for DSPI flash
The type of DSPI flash on ls1021aqds is AT45DB021, it has specail
commands and page-size.
Use the special spi flash driver instead of "spi_flash_std" driver.
Signed-off-by: Haikun Wang <haikun.wang@freescale.com>
Tested-by: Haikun Wang <haikun.wang@freescale.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
The 4KB padding doesn't seem necessary since we don't normally adjust the
control device tree file within U-Boot. Also drop the memory table space.
This commit cleanup MAX77686 regulator node by:
- remove the sub-nodes of unconnected regulators
- remove the "regulator-compatible" properties of all regulators
This prevents printing init errors for the regulators,
with duplicated name strings.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Enable the EC and keyboard, using the SPI bus.
The EC driver requires a particular format and a deactivation delay. Also
U-Boot does not support interrupts.
For now, adjust the device tree to comply. At some point we should tidy
this up to support interrupts and make tegra and exynos use the same setup.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add device tree files for Freescale Vybrid platform and
Toradex Colibri VF50, VF61 modules.
Device tree files are taken from upstream Kernel.
Removed the stuff which are not used/supported yet in U-Boot.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add and use a proper dts for the ga10h a33 based tablet, as
submitted upstream.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Copy over all the latest dts changes from mripard/sunxi/dt-for-4.2 ,
this gives us a proper dtsi file for the A33 rather then abusing
sun8i-a23.dtsi for this.
And this replaces our minimal (dummy) sun7i-a20-mk808c and
sun8i-a33-astar-mid756 dts files with proper ones.
The Mele A1000G-quad and the Mele M9 have the same PCB, sofar we've been
using the same defconfig (and dts on the kernel side) for both models.
Unfortunately this does not work for the otg controller, on the M9 this
is routed to a micro-usb connector on the outside, while as on the
A1000G-quad it is connected to an usb to sata bridge.
This commit adds a new defconfig for the Mele-A1000G-quad to allow using
different otg controller settings on the 2 boards.
Adding regulators subnode to fdt max77686 node, allows properly init
regulators by the max77686 regulator driver. This enables the complete
functionality of the regulator command.
This commit also updates the proper dts files.
This name is used in Linux, so use it in U-Boot.
Add the various host1x peripherals to allow an eDP display to be connected.
This peripheral is required to get the LCD display running. Add it to
tegra124 and also bring in the binding file from Linux 3.18
Add required setup for the LCD display, and a function to provide the
board ID. This requires GPIOs to be available prior to relocation.
This patch adds device tree for the ST Micro stv0991 board & enables
device tree control. Progressively device tree support for the drivers
being used will also be added.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Replace CONFIG_SOCFPGA with CONFIG_ARCH_SOCFPGA.
u-boot has support for a number of boards for which a dts file still needs
to be written, add minimal dts files for these boards so that we can switch
them over to driver-model / fdt.
We need dts files for all boards we support, so bring in a few unmerged ones,
these will be replaced with the upstream merged versions the next time we
sync dts files.
Bring all the sunxi dts files (and update existing ones) from
mripard/sunxi/dt-for-4.1 (which will be merged into upstream master any
day now). This is necessary so that we can move all sunxi boards over to
the driver model.
The PicoZed is a System-on-Module board which is marketed as part of
the ZedBoard/MicroZed/etc. collection. It includes a Zynq-7000
processor.
This patch adds support that covers all the variants of the PicoZed
including the SKUs with Z7010/Z7020 and Z7015/Z7030 Zynq chips. This
patch set however only covers support for the System-on-Module and does
not cover any extra components that are available on carrier boards
(except those that are fanned out of the module itself).
More information on this board, its variants and available carrier
boards is available at: http://zedboard.org/product/picozed
Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com>
Arria V SocDK has same QSPI and SPI flash configuration as Socrates. Add
support for it.
Signed-off-by: Pavel Machek <pavel@denx.de>
support for it.
For some files I neglected to add a license. Rectify this:
arch/arm/dts/exynos4210-pinctrl-uboot.dtsi
arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi
arch/arm/dts/exynos5250-pinctrl-uboot.dtsi
arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi
arch/arm/dts/s5pc100-pinctrl.dtsi
arch/arm/dts/s5pc110-pinctrl.dtsi
This file came from Linux and has no license information there, so add a
comment to that effect:
arch/sandbox/include/asm/bitops.h
This file also came from Linux - presumably someone from TI could add the
license:
include/dt-bindings/pinctrl/omap.h
Reported-by: Ingrid Viitanen <ingrid.viitanen@nokia.com>
Since we can support both controllers now, enable this in the device tree.
These are needed to enable the USB bus (although not sufficient since it
still does not work).
Add QSPI controller dts node in ls1021a.dtsi.
Add QSPI slave device dts node in ls1021a-twr.dts and ls1021a-qds.dts.
Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com>
Update DSPI controller node in ls1021a.dtsi.
Update flash device node in ls1021a-qds.dts.
Ls1021a-twr board doesn't support DSPI, so remove DSPI node
in ls1021a-twr.dts.
Change address_cells and size_cells of root node and 'soc' node
from 2 to 1.
We backport ls1021a device tree source files from kernel to u-boot.
Kernel files set address_cells and size_cells to 2 in order to access
more than 4GB space.
But we don't have this requirement now and u-boot fdtdec_get_xxx interfaces
can't support property whose size is 'u64' completely.
So make this change.
Bring in required device tree files for ls1021a from Linux.
These are initially unchanged and have a number of pieces not needed by U-Boot.
Backport of kernel commits:
7c14f6c719de092d69c81877786e83ce7ae1a860
35faad2a1563b3d4dc983a82ac41033fe053870c
The U-Boot device trees are slightly different in a few places. Adjust them
to remove most of the differences. Note that U-Boot does not support the
concept of interrupts as distinct from GPIOs, so this difference remains.
For sandbox, use the same keyboard file as for ARM boards and drop the
host emulation bus which seems redundant.
Add backlight enable GPIO, and delay needed for panel powerup
via FIMD DT node.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Now that parade driver supports reading SLP and RST GPIO
from DT, specify the same in parade DT node.
Now that the exynos_fb driver supports handling backlight GPIO
via DT, specify pwm output property via FIMD DT node.
In accordance with our other modules supported by U-Boot and as agreed
upon for Apalis/Colibri T30 get rid of the carrier board in the board/
configuration/device-tree naming.
While at it also bring the prompt more in line with our other products.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Panasonic's System LSI products, UniPhier SoC family, have been
transferred to Socionext Inc.
README
Import DTS for Arria V development kit and enable support
for DT. The DT is imported from Linux 3.19-rc1 as of commit
97bf6af1f928216fd6c5a66e8a57bfa95a659672 .
Cc: Chin Liang See <clsee@opensource.altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
Cc: Vince Bridgers <vbridger@opensource.altera.com>
Import DTS for Cyclone V development kit and enable support
This fixes the MMC/SD card detect GPIOs for Apalis T30 which got broken
by the following commit:
2b2b50bc8748 "dm: tegra: dts: Use TEGRA_GPIO() macro for all GPIOs"
While at it also re-add the comments describing which particular
Apalis/Colibri pins those GPIOs are on.
All boards with a SPI interface have a suitable spi alias except Apalis
T30. Add these missing aliases just as the following commit did for the
others:
d2f60f93325a "dm: tegra: dts: Add aliases for spi on tegra30 boards"
Each USB port corresponds to the following IP core:
port0: xHCI (0x65a00000) SS+HS
port1: xHCI (0x65c00000) HS (SS PHY is not implemented)
port2: EHCI (0x5a800100) HS
port3: EHCI (0x5a810100) HS
EHCI host controllers have a common register interface.
We may wish to implement a generic EHCI driver someday.
This needs for special handling of nRESET_OUT line(GPD1-0 gpio) for eMMC
memory to perform complete reboot on Odroid XU3 board.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
