path: root/arch/arm/dts
2019-01-02rockchip: rk3399-puma: Set VDD_LOG to 950 mV.Christoph Muellner
This patch sets VDD_LOG to 950 mV on RK3399-Q7. This is required to address stability issues on Puma in heavy-load use-cases. Reported-by: Assaf Agmon <assaf@r-go.io> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Signed-off-by: Christoph Muellner <christoph.muellner@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-01-02rockchip: rk3399-puma: Cleanup of vdd_log DTS entry.Christoph Muellner
This patch eliminates the non-standard entries "rockchip,pwm_id" and "rockchip,pwm_voltage". They are neither documented nor read out by any driver. Additionally it introduces the entry regulator-init-microvolt and sets it to 900 mV, which is the default target value for VDD_LOG. Signed-off-by: Christoph Muellner <christoph.muellner@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-01-01Merge tag 'u-boot-imx-20190101' of git://www.denx.de/git/u-boot-imxTom Rini
imx for 2019.01 - introduce support for i.MX8M - fix size limit for Vhybrid / pico boards - several board fixes - w1 driver for MX2x / MX5x
2019-01-01imx: add i.MX8MQ EVK supportPeng Fan
Add i.MX8MQ EVK support. SPL will initialize ddr and load ddr phy firmware. Then loading FIT image, ATF to OCRAM, U-Boot and DTB to DRAM. The boot log with Arm trusted firmware console enabled: " U-Boot SPL 2018.11-00142-g9ae14e7274 (Nov 20 2018 - 18:13:16 +0800) PMIC: PFUZE100 ID=0x10 Normal Boot Trying to boot from MMC2 NOTICE: Configureing TZASC380 NOTICE: BL31: v1.5(release):p9.0.0_1.0.0-beta-20180928-8-ge09c4b62-dirty NOTICE: BL31: Built : 09:28:54, Nov 8 2018 lpddr4 swffc start NOTICE: sip svc init U-Boot 2018.11-00142-g9ae14e7274 (Nov 20 2018 - 18:13:16 +0800) CPU: Freescale i.MX8MQ rev2.0 at 1000 MHz Reset cause: POR Model: Freescale i.MX8MQ EVK DRAM: 3 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial Net: Warning: ethernet@30be0000 using MAC address from ROM eth0: ethernet@30be0000 Hit any key to stop autoboot: 0 " Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-01-01ARM: DTS: Provide pinfunc definitions for vybrid vf610 from Linux kernelLukasz Majewski
This file is in sync with v4.20-next tree: e4dda4f5a4df "x86/kaslr, ACPI/NUMA: avoid including asm/kaslr.h on arm64" Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-01-01ARM: DTS: Add iomux node to vf.dtsi for Vybrid devicesLukasz Majewski
This node is in sync with v4.20-next tree: e4dda4f5a4df "x86/kaslr, ACPI/NUMA: avoid including asm/kaslr.h on arm64" Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-12-29ARM: uniphier: dts: sync with Linux 4.20Masahiro Yamada
Currently, the DWC3 USB node is out of sync because the bindings for the UniPhier DWC3 PHY diverged between Linux and U-Boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-19arm: dts: s400: Fix status for eMMC and SDIO portsNeil Armstrong
Under U-boot, the WiFi SDIO Module should be disabled and the eMMC modules should be enabled, so this patch adds an s400-u-boot.dtsi include file specific for U-Boot that will be included by the build system. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Jerome Brunet <jbrunet@baylibre.com>
2018-12-16Merge tag 'for-master-20181216' of git://git.denx.de/u-boot-rockchipTom Rini
Improvements and fixes or u-boot-rockchip: - new board: adds rv1108-elgin-r1 board support - rk3288-evb: dts: remove 'vmmc' from emmc node - rk3399-puma: dts: remove obsolete DTS node 'vcc5v0_host'
2018-12-16ARM: rockchip: Add rv1108-elgin-r1 board supportOtavio Salvador
Add the initial support for Elgin R1 board, which is based on the RV1108 SoC and has the following features currently supported in U-Boot: - UART - eMMC - USB Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-15Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
- Second half of the USB Gadget DM conversion
2018-12-15rockchip: rk3288-evb: dts: remove 'vmmc' from emmc nodeKever Yang
This is a sync with kernel mainline dts. The U-Boot eMMC does not need to care about the power for Rockchip SoCs, because if the board is using eMMC, the power will default on (for bootrom), so the 'vmmc', 'vqmmc' is only useful for SD in U-Boot. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-15rockchip: rk3399-puma: Remove obsolete DTS node 'vcc5v0_host'.Christoph Muellner
vcc5v0_host and usbhub_enable share gpio4 RK_PA3, which is a problem during probing (the second probe will trigger a -EBUSY, when trying to get the gpio handle). An analysis of the situation shows, that both regulators are actually describing the same supply. This patch removes the (currenlty not successful probing) regulator vcc5v0_host from the DTS and adds the pinctrl-* setting to usbhub_enable. Signed-off-by: Christoph Muellner <christoph.muellner@theobroma-systems.com> Reviewed-by: Phiilipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-15poplar: fix boot failure caused by serial driver changeShawn Guo
Commit 4687919684e0 ("serial: Remove DM_FLAG_PRE_RELOC flag in various drivers") essentially drops flag DM_FLAG_PRE_RELOC from serial_pl01x driver for Poplar platform, because the platform falls into the following strategy category made by the commit. Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Before the commit lands, Poplar platform works by statically declaring pl011 serial device via U_BOOT_DEVICE() with DM_FLAG_PRE_RELOC flag set in the driver. But since Poplar also supports device configuration from device tree, the commit practically drops the flag for Poplar, and hence breaks the platform from booting. This patch changes platform code and device tree to initiate pl011 serial device from device tree rather than static declaration, so that above strategy about DM_FLAG_PRE_RELOC applies to Poplar, and therefore the reported boot failure gets fixed. Reported-by: Igor Opaniuk <igor.opaniuk@linaro.org> Fixes: 4687919684e0 ("serial: Remove DM_FLAG_PRE_RELOC flag in various drivers") Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Igor Opaniuk <igor.opaniuk@linaro.org> Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-12-14dts: am4372: Enable USB1 in SPLJean-Jacques Hiblot
USB1 can be used by the romboot on all am4372 platforms to download a firmware (SPL in our case). It makes sense to enable USB1 in the SPL to download u-boot. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-14dts: Add a u-boot specific dtsi file for the am4372Jean-Jacques Hiblot
This file is used to override the values found in am4372.dtsi Use it to fix the "compatible" options for the controllers used to support the USB (parent bus and syscons). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-14ARM: dts: k2g-evm: enable USB0 and USB1Jean-Jacques Hiblot
2018-12-13dm: exynos: sound: Convert to use driver modelSimon Glass
Update snow's device tree and config to use driver model for sound. Also update the others as best we can. Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only boards that is tested and known to work are snow, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: sound: Add conversion to driver modelSimon Glass
Move the existing hardware drivers over to use driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: sound: exynos: Correct codec bus addressesSimon Glass
For snow the codec is at address 0x11 on the i2c bus, in 7-bit format. The device tree and code are in 8-bit format (i.e. shifted left one bit). Fix both. Fix pit in a similar way. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13snow: Expand U-Boot sizeSimon Glass
Now that we have EFI, etc. enabled, U-Boot is larger than it was. Expand the region allocated for it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-10Merge tag 'fsl-qoriq-for-v2019.01-rc2' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
Add TFA boot flow for some Layerscape platforms Add support for lx2160a SoC [trini: Add a bunch of missing MAINTAINERS entries] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-10Merge tag 'for-master-20181210' of git://git.denx.de/u-boot-rockchipTom Rini
Improvements: - init DRAM for RK322x in SPL - add FAN53555 PMIC/regulator driver - update MicroCrystal RV3029 driver to Kconfig and sync from Linux - add bootcount uclass and first DM-driver for bootcount
2018-12-10Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
- DM_I2C_COMPAT removal for all ti platforms from Jean-Jacques Hiblot - Fix in i2c command help output from Chirstoph Muellner.
2018-12-10Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
- DWC3 and UDC cleanup
2018-12-10rockchip: rk3399-puma: enable fan53555 regulators in DTSPhilipp Tomsich
Now that we have FAN53555 support, we can enable the regulators in our DTS. To make these easier to identify on the U-Boot commandline, we rename them to the names of the voltage rails they control. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-10dts: am43x: omap5: Add node for I2C in SPLJean-Jacques Hiblot
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-12-08arm: mvebu: helios4: Reset uSOM onboard phy during board initAditya Prayoga
Similar to Clearfog rev 2.1, GPIO 19 also used to reset onboard ethernet PHY. This patch depend on net: mvneta: Add GPIO configuration support [URL: https://patchwork.ozlabs.org/patch/1007736/] Signed-off-by: Aditya Prayoga <aditya@kobol.io> Reviewed-by: Stefan Roese <sr@denx.de> Tested-By: Dennis Gilmore <dgilmore@redhat.com> Reviewed-By: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08arm: mvebu: helios4: Enable SPI flash supportAditya Prayoga
Enable SPI flash support under U-Boot and SPL. The ENV size and offset, ported from U-Boot 2013.01 Marvell version: 2015_T1.0p16 To create U-Boot image for SPI flash, user would need to replace * CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC with CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI * CONFIG_ENV_IS_IN_MMC with CONFIG_ENV_IS_IN_SPI_FLASH Signed-off-by: Aditya Prayoga <aditya@kobol.io> Reviewed-by: Stefan Roese <sr@denx.de> Tested-By: Dennis Gilmore <dgilmore@redhat.com> Reviewed-By: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08arm: mvebu: helios4: Enable I2C and IO ExpanderAditya Prayoga
Enable Marvell I2C driver and I2C IO expander. Set default bus to external I2C bus. Define I2C aliases in device tree so it can be recognized by the driver. Signed-off-by: Aditya Prayoga <aditya@kobol.io> Reviewed-by: Stefan Roese <sr@denx.de> Tested-By: Dennis Gilmore <dgilmore@redhat.com> Reviewed-By: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-07dts: dra7x: make ocp2scp@4a080000 compatible with simple-busJean-Jacques Hiblot
This is required when DM_USB is used, to bind the USB phys. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-07arm: dts: am33xx: Sync dts with Linux 4.20.0Felix Brack
This patch synchronizes the am33xx SoC specific files with those from Linux 4.20.0. Hence all board maintainers of am33xx based boards are on the cc list. The main purpose of this patch is to prevent further diverging of the dts files from U-Boot and those from Linux. It aims to set the stage for the synchronization of board specific dts files. Example: I'm the maintainer of the PDU001 board: once this patch is applied successfully I will make changes to the board specific dts file in Linux only and then post a patch with a copy of this exact dts file to U-Boot. This will make U-Boot and Linux remain in sync. The stumbling block of https://patchwork.ozlabs.org/patch/943627 was removed by the patch https://patchwork.ozlabs.org/patch/962428 from Lokesh Vutla (many thanks!). This omap-serial driver allows using the Linux am33xx.dtsi file in U-Boot. Other changes to dts and dtsi files made by this patch are mainly to prevent _new_ warnings during the build process. Especially the warning at pinmux@800 stating 'unnecessary #address-cells/#size-cells without "ranges" or child "reg"' was not removed. This warning is a good example showing the benefit of the synchronization: if it needs to be fixed it will be fixed in Linux and ported back to U-Boot. Buildman reports all 46 am33xx SoC based boards to build fine, with warnings of course. Nevertheless this patch should be tested thoroughly on as many boards as possible to prevent any collateral damage. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-07ARM: DTS: da850-evm: Re-sync da850-evm.dts from Linux 4.20Adam Ford
There has been some natural evolution of the device tree, so resync with 4.20 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-07ARM: dts: da850-lcdk: Sync from Linux 4.20Adam Ford
Re-synce the device tree files from Linux 4.20 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-07ARM: DTS: da850: Sync from Linux 4.20Adam Ford
Re-sync with 4.20 due some some natural evolution. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-07ARM: DTS: Resync LogicPD-Torpedo-37xx-devkit with Linux 4.20Adam Ford
Migrate some small device tree fixes from Linux 4.20. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-07ARM: DTS: Resync LogicPD SOM-LV with Linux 4.20Adam Ford
There have been a few fixes to the device trees, so this re-syncs the dts/dtsi files with Linux Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-07ARM: DTS: Resync am3517-evm.dts with Linux 4.20Adam Ford
The DTS file for the AM3517 had the incorrect CD polarity. Resync with the fixed DTS file from Linux. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-07serial: bcm6858: remove driver and switch to bcm6345Álvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-12-07arm: am335x-pdu001: Enable CONFIG_BLK and CONFIG_DM_MMCFelix Brack
This patch enables CONFIG_BLK as well as CONFIG_DM_MMC for the PDU001 board. It depends on Patrice Chotard's patch 'power: regulator: denied disable on always-on regulator' which prevents power cycling the vmmc supply. Without this patch the board will not boot as vmmc is unfortunately used by other board components, not just eMMC and micro SD card. Furthermore my patch 'dts: am335x-pdu001: Fix polarity of card detection input' is required to boot from external micro SD card. Without this patch no SD card will be detected and hence booting will fail. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-07dts: am335x-pdu001: Fix polarity of card detection inputFelix Brack
When a micro SD card is inserted in the PDU001 card cage, the card detection switch is opened and the corresponding GPIO input is driven by a pull-up. Hence change the active level of the card detection input from low to high. Signed-off-by: Felix Brack <fb@ltec.ch>
2018-12-06pinctrl: stm32: make pinctrl use hwspinlockBenjamin Gaignard
Protect configuration registers with a hardware spinlock. If a hwspinlock is defined in the device-tree node used it to be sure that none of the others processors on the SoC could change the configuration at the same time. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2018-12-06hwspinlock: add stm32 hardware spinlock supportBenjamin Gaignard
Implement hardware spinlock support for STM32MP1. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2018-12-06armv8: lx2160a: Add LX2160A SoC SupportPriyanka Jain
LX2160A Soc is based on Layerscape Chassis Generation 3.2 architecture with features: 16 ARM v8 Cortex-A72 cores in 8 cluster, CCN508, SEC, 2 64-bit DDR4 memory controller, RGMII, 8 I2C controllers, 3 serdes modules, USB 3.0, SATA, 4 PL011 SBSA UARTs, 4 TZASC instances, etc. SoC personalites: LX2120A is SoC with Twelve 64-bit ARM v8 Cortex-A72 CPUs LX2080A is SoC with Eight 64-bit ARM v8 Cortex-A72 CPUs Signed-off-by: Bao Xiaowei <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-12-06armv8: dts: fsl-ls2080a: add sata node supportPeng Ma
One ls2080a, there is one SATA 3.0 advanced host controller interface which is a high-performance SATA solution that delivers comprehensive and fully-compliant generation 3 (1.5 Gb/s - 6.0 Gb/s) serial ATA capabilities, in accordance with the serial ATA revision 3.0 of Serial ATA International Organization. Add sata node to support this feature. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2018-12-06armv8: dts: fsl-ls1088a: add sata node supportPeng Ma
One ls1088a, there is one SATA 3.0 advanced host controller interface which is a high-performance SATA solution that delivers comprehensive and fully-compliant generation 3 (1.5 Gb/s - 6.0 Gb/s) serial ATA capabilities, in accordance with the serial ATA revision 3.0 of Serial ATA International Organization. Add sata node to support this feature. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2018-12-06armv8: dts: fsl-ls1046a: add sata node supportPeng Ma
One ls1046a, there is one SATA 3.0 advanced host controller interface which is a high-performance SATA solution that delivers comprehensive and fully-compliant generation 3 (1.5 Gb/s - 6.0 Gb/s) serial ATA capabilities, in accordance with the serial ATA revision 3.0 of Serial ATA International Organization. Add sata node to support this feature. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-12-06rockchip: rk3399: Add Ficus EE board supportManivannan Sadhasivam
Add board support for Ficus EE board from Vamrs. This board utilizes common Rock960 family support. Following peripherals are tested and known to work: * Gigabit Ethernet * USB 2.0 * MMC Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> [Reworked based on common Rock960 family support] Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-06rockchip: rk3399: Add Rock960 CE board supportManivannan Sadhasivam
Add board support for Rock960 CE board from Vamrs. This board utilizes common Rock960 family support. Following peripherals are tested and known to work: * USB 2.0 * MMC This commit also adds DDR configuration for LPDDR3-2GiB-1600MHz which is being used on the board. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-06rockchip: rk3399: Add common Rock960 family from VamrsManivannan Sadhasivam
Rock960 is a family of boards based on Rockchip RK3399 SoC from Vamrs. It consists of Rock960 (Consumer Edition) and Ficus (Enterprise Edition) 96Boards. Below are some of the key differences between both Rock960 and Ficus boards: 1. Different host enable GPIO for USB 2. Different power and reset GPIO for PCI-E 3. No Ethernet port on Rock960 The common board support will be utilized by both boards. The device tree has been organized in such a way that only the properties which differ between both boards are placed in the board specific dts and the reset of the nodes are placed in common dtsi file. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> [Added instructions for SD card boot] Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Peter Robinson <pbrobinson@gmail.com>
