path: root/arch/arm/imx-common
2016-01-03imx_common: check for Serial Downloader in spl_boot_deviceStefano Babic
Check for bmode before reading the boot device to check if a serial downloader is started, and returns UART if the serial downloader is set, letting SPL to wait for an image if CONFIG_SPL_YMODEM_SUPPORT is set. This allows to load again a SPL based board with imx_usb_loader together with a tool such as kermit. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tim Harvey <tharvey@gateworks.com> CC: Fabio Estevam <Fabio.Estevam@freescale.com> CC: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Eric Nelson <eric@nelint.com> Tested-by: Eric Nelson <eric@nelint.com>
2015-11-12imx: mx7: compile misc.c for mx7Peng Fan
Compile misc.c for mx7, since we need related function for lcdif and nand. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Sanchayan Maity <maitysanchayan@gmail.com> Cc: Stefan Agner <stefan@agner.ch> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-12imx: imx-common: power down lcdif before boot osPeng Fan
Need to call lcdif_power_down to make lcdif in initial state before kernel boot. Similar issue for uboot reset with lcdif enabled, system will hang after serveral times resetting. Need to let lcdif initial state to make all go well. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-10-30imx: hab: add mx7 secure boot supportAdrian Alonso
Add mx7 secure boot support, add helper macro IS_HAB_ENABLED_BIT to get the corresponding bit mask per SoC (mx7 or mx6) to identify if securue boot feature is enabled/disabled. On authenticate_image only check for mmu enabled on mx6 SoC to force pu_irom_mmu_enabled so ROM code can perform mmu cache flush mx7 SoC ROM code does not have this issue as ROM enables cache support based on fuse settings. Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-10-30imx: hab: use read_fuse for secure boot settingsAdrian Alonso
Use read_fuse api fuction call to read secure boot fuse settings (enabled/disabled). Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-10-30imx: hab: use unified rom section for mx6sx and mx6ulAdrian Alonso
Add CONFIG_ROM_UNIFIED_SECTIONS for mx6sx and mx6ul target platforms to resolve corresponding HAB_RVT_BASE base address, the RVT table contains pointers to the HAB API functions in ROM code. Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-10-30imx: hab: rework secure boot support for imx6Adrian Alonso
Rework secure boot support for imx6, move existing hab support for imx6 into imx-common for SoC reuse. Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-10-30imx-common: timer: clean up codePeng Fan
We can reuse common functions in lib/time.c, but not reimplement functions in imx-common/time.c. Only keep timer_init ,get_tbclk and implement timer_read_counter in imx-common/time.c. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-10-02vf610: refactor DDRMC codeAlbert ARIBAUD \\(3ADEV\\)
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-09-24imx: fix coding stylePeng Fan
Fix coding style. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2015-09-24imx-common: wrap boot_mode_apply with CONFIG_CMD_BMODEPeng Fan
boot_mode_apply should be applied only with CONFIG_CMD_BMODE enabled. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2015-09-24imx-common: consider mux_ctrl_ofs when setting mux_modePeng Fan
Some i.MXes use __NA_ or 0 to avoid setting mux_mode, but the following patch only take i.MX6/7 into consideration. "c3c8a5748897b24f18618047804317167a531dd3 imx-common: fix iomux settings" Use is_soc_type(MXC_CPU_MX7) to avoid breaking other i.MXes when setting mux_mode. In this patch, switch to use "asm/imx-common/sys_proto.h" to avoid build break for "is_soc_type" for vf610 and mx25. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2015-09-20imx-common: fix iomux settingsPeng Fan
When setting iomux for a pin mux, there is no need to check mux_ctrl_ofs. Also If still checking mux_ctrl_ofs, we have no chance to set iomux for i.MX7D IOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO1_IO00, because the mux_ctrl_ofs for this register is 0. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13imx-common: cpu: Do not print on invalid temperatureFabio Estevam
It is not very useful to have the message below on every boot (especially when we are using early silicon): U-Boot 2015.10-rc2-23945-g37cf215 (Sep 08 2015 - 14:12:14 -0300) CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0 - invalid sensor device , so turn the error message into debug level. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13imx: imx7d: add imx-common cpu support for imx7dAdrian Alonso
Add imx-common cpu support for imx7d SoC - Update reset_cause for imx7d - Enable watchdog driver built for imx7d Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-09-13arm: imx-common: init: rework wdog settings for imx6/imx7Adrian Alonso
Rework imx_set_wdog_powerdown to be reused by imx6 and imx7 Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-09-13arm: imx-common: init: extend init_aips to support imx7Adrian Alonso
Extend init_aips to support imx7 SoC, use is_soc_type and is_cpu_type to resolve at run time aips3 settings Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-09-13imx: system counter driver for imx7d and mx6ulAdrian Alonso
Add system counter driver for imx7d and mx6ul imx7 and imx6ul supports system counter timer as well as GPT timer (arch/arm/imx-common/timer.c); The default for imx7 is systemcounter timer. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-09-13arm: imx: imx-common: init: move arch init common setupAdrian Alonso
Move common imx6 arch init setup, init.c can be extended and reused to support imx7 SoC keeping init arch common code. Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-09-13arm: imx: common rework cache settings for imx6Adrian Alonso
Rework cache settings for imx6, move cache configuration to imx-common/cache.c so it can be reused for newer SoC Signed-off-by: Adrian Alonso <aalonso@freescale.com>
2015-09-13thermal: imx_thermal: rework driver to be reusedAdrian Alonso
Rework imx_thermal driver to be used across i.MX processor that support thermal sensor Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-09-02imx: iomux-v3: add imx7d support for iomuxcAdrian Alonso
* Add imx7d support for iomux controller * imx7d has two iomux controllers iomuxc (0x3033000) and iomuxc-lpsr (0x302C0000) each conroller provides control and mux mode pad registers but shares iomuxc input select register with iomuxc-lpsr IOMUX_CONFIG_LPSR flag is used to properly set daisy chain settings for iomuxc-lpsr pads. * Since mx7d introduces LPSR IOMUX pins, add new base to IOMUX v3 driver for these LPSR pins. Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-08-02imx-common: timer: add i.MX6UL supportPeng Fan
Add i.MX6UL GPT timer support. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul: Add i.MX6UL CPU typePeng Fan
Add MXC_CPU_MX6UL for i.MX6UL CPU type which is got at runtime from DIGPROG register. But the value has been occupied by MXC_CPU_MX6D which is not real id from DIGPROG register, so change i.MX6D to value 0x67 which was not occupied. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-08-02imx: add cpu type for i.MX6QP/DPPeng Fan
Add cpu type for i.MX6QP/DP. This patch also fix is_mx6dqp(), since get_cpu_rev can return MXC_CPU_MX6QP and MXC_CPU_MX6DP, we should use: (is_cpu_type(MXC_CPU_MX6QP) || is_cpu_type(MXC_CPU_MX6DP)). Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-06-27imx: mx6 correct is_soc_rev usagePeng Fan
is_soc_rev should return a bool value, so use "==", but not "-", change (is_soc_rev(CHIP_REV_1_0) > 0) to (soc_rev() > CHIP_REV_1_0). This patch also add space between "&" for cpu_type(rev) macro. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-06-08imx: drop warning: unused variable 'max_freq'Stefano Babic
max_freq in print_cpuinfo is used only with imx6. Signed-off-by: Stefano Babic <sbabic@denx.de>
2015-06-08dm: gpio: vf610: Add GPIO driver supportBhuvanchandra DV
Add GPIO driver support to Freescale VF610 Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-05-28Revert "imx: drop warning: unused variable 'max_freq'"Stefano Babic
This reverts commit a0117a5e416629932becf079589f5e1859eab90a. Signed-off-by: Stefano Babic <sbabic@denx.de>
2015-05-27imx: drop warning: unused variable 'max_freq'Stefano Babic
2015-05-26arm, imx6, i2c: add I2C4 for MX6DLHeiko Schocher
add I2C4 modul for MX6DL based boards. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-19imx: mx6: add display of CPU temperature grade in print_cpuinfo()Tim Harvey
When CONFIG_IMX6_THERMAL is defined print the CPU temperature grade info along with the current temperature. Before: CPU: Temperature 42 C After: CPU: Automotive temperature grade (-40C to 125C) at 42C CPU: Industrial temperature grade (-40C to 105C) at 42C CPU: Extended Commercial temperature grade (-20C to 105C) at 42C Cc: Stefan Roese <sr@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Heiko Schocher <hs@denx.de> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jon Nettleton <jon.nettleton@gmail.com> Cc: Jason Liu <r64343@freescale.com> Cc: Ye Li <b37916@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Peng Fan <b51431@freescale.com> Tested-by: Nikolay Dimitrov <picmaster@mail.bg> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: mx6: display max cpu frequency in print_cpuinfo()Tim Harvey
Display the max CPU frequency as well as the current running CPU frequency if the max CPU frequency is available and differs from the current CPU frequency. Before: CPU: Freescale i.MX6Q rev1.2 at 792 MHz After - using an 800MHz IMX6DL (running at its max) CPU: Freescale i.MX6DL rev1.1 at 792 MHz After - using a 1GHz IMX6Q (not running at its max): CPU: Freescale i.MX6Q rev1.2 996 MHz (running at 792 MHz) Cc: Stefan Roese <sr@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Heiko Schocher <hs@denx.de> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jon Nettleton <jon.nettleton@gmail.com> Cc: Jason Liu <r64343@freescale.com> Cc: Ye Li <b37916@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Peng Fan <b51431@freescale.com> Tested-by: Nikolay Dimitrov <picmaster@mail.bg> Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19arm/imx-common: Fix warning 'get_reset_cause' defined but not usedPrabhakar Kushwaha
Fix below warning arch/arm/imx-common/cpu.c:29:14: warning: ‘get_reset_cause’ defined but not used static char *get_reset_cause(void) Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-05-15imx: dek_blob: Add explicit include for mapmemUlises Cardenas
Boards such as imx6q_sabresd might not have mapmem.h as part of their common library. This causes a build error if the DEK blob command is enabled. Fix: make explicit the include of mapmem.h Signed-off-by: Ulises Cardenas <Ulises.Cardenas@freescale.com> Reviewed-by: Ruchika Gupta <Ruchika.gupta@freescale.com>
2015-05-14i2c: mxc: refactor i2c driver and support dmPeng Fan
1. Introduce a new structure `struct mxc_i2c_bus`, this structure will used for non-DM and DM. 2. Remove `struct mxc_i2c_regs` structure, but use register offset to access registers based on `base` entry of `struct mxc_i2c_bus`. 3. Remove most `#ifdef I2C_QUIRK_REG`. Using driver_data to contain platform flags. A new flag is introduced, I2C_QUIRK_FLAG. 4. Most functions use `struct mxc_i2c_bus` as one of the parameters. Make most functions common to DM and non-DM, try to avoid duplicated code. 5. Support DM, but pinctrl is not included. Pinmux setting is still set by setup_i2c, but we do not need bus_i2c_init for DM. 6. struct i2c_parms and struct sram_data are removed. 7. Remove bus_i2c_read bus_i2c_write prototype in header file. The frist paramter of bus_i2c_init is modified to i2c index. Add new prototype i2c_idle_bus and force_bus_idle. Since bus_i2c_init is not good for DM I2C and pinctrl is missed, we use a weak function for i2c_idle_bus. Board file take the responsibility to implement this function, like this: " int i2c_idle_bus(struct mxc_i2c_bus *i2c_bus) { if (i2c_bus->index == 0) force_bus_idle(i2c_pads_info0); else if (i2c_bus->index == 1) force_bus_idle(i2c_pads_info1); else xxxxxx } " 8. Introduce a weak function, enable_i2c_clk 9. Tested on an i.MX7 platform. Log info: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver simple_bus [ ] |-- soc simple_bus [ ] | |-- aips-bus@30000000 simple_bus [ ] | | |-- anatop@30360000 simple_bus [ ] | | `-- snvs@30370000 simple_bus [ ] | |-- aips-bus@30400000 simple_bus [ ] | `-- aips-bus@30800000 i2c [ ] | |-- i2c@30a20000 i2c [ ] | `-- i2c@30a40000 simple_bus [ ] `-- regulators => i2c dev 0 Setting bus to 0 => i2c probe Valid chip addresses: 08 50 => i2c md 8 31 0031: 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-23ARM: vf610: Move DDR3 initialization to imx-commonSanchayan Maity
In order to avoid code duplication, move the DDR3 initialization to the common place under imx-common. Currently ROW_DIFF and COL_DIFF can be chosen from the board file. The JEDEC timings are specified using a common ddr3_jedec_timings structure. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-03-23ARM: iMX: define an IMX_CONFIG Kconfig optionBoris BREZILLON
IMX_CONFIG is currently passed via the SYS_EXTRA_OPTIONS which is marked as deprecated. Add a new Kconfig file under arch/arm/imx-common and define the IMX_CONFIG Kconfig in there. Each board is supposed to provide a default value pointing to the appropriate imximage.cfg file. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2015-03-02imx6: Added DEK blob generator commandRaul Cardenas
Freescale's SEC block has built-in Data Encryption Key(DEK) Blob Protocol which provides a method for protecting a DEK for non-secure memory storage. SEC block protects data in a data structure called a Secret Key Blob, which provides both confidentiality and integrity protection. Every time the blob encapsulation is executed, a AES-256 key is randomly generated to encrypt the DEK. This key is encrypted with the OTP Secret key from SoC. The resulting blob consists of the encrypted AES-256 key, the encrypted DEK, and a 16-bit MAC. During decapsulation, the reverse process is performed to get back the original DEK. A caveat to the blob decapsulation process, is that the DEK is decrypted in secure-memory and can only be read by FSL SEC HW. The DEK is used to decrypt data during encrypted boot. Commands added -------------- dek_blob - encapsulating DEK as a cryptgraphic blob Commands Syntax --------------- dek_blob src dst len Encapsulate and create blob of a len-bits DEK at address src and store the result at address dst. Signed-off-by: Raul Cardenas <Ulises.Cardenas@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Signed-off-by: Ulises Cardenas <ulises.cardenas@freescale.com> Signed-off-by: Ulises Cardenas-B45798 <Ulises.Cardenas@freescale.com>
2015-02-17ARM: i.MX: provide access to reset cause through get_imx_reset_cause()Eric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-12-30imx: i2c: Zap unnecessary malloc() callsMarek Vasut
The malloc() calls are unnecessary, just allocate the stuff on stack. While at it, reorder the code a little, so that only one variable is used for the text, use snprintf() instead of sprintf() and use %01d as a formatting string to avoid any possible overflows. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-12-30imx SPL: enable boot from eMMC boot partitions.Pierre Aubert
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2014-12-01sata: fix reset_sata for dwc_ahsataSoeren Moch
- fix crash when sata device is not initialized - remove disable_sata_clock() since it is not clear which clock for which device should be disabled here - call disable_sata_clock() for mx6 in preboot_os instead Signed-off-by: Soeren Moch <smoch@web.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-11-24arm: imx: stop sata on bootNikita Kiryanov
Ideally, the Linux kernel should get the hardware in its most untouched state. For the most part, U-Boot does not reset the various subsystems it touches before boot, and usually Linux deals with it, but on some boards (cm_fx6) the Linux kernel fails to detect the ssd correctly if sata is used by U-Boot. Power off sata on OS boot so that Linux will have a clean state to work with. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-21mx6: thermal: Check cpu temperature via thermal sensorYe.Li
Add imx6 thermal device to mx6 soc file. Read the cpu temperature using this device to access onchip thermal sensor. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
2014-11-20imx: consolidate set_chipselect_size functionFabio Estevam
Move MX5 specific set_chipselect_size function into generic i.MX part, such that MX6 based boards are able to use this function as well. While doing this the iomuxc gpr member needed to be consolidated between MX5 and MX6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-13mx6: video_skip: Fix crash on NULL pointerNikolay Dimitrov
Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg> Cc: Stefano Babic <sbabic@denx.de>
2014-11-12arm: imx: make bmode command work with SPL/U-Boot comboNikita Kiryanov
The bmode command forces the SoC to use a specific boot device by writing its boot mode into SRC_GPR9, and notifying the SoC of the change using SRC_GPR10[28] bit: if the bit is on, bootROM uses the value in SRC_GPR9 instead of SRC_SMBR1 to determine the boot device. SPL on the other hand is oblivious to this distinction, so once the bootROM loads SPL from the device configured in SRC_GPR10, SPL will attempt to load U-Boot from the device configured in SRC_SMBR1, which is not updated by the bootROM to the value in SRC_GPR9. The result is that the selected boot device is not used across all the boot stages. Update spl_boot_device() to look at gpr9 when necessary. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Heiko Schocher <hs@denx.de>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
