Introduce a new config symbol to select the i.MX
General Purpose Timer (GPT).
Use i.MX bootaux support introduced for i.MX 6SoloX/i.MX 7 for
Vybrid too. Starting the Cortex-M4 core on Vybrid works a bit
differently, namely it uses a GPR register to define the initial
PC. There is no way to define the initial stack (the stack is
set up in a boot ROM). This is not a problem for most firmwares
since the firmwares startup code reinitialize the stack as part
of the firmware startup code anyway.
Introduce USE_IMXIMG_PLUGIN Kconfig
Signed-off-by: Peng Fan <peng.fan@nxp.com>
So the option can easily be selected through menuconfig.
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
To boot a auxiliary core in asymmetric multicore system, introduce the
new command "bootaux" to do it. Example of boot auxliary core from
0x70000000 where stores the boot head information that should be
parsed by auxiliary core, "bootaux 0x70000000".
Introduce Kconfig option IMX_BOOTAUX.
Signed-off-by: Ye.Li <ye.li@nxp.com>
Introduce Resource Domain Controller support for i.MX.
Now i.MX6SX and i.MX7D supports this feature to assign masters
and peripherals to different domains.
Add CONFIG_ROM_UNIFIED_SECTIONS for mx6sx and mx6ul target
platforms to resolve corresponding HAB_RVT_BASE base address,
the RVT table contains pointers to the HAB API functions in
ROM code.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
IMX_CONFIG is currently passed via the SYS_EXTRA_OPTIONS which is marked
as deprecated.
Add a new Kconfig file under arch/arm/imx-common and define the
IMX_CONFIG Kconfig in there.
Each board is supposed to provide a default value pointing to the
appropriate imximage.cfg file.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
