path: root/arch/arm/dts
2020-02-04arm: dts: lx2160a: Add FSPI node propertiesKuldeep Singh
Align flexspi node properties with linux device-tree properties Tested on LX2160A-RDB Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04arm: dts: ls1028a: Add FSPI node propertiesKuldeep Singh
Align flexspi node properties with linux device-tree properties Tested on LS1028A-RDB Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04arm: dts: ls1028a: fix interrupt propertiesMichael Walle
Sync the interrupt properties with the ones from Linux. Also use the constants provided by the dt-bindings header. Please note, that there are actual changes/fixes in the irq flags. U-Boot won't use the interrupt properties anyway. It's just to be consistent with the Linux device tree. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04arm: ls1028a: use the new flexspi driverMichael Walle
Also align the fspi node with the kernel one. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-30rockchip: rk3308: add alias for emmc/sdmmcKever Yang
Add alias for mmc/sdmmc so that we can have a fix mmc number for emmc. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-30ram: rk3328: update lpddr3 settingYouMin Chen
update lpddr3 setting for fix init fail about "col error". Signed-off-by: YouMin Chen <cym@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30ram: rk3328: add support ddr4 initYouMin Chen
Add rk3328-sdram-ddr4-666.dtsi for support ddr4 init. Signed-off-by: YouMin Chen <cym@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30rockchip: Add Single boot image (with binman, pad_cat)Jagan Teki
All rockchip platforms support TPL or SPL-based bootloader in mainline with U-Boot proper as final stage. For each stage we need to burn the image on to flash with respective offsets. This patch creates a single boot image component using - binman, for arm32 rockchip platforms - pad_cat, for arm64 rockchip platforms. This would help users to get rid of burning different boot stage images. The new image called 'u-boot-rockchip.bin' which can burn into flash like: ₹ sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64 This would support all rockchip platforms, except rk3128 since it doesn't support for SPL yet. Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com> Cc: Wadim Egorov <w.egorov@phytec.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30arm: dts: rk3188: Add rk3188-u-boot.dtsiJagan Teki
Add U-Boot specific dtsi file for rk3188 SoC. This would help to add U-Boot specific dts nodes, properties which are common across rk3188. Right now, the file is empty, will add required changes in future patches. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30arm: dts: rk3036: Add rk3036-u-boot.dtsiJagan Teki
Add U-Boot specific dtsi file for rk3036 SoC. This would help to add U-Boot specific dts nodes, properties which are common across rk3036. Right now, the file is empty, will add required changes in future patches. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30rockpro-rk3399: Enable SPI FlashJagan Teki
Enable winbond SPI flash for ROC-PC-RK3399 board. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-30roc-pc-rk3399: Enable SPI FlashJagan Teki
2020-01-30rockchip: dts: Sync ROC-RK3399-PC changes from LinuxJagan Teki
Sync the ROC-RK3399-PC device tree changes from Linux with below commit details: commit <c36308abe4110e4db362d5e2ae3797834a7b1192> ("arm64: dts: rockchip: Enable MTD Flash on rk3399-roc-pc") Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-28Merge branch 'master' of https://gitlab.denx.de/u-boot/custodians/u-boot-samsungTom Rini
- Various exynos fixes
2020-01-26Merge branch 'master' of https://gitlab.denx.de/u-boot/custodians/u-boot-sunxiTom Rini
- Libre Computer ALL-H3-IT/ALL-H5-CC board (Chen-Yu Tsai) - Allwinner R40 Ethernet, usb phy enablement (Andre Przywara) - Sunxi auto load from 128KB MMC offset (Andre Przywara) - Orange Pi Win Ethernet phy enablement (Jernej Skrabec)
2020-01-25usb: musb-new: mt85xx: add musb-new gadget driver.mingming lee
Using musb-new structure for mt85xx gadget driver. Add gadget driver dts for mt8518 SoCs. Signed-off-by: mingming lee <mingming.lee@mediatek.com>
2020-01-24sunxi: dts: R40: Update Bananapi M2 Berry .dtsAndre Przywara
Update the .dts file from the kernel, which carries much more nodes, some of them we need to enable USB and Ethernet support for the board. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-24sunxi: H3/H5 Sync DT files from upstream Linux kernel as of next-20200108Chen-Yu Tsai
Sync the device tree files and device tree header files from upstream Linux kernel, as of 2020-01-08. The commit synced to in the sunxi repo 98d25b0b266d Merge branch 'sunxi/dt-for-5.6' into sunxi/for-next which is also part of next-20200108. Changes brought in include: - cleanup of pinmux node names - addition of Security ID, MBUS, CSI, crypto engine, video codec, pmu, and thermal sensor device nodes for both SoCs - addition of deinterlacing engine device node on H3 - cleanup of RTC device node and addition of its clocks - various board cleanups and improvements - removal of pinmux node for GPIO lines - cpufreq / DVFS - HDMI output - UART-based Bluetooth - audio codec - USB ports - new boards Most of the changes don't concern U-boot. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-23bcm968360bg: add initial supportPhilippe Reynes
This add the initial support of the broadcom reference board bcm968360bg with a bcm68360 SoC. This board has 512 MB of RAM, 256 MB of flash (nand), 2 USB port, 1 UART, and 4 ethernet ports. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-23bcm68360: add initial supportPhilippe Reynes
This add the initial support of the broadcom bcm68360 SoC family. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-23arm: dts: exynos: Use common alias for Odroid U3/X2 MMC2 (SD-card)Marek Szyprowski
Use MMC0 for eMMC and MMC2 for SD-card as other Exynos-based boards do. This allows to use common code to get MMC device id based on the XOM[7:5] pins. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2020-01-23arm: dts: exynos: Fix card-detect polarity for SD card on Odroid U3/X2Marek Szyprowski
Card detect line for SD-card on Odroid U3/X2 boards are active low, so add cd-inverted property to indicate this, as u-boot's GPIO driver doesn't support specifying line polarity. This restores S5P_SDHCI driver operation on Odroid U3/X2 boards. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2020-01-23arm: dts: exynos: Extend board descriptionMarek Szyprowski
u-boot uses the same DTS for the all Odroid XU3-based boards, so list them in the model description to let user know that those boards are supported. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2020-01-22board: Add new Samsung "stemmy" board based on ST-Ericsson U8500Stephan Gerhold
The ST-Ericsson U8500 SoC has been used in mass-production for some Android smartphones released around 2012. In particular, Samsung has released more than 5 different smartphones based on U8500, e.g. - Samsung Galaxy S III mini (GT-I8190) "golden" - Samsung Galaxy S Advance (GT-I9070) "janice" - Samsung Galaxy Xcover 2 (GT-S7710) "skomer" and a few others. Mainline Linux has great support for the Ux500 SoC, so these smartphones can also run Linux mainline quite well. Unfortunately, the original Samsung bootloader used on these devices has limitations that prevent booting Linux mainline directly. It keeps the L2 cache enabled, which causes Linux to crash very early, shortly after decompressing the kernel. Using U-Boot allows to circumvent these limitations. We can let the Samsung bootloader chain-load U-Boot and U-Boot locks the L2 cache before booting into Linux. U-Boot has several other advantages - it supports device-trees directly and we are no longer limited to flashing Android boot images through Samsung's proprietary download mode. The Samsung "stemmy" board covers all Samsung devices based on U8500. Add minimal support for "stemmy". For now only UART is supported but this will be extended later. Signed-off-by: Stephan Gerhold <stephan@gerhold.net> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2020-01-22arm: Add support for ST-Ericsson U8500 SoCStephan Gerhold
The NovaThor U8500 SoC was released by ST-Ericsson in 2011. It was used for some development boards like the CALAO Systems Snowball SBC, but mass production was primarily for Android smartphones like the Samsung Galaxy S III mini. Previous support for U8500 was removed in commit 68282f55b846 ("arm: Remove unused ST-Ericsson u8500 arch") since none of the boards were converted to generic boards before the deadline. The new code does not have much in common with the previous code. I have completely rewritten everything, embracing the Driver Model and device trees wherever possible. The U8500 support is a bit more minimal for now - my primary use case is to use U-Boot as alternative bootloader for some of the U8500 Samsung smartphones. At the moment U-Boot is chain-loaded from the original Samsung bootloader. A side effect of this is that we can (temporarily) get away without implementing some functionality - e.g. all clocks are already enabled by the original bootloader. More functionality will be added in future patches. Cc: Mathieu Poirier <mathieu.poirier@linaro.org> Cc: John Rigby <john.rigby@linaro.org> Signed-off-by: Stephan Gerhold <stephan@gerhold.net> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2020-01-22arm: dts: Import device tree for ST-Ericsson Ux500Stephan Gerhold
from https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson.git/ tag "ux500-armsoc-v5.6-2" commit 224bf0fe7292 ("ARM: dts: ux500: samsung-golden: Add Bluetooth") (queued for merge in Linux 5.6) Signed-off-by: Stephan Gerhold <stephan@gerhold.net> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2020-01-21Merge https://gitlab.denx.de/u-boot/custodians/u-boot-marvellTom Rini
- Clearfog: Add run-time board detection with TLV EEPROM support (Baruch)
2020-01-21ARM: mvebu: clearfog: add EEPROM devicesBaruch Siach
Add device-tree description for the EEPROM devices on Armada 388 SOM rev 2.1. Another EEPROM is now on Clearfog Pro carrier rev 2.2, and Clearfog Base rev 1.3. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2020-01-21Merge tag 'u-boot-imx-20200121' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx --------------------------------- imx8: cleanup, fix warnings imx6ull: add VisionSOM SoM and EVK mx7ulp: fix warning due network, cleanup mx7dsabre: Fix dm probe pmic imx6: fixed for vining2000 Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/639512296
2020-01-20Merge tag '2020-01-20-ti-2020.04' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-ti K3 J721E: * DMA support. * MMC and ADMA support. * EEPROM support. * J721e High Security EVM support. * USB DT nodes K3 AM654: * Fixed boot due to pmic probe error. * USB support and DT nodes. * ADMA support DRA7xx/AM57xx: * BBAI board support * Clean up of net platform code under board/ti AM33/AM43/Davinci: * Reduce SPL size for omap3 boards. * SPL DT support for da850-lcdk * PLL divider fix for AM335x
2020-01-20arm: dts: imx7ulp-evk: remove mux value from pad configurationJorge Ramirez-Ortiz
The mux mode is embedded in the PAD definition and therefore there is no need to repeat it in the PAD configuration value (more over since this information will be masked out when the configuration value is applied). Signed-off-by: Jorge Ramirez-Ortiz <jorge@foundries.io> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2020-01-20arm: dts: i.mx8x: add #cooling-cells propertiesAnatolij Gustschin
Fix dtb building warnings: Warning (cooling_device_property): /thermal-zones/cpu-thermal0/cooling-maps/map0: Missing property '#cooling-cells' in node /cpus/cpu@0 or bad phandle (referred from cooling-device[0]) Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2020-01-20ARM: imx: mx6ull: Add iMX6ULL VisionSOM SoM and EVKArkadiusz Karas
Add iMX6ULL VisionSOM SoM and VisionCB-RT-STD evaluation board support. The SoM has an iMX6ULL, 512 MiB of DRAM and microSD slot. The carrier board has Ethernet, USB host port, USB OTG port. Signed-off-by: Arkadiusz Karas <arkadiusz.karas@somlabs.com> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2020-01-20arm: dts: k3-am654-base-board: enable USB1Vignesh Raghavendra
Add pinmux for USB1 and enable it as a peripheral port in U-Boot specific dtsi since U-Boot does not support OTG. Disable USB0 as its not available on the baseboard. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20arm: dts: k3-am65-main: add USB supportVignesh Raghavendra
Add support for USB0 and USB1 instances on the AM6 SoC. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20ARM: dts: omap3/omap35 Torpedo and SOM-LV: Unify and shrink SPL dtbAdam Ford
None of these boards boot, but the solution appears to be the same. All the boards have SPL that is too large. With a few defconfig options removed, these corresponding options can be removed from their respective SPL dtb files. This patch unifies the DM37/OMAP35 boards' -u-boot.dtsi files to remove gpio's, i2c, bandgap, thermal zones, unneeded uarts, and unneeded MMC nodes. Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20arm: dts: k3-am654-r5-base-board: Fix power-domains for wkup_vtm0Lokesh Vutla
wkup_vtm populates only 1 power-domain cell in it's node. But the power-domain cell are defined as 2. Due to this the following warning comes during build: arch/arm/dts/k3-am654-r5-base-board.dtb: Warning (power_domains_property): /interconnect@100000/interconnect@28380000/interconnect@42040000/ wkup_vtm@42050000:power-domains: property size (8) too small for cell size 2 Fix this by updating the power-domain cells. Fixes: cfa6bd549c ("arm: dts: k3-am654-r5-base-board: Add VTM node") Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20arm64: dts: k3-j721e-common-proc-board: Fully enable wkup_i2c0 useAndreas Dannenberg
Make the wkup_i2c0 module usable across all stages of U-Boot by adding the needed definitions including the associated pinmux definitions. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20board: ti: beagleboneai: add dts fileJason Kridner
BeagleBoard.org BeagleBone AI is an open source hardware single board computer based on the Texas Instruments AM5729 SoC featuring dual-core 1.5GHz Arm Cortex-A15 processor, dual-core C66 digital signal processor (DSP), quad-core embedded vision engine (EVE), Arm Cortex-M4 processors, dual programmable realtime unit industrial control subsystems and more. The board features 1GB DDR3L, USB3.0 Type-C, USB HS Type-A, microHDMI, 16GB eMMC flash, 1G Ethernet, 802.11ac 2/5GHz, Bluetooth, and BeagleBone expansion headers. For more information, refer to: https://beaglebone.ai The corresponding patch against the mainline linux kernel can be found at: https://patchwork.kernel.org/patch/11254903/ This patch introduces the BeagleBone AI device tree. Note that the device use the "ti,tpd12s016" component which is software compatible with "ti,tpd12s015". Thus we only use the latter driver. Signed-off-by: Jason Kridner <jdk@ti.com> Signed-off-by: Caleb Robey <c-robey@ti.com> Cc: Robert Nelson <robertcnelson@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20arm: dts: k3-j721e-common-proc-board: Add pinmux for SD cardFaiz Abbas
Add pinmux for sdhci1 node connected to the SD card. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20arm: dts: k3-j721e-common-proc-board: Remove voltage-ranges from sdhci nodesFaiz Abbas
voltage-ranges properties are NOP. Remove them. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20mmc: am654_sdhci: Get Xin clock by nameFaiz Abbas
Get clk_xin by name instead of by index to avoid having to put clocks in the same order in all devices. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20ARM: dts: da850-lcdk: Update DTS files for SPL device tree supportAdam Ford
Currently, the da850-lcdk uses SPL_OF_PLATDATA and manually loads the necessary source code instead of using the auto-generated, because the drivers don't properly autogenerate the code. This patch simply enables the various device tree options to mimic the da850-evm which doesn't need or use OF_PLATDATA for device tree support. It does not disable OF_PLATDATA. Signed-off-by: Adam Ford <aford173@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20arm: dts: k3-j721e: Add DT nodes for USBVignesh Raghavendra
J721e has two instances of Cadence USB3 controller. Add DT nodes for the same. USB0 is configured to device mode and USB1 is configured to host mode. For now only high speed mode is supported. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-17ARM: dts: stm32: Add missing ETHCK clock to ethernet nodeMarek Vasut
Add missing 'eth-ck' clock to the ethernet node. These clock are used to generate external clock signal for the PHY in case 'st,eth_ref_clk_sel' is specified. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-01-17stm32mp1: split board and SOC support for STM32MP15x familyPatrick Delaunay
Split the board and SOC support for STM32MP15x family and prepare the introduction of new boards with STM32MP15x. This path define the 2 configurations: - STM32MP15x: STM32MP15x soc support (new) - TARGET_ST_STM32MP15x: STMicroelectronics board support (choice) Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2020-01-16Merge tag 'xilinx-for-v2020.04' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze Xilinx/FPGA changes for v2020.04 ARM64: - Add INIT_SPL_RELATIVE dependency SPL: - FIT image fix - Enable customization of bl2_plat_get_bl31_params() Pytest: - Add test for octal/hex conversions Microblaze: - Fix manual relocation for one SPI instance Nand: - Convert zynq/zynqmp drivers to DM Xilinx: - Enable boot script location via Kconfig - Support OF_SEPARATE in board FDT selection - Remove low level uart setup it is done later by code - Add support for DEVICE_TREE variable passing for SPL Zynq: - Enable jtag boot mode via distro boot - Removing unused baseaddresses from hardware.h - DT fixups ZynqMP: - Fix emmc boot sequence - Simplify spl logic around bss and board_init_r() - Support psu_post_config_data() calling - Tune mini-nand DTS - Fix psu wiring for a2197 boards - Add runtime MMC device boot order filling in spl - Clear ATF handoff handling with custom bl2_plat_get_bl31_params() - Add support u-boot.its generation - Use single image configuration for all platforms - Enable PANIC_HANG via Kconfig - DT fixups - Firmware fixes - Add support for zcu208 and zcu1285 Versal: - Fix emmc boot sequence - Enable board_late_init() by default
2020-01-16arm: dts: mediatek: move u-boot properties to -u-boot.dtsi fileSam Shih
This patch move u-boot properties to -u-boot.dtsi file. Signed-off-by: Sam Shih <sam.shih@mediatek.com> Reviewed-by: Ryder Lee <ryder.lee@mediatek.com>
2020-01-16Add support for MT7622 reference boardSam Shih
This adds a general board file based on MT7622 SoCs from MediaTek. This commit is adding the basic boot support for the MT7622 rfb. Signed-off-by: Sam Shih <sam.shih@mediatek.com> Reviewed-by: Ryder Lee <ryder.lee@mediatek.com> Tested-by: Frank Wunderlich <frank-w@public-files.de>
2020-01-16ARM: MediaTek: Add support for MediaTek MT7622 SoCSam Shih
Add support for MediaTek MT7622 SoC. This include the file that will initialize the SoC after boot and its device tree. Signed-off-by: Sam Shih <sam.shih@mediatek.com> Reviewed-by: Ryder Lee <ryder.lee@mediatek.com>
