPU frequency if the max CPU frequency is available and differs from the current CPU frequency. Before: CPU: Freescale i.MX6Q rev1.2 at 792 MHz After - using an 800MHz IMX6DL (running at its max) CPU: Freescale i.MX6DL rev1.1 at 792 MHz After - using a 1GHz IMX6Q (not running at its max): CPU: Freescale i.MX6Q rev1.2 996 MHz (running at 792 MHz) Cc: Stefan Roese <sr@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Heiko Schocher <hs@denx.de> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jon Nettleton <jon.nettleton@gmail.com> Cc: Jason Liu <r64343@freescale.com> Cc: Ye Li <b37916@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Peng Fan <b51431@freescale.com> Tested-by: Nikolay Dimitrov <picmaster@mail.bg> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19arm/imx-common: Fix warning 'get_reset_cause' defined but not usedPrabhakar Kushwaha
Fix below warning arch/arm/imx-common/cpu.c:29:14: warning: ‘get_reset_cause’ defined but not used static char *get_reset_cause(void) Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-05-15imx: dek_blob: Add explicit include for mapmemUlises Cardenas
Boards such as imx6q_sabresd might not have mapmem.h as part of their common library. This causes a build error if the DEK blob command is enabled. Fix: make explicit the include of mapmem.h Signed-off-by: Ulises Cardenas <Ulises.Cardenas@freescale.com> Reviewed-by: Ruchika Gupta <Ruchika.gupta@freescale.com>
2015-05-14i2c: mxc: refactor i2c driver and support dmPeng Fan
1. Introduce a new structure `struct mxc_i2c_bus`, this structure will used for non-DM and DM. 2. Remove `struct mxc_i2c_regs` structure, but use register offset to access registers based on `base` entry of `struct mxc_i2c_bus`. 3. Remove most `#ifdef I2C_QUIRK_REG`. Using driver_data to contain platform flags. A new flag is introduced, I2C_QUIRK_FLAG. 4. Most functions use `struct mxc_i2c_bus` as one of the parameters. Make most functions common to DM and non-DM, try to avoid duplicated code. 5. Support DM, but pinctrl is not included. Pinmux setting is still set by setup_i2c, but we do not need bus_i2c_init for DM. 6. struct i2c_parms and struct sram_data are removed. 7. Remove bus_i2c_read bus_i2c_write prototype in header file. The frist paramter of bus_i2c_init is modified to i2c index. Add new prototype i2c_idle_bus and force_bus_idle. Since bus_i2c_init is not good for DM I2C and pinctrl is missed, we use a weak function for i2c_idle_bus. Board file take the responsibility to implement this function, like this: " int i2c_idle_bus(struct mxc_i2c_bus *i2c_bus) { if (i2c_bus->index == 0) force_bus_idle(i2c_pads_info0); else if (i2c_bus->index == 1) force_bus_idle(i2c_pads_info1); else xxxxxx } " 8. Introduce a weak function, enable_i2c_clk 9. Tested on an i.MX7 platform. Log info: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver simple_bus [ ] |-- soc simple_bus [ ] | |-- aips-bus@30000000 simple_bus [ ] | | |-- anatop@30360000 simple_bus [ ] | | `-- snvs@30370000 simple_bus [ ] | |-- aips-bus@30400000 simple_bus [ ] | `-- aips-bus@30800000 i2c [ ] | |-- i2c@30a20000 i2c [ ] | `-- i2c@30a40000 simple_bus [ ] `-- regulators => i2c dev 0 Setting bus to 0 => i2c probe Valid chip addresses: 08 50 => i2c md 8 31 0031: 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-23ARM: vf610: Move DDR3 initialization to imx-commonSanchayan Maity
In order to avoid code duplication, move the DDR3 initialization to the common place under imx-common. Currently ROW_DIFF and COL_DIFF can be chosen from the board file. The JEDEC timings are specified using a common ddr3_jedec_timings structure. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-03-23ARM: iMX: define an IMX_CONFIG Kconfig optionBoris BREZILLON
IMX_CONFIG is currently passed via the SYS_EXTRA_OPTIONS which is marked as deprecated. Add a new Kconfig file under arch/arm/imx-common and define the IMX_CONFIG Kconfig in there. Each board is supposed to provide a default value pointing to the appropriate imximage.cfg file. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2015-03-02imx6: Added DEK blob generator commandRaul Cardenas
Freescale's SEC block has built-in Data Encryption Key(DEK) Blob Protocol which provides a method for protecting a DEK for non-secure memory storage. SEC block protects data in a data structure called a Secret Key Blob, which provides both confidentiality and integrity protection. Every time the blob encapsulation is executed, a AES-256 key is randomly generated to encrypt the DEK. This key is encrypted with the OTP Secret key from SoC. The resulting blob consists of the encrypted AES-256 key, the encrypted DEK, and a 16-bit MAC. During decapsulation, the reverse process is performed to get back the original DEK. A caveat to the blob decapsulation process, is that the DEK is decrypted in secure-memory and can only be read by FSL SEC HW. The DEK is used to decrypt data during encrypted boot. Commands added -------------- dek_blob - encapsulating DEK as a cryptgraphic blob Commands Syntax --------------- dek_blob src dst len Encapsulate and create blob of a len-bits DEK at address src and store the result at address dst. Signed-off-by: Raul Cardenas <Ulises.Cardenas@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Signed-off-by: Ulises Cardenas <ulises.cardenas@freescale.com> Signed-off-by: Ulises Cardenas-B45798 <Ulises.Cardenas@freescale.com>
2015-02-17ARM: i.MX: provide access to reset cause through get_imx_reset_cause()Eric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-12-30imx: i2c: Zap unnecessary malloc() callsMarek Vasut
The malloc() calls are unnecessary, just allocate the stuff on stack. While at it, reorder the code a little, so that only one variable is used for the text, use snprintf() instead of sprintf() and use %01d as a formatting string to avoid any possible overflows. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-12-30imx SPL: enable boot from eMMC boot partitions.Pierre Aubert
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2014-12-01sata: fix reset_sata for dwc_ahsataSoeren Moch
- fix crash when sata device is not initialized - remove disable_sata_clock() since it is not clear which clock for which device should be disabled here - call disable_sata_clock() for mx6 in preboot_os instead Signed-off-by: Soeren Moch <smoch@web.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-11-24arm: imx: stop sata on bootNikita Kiryanov
Ideally, the Linux kernel should get the hardware in its most untouched state. For the most part, U-Boot does not reset the various subsystems it touches before boot, and usually Linux deals with it, but on some boards (cm_fx6) the Linux kernel fails to detect the ssd correctly if sata is used by U-Boot. Power off sata on OS boot so that Linux will have a clean state to work with. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-21mx6: thermal: Check cpu temperature via thermal sensorYe.Li
Add imx6 thermal device to mx6 soc file. Read the cpu temperature using this device to access onchip thermal sensor. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
2014-11-20imx: consolidate set_chipselect_size functionFabio Estevam
Move MX5 specific set_chipselect_size function into generic i.MX part, such that MX6 based boards are able to use this function as well. While doing this the iomuxc gpr member needed to be consolidated between MX5 and MX6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-13mx6: video_skip: Fix crash on NULL pointerNikolay Dimitrov
Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg> Cc: Stefano Babic <sbabic@denx.de>
2014-11-12arm: imx: make bmode command work with SPL/U-Boot comboNikita Kiryanov
The bmode command forces the SoC to use a specific boot device by writing its boot mode into SRC_GPR9, and notifying the SoC of the change using SRC_GPR10[28] bit: if the bit is on, bootROM uses the value in SRC_GPR9 instead of SRC_SMBR1 to determine the boot device. SPL on the other hand is oblivious to this distinction, so once the bootROM loads SPL from the device configured in SRC_GPR10, SPL will attempt to load U-Boot from the device configured in SRC_SMBR1, which is not updated by the bootROM to the value in SRC_GPR9. The result is that the selected boot device is not used across all the boot stages. Update spl_boot_device() to look at gpr9 when necessary. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Heiko Schocher <hs@denx.de>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-03imx: mx6 sabreauto: Add board support for USB EHCIYe.Li
On mx6 sabreauto board, there are two USB ports: 0: OTG 1: HOST The EHCI driver is enabled for this board, but the IOMUX and VBUS power control is not implemented, which cause both USB port failed to work. This patch fix the problem by adding the board support codes. Since the power control uses the GPIO pin from port expander MAX7310, the PCA953X driver is enabled for accessing the MAX7310. The ID pin of OTG Port needs to configure the GPR1 bit 13 for selecting its daisy chain. Add a new function "imx_iomux_set_gpr_register" to handle GPR register setting. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-03imx: gpt: Add High frequency clock source support for GPTYe.Li
Introduce a new configuration "CONFIG_MXC_GPT_HCLK". When it is set, the GPT will select a high frequency clock as clock source. Otherwise, the GPT will stay to use 32Khz OSC as clock source. In the implementation, since only the GPT on i.MX6 series provide the clock source option for 24Mhz OSC. For others (only i.MX5 and i.MX6 compile the driver), if the configuration is set, the perclk will be selected as clock source. MX6Q/D Rev 1.0 and MX6SL are special in the implementation, because they don't have the 24Mhz OSC clock source option, so also select the perclk for them. For MX6SL, we will set the OSC 24Mhz to perclk in CCM, so eventually the clock comes from OSC 24Mhz. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-imxTom Rini
2014-10-25imx: add missing includesJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-22dm: imx: i2c: Use gpio_request() to request GPIOsSimon Glass
GPIOs should be requested before use. Without this, driver model will not permit the GPIO to be used. Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-10-22imx: Add error checking to setup_i2c()Simon Glass
Since this function can fail, check its return value. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-10-21ARM: i.MX video: declare displays and display_count publiclyEric Nelson
Declare displays[] and display_count in imx-common/video.h to prevent "Should it be static?" messages when compiling board files with "make C=1". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-08-20ARM: mx6: Prevent overflow in DRAM size detectionMarek Vasut
The MX6 DRAM controller can be configured to handle 4GiB of DRAM, but only 3840 MiB of that can be really used. In case the controller is configured to operate a 4GiB module, the imx_ddr_size() function will correctly compute that there is 4GiB of DRAM in the system. Firstly, the return value is 32-bit, so the function will effectively return zero. Secondly, the MX6 cannot address the full 4GiB, but only 3840MiB of all that. Thus, clamp the returned size to 3840MiB in such case. Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Tim Harvey <tharvey@gateworks.com>
2014-07-23mx6: Remove duplication of iomuxc structureFabio Estevam
There is no need to keep iomuxc_base_regs structure as it serves the exact same purpose of the iomuxc structure, which is to provide access to the GPR registers. The additional fields of iomuxc_base_regs are not used. Other advantage of 'iomuxc' is that it has a shorter name and the variable declarations can fit into a single line. So remove iomuxc_base_regs structure and use iomuxc instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-07-16Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Conflicts: boards.cfg
2014-07-10mx6: Add support for the mx6solox variantFabio Estevam
mx6solox is the newest member of the mx6 family. Some of the new features on this variants are: - Cortex M4 microcontroller (besides the CortexA9) - Dual Gigabit Ethernet Add the initial support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-06-30Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-25vf610: fix build due to missing sys_proto.hStefano Babic
commit 67a04ab3ab8522a3a34491853e46105317580df5 fix the build for MX25. The same error happens for VF610 SOC. Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-06-06MX25: fix build due to missing sys_proto.hStefano Babic
THe mx25 arch does not have a sys_proto.h file. Instead of creating a dummy file, the file is not included for this SOC. Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-06-06imx: sata: return failure if not IMX6Q/IMX6DTim Harvey
The IMX6QUAD/DUAL have SATA, but the IMX6SOLO/DL do not. Return instead of configuring the SATA clock and GPR13 registers. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-06-06imx: iomux: add macros to setup iomux for multiple SoC typesTim Harvey
Allow imx_iomux_v3_setup_multiple_pads to take a multi-cpu pad_list and add macros for declaring the pad_list that take into account the SoC types supported using CONFIG_MX6QDL (supports both the MX6Q and MX6DL iomux). Cc: Stefan Roese <sr@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Andy Ng <andreas2025@gmail.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-06-06imx: add comments and remove unused struct fieldsTim Harvey
Add comment block for the imx_ddr_size function and remove the extra unused fields from struct esd_mmdc_regs which are also not common between IMX53 and IMX6. Cc: Stefan Roese <sr@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Andy Ng <andreas2025@gmail.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-06-06mx6: add boot device support for SPLTim Harvey
Add a common spl.c file to support boot device functions needed for SPL such as detecting the boot device. Cc: Stefan Roese <sr@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Andy Ng <andreas2025@gmail.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-06-05kbuild: move cmd_mkimage to scripts/Makefile.libMasahiro Yamada
Because cmd_mkimage is used in various subdirectories, it seems reasonable to define it in scripts/Makefile.lib. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-09iomux-v3: Add support for mx6sl LVE bitFabio Estevam
On mx6sl there is a LVE (Low Voltage Enable) bit in the IOMUXC_SW_PAD_CTL register that can enable or disable low voltage on the pad. LVE is bit 22 of IOMUXC_SW_PAD_CTL register, but in order to make the calculation easier we can define it as a flag in bit 1, since this bit is unused. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Otavio Salvador <otavio@ossystems.com.br>
2014-04-15imx-common/video: add detect_hdmiEric Benard
this function is used by several board together with board_video_skip to detect if hdmi is plugged is order to select the display to use. So move it in imx-common to share it. Signed-off-by: Eric Bénard <eric@eukrea.com>
