path: root/arch/arm/dts
2019-07-09ARM: dts: colibri_vf: Add dcu0 nodeIgor Opaniuk
Add dumb node for NXP Display Control Unit0(DCU), which permits DM_ENABLED converted driver to be probed. Currently no display timings are provided in this node. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-09imx: imx8dx/qxp: enable thermalPeng Fan
Add thermal dts node Enable thermal in defconfig Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-07-05Merge tag 'rpi-next-2019.07' of https://github.com/mbgg/u-bootTom Rini
- fix complation error for CONFIG_USB - update RPi3 DTBs to v5.1-rc6 state - add defconfig for RPi3 B+ - Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
2019-07-04wandboard: Add FIT image supportFabio Estevam
After the transition to DM, only the mx6dl/solo wandboard is supported. Add FIT image support so that all the wandboard variants can be supported, like it was prior to the DM conversion. Successfully booted Linux on mx6q/solo/qp wandboards. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Add mmc0 aliasFabio Estevam
Add a mmc0 alias so that U-Boot proper can associate mmc0 with the boot SD card. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Import extra wandboard devicetree filesFabio Estevam
Import wandboard devicetree files so that the mx6q and mx6qp variants can be properly supported. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04wandboard: Sync with devicetree files from kernel 5.1.9Fabio Estevam
Udate the wandboard devicetree files with the ones from kernel 5.1.9. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04mx6: dts: Move dtbs under SoC levelFabio Estevam
Place dtbs under SoC level rather than board level. imx6q-novena.dtb and imx6dl-wandboard-revb1.dtb were placed under the board config option, so move them to SoC level. This also aligns with the kernel dts Makefile format. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-04mx6: dts: Keep dtb entries sortedFabio Estevam
Keep dtb entries sorted to help adding new dtbs in an organized form. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-07-02rockchip: dts: rk3288-tinker: enable sdmmc pinctrl node in splKever Yang
rockchip pinctrl driver has update to use dts, so we need to add the pinctrl config in SPL for sdmmc. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-02rockchip: dts: tinker: migrate the dm-pre-reloc tag into -u-boot dtsKever Yang
Migrate all the "u-boot,dm-pre-reloc" tag from rk3288-tinker.dts into rk3288-tinker-u-boot.dtsi. When both board level and soc level '-u-boot.dtsi' files exist, we need to include the soc level 'rk3288-u-boot.dtsi' manually. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-02rockchip: dts: rk3288: move reloc tag into -u-boot dtsKever Yang
Move all the tag "u-boot,dm-pre-reloc" from rk3288.dtsi into rk3288-u-boot.dtsi. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-02rockchip: dts: rk3399: rockpro64: Provide init voltageMark Kettenis
Add missing regulator-init-microvolt property to vdd_log regulator. Signed-off-by: Mark Kettenis <kettenis@openbsd.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> (Rebase on latest u-boot-rockchip master) Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Change-Id: I13b24fb81e8ad269d7dbb0c7b67f5f4795d2e775
2019-06-28Merge tag 'u-boot-imx-20190628' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx Fixes for 2019.07 - menlo board - allow SDB on Sabre - HAB for mx6sl - apalis board
2019-06-28Merge tag 'u-boot-stm32-20190628' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-stm STM32 MCU fixes/cleanup: - Fix SPL console for STM32F769 Discovery - Fix Memory Protection Unit size for STM32F4 series - Cleanup DT for STM32F746 Discovery
2019-06-28ARM: dts: stm32: Remove useless u-boot, dm-pre-reloc in ↵Patrice Chotard
stm32f746-disco-u-boot.dtsi As in stm32f7-u-boot.dtsi these nodes already have "u-bootdm-pre-reloc" property, no need to add them again in stm32f746-disco-u-boot.dtsi. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-06-28ARM: dts: stm32: Add u-boot, dm-pre-reloc for usart1_pins_a for stm32f769-discoPatrice Chotard
This allow to get console output in SPL for stm32f769-disco. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-06-27ARM: dts: imx: m53menlo: Import M53Menlo DT from LinuxMarek Vasut
Import iMX53 M53Menlo device tree from Linux next-20190607 3f310e51ceb1 . Enable DT control in full U-Boot . Add U-Boot extras into separate DTSi, the GPIO controllers need to be inited early, otherwise m53_set_clock() won't be able to detect the correct CPU clock frequency by reading the GPIO. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-27ARM: dts: imx: imx53: Synchronize iMX53 DT with LinuxMarek Vasut
Synchronize iMX53 device tree from Linux next-20190607 3f310e51ceb1 , this is needed to get NFC, UART, USBOTG DT nodes. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-26rockchip: rk3399: Move u-boot, dm-pre-reloc of uart0, uart2Jagan Teki
u-boot,dm-pre-reloc for uart0, uart2 indeed u-boot specific properties. Move them into rk3399-u-boot.dtsi so the boards which enabled these node will available during SPL. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26rockchip: dts: rk3328: add rk3328-rock64.dtsMatwey V. Kornilov
rk3328-rock64.dts has been taken from Linux kernel commit cff6d1d6f88b ("arm64: dts: rockchip: enable HS200 for eMMC on rock64") with minor modifications (drop nodes not known by rk3328.dtsi). Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-20Merge tag 'u-boot-stm32-20190619' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-stm - Update STM32MP entry in MAINTAINERS - Handle correctly binding for g-tx-fifo-size for USB DWC2 driver - Fix trusted STM32MP1 defconfig with correct ethernet driver
2019-06-19ARM: dts: stm32mp1: remove override for g-tx-fifo-sizePatrick Delaunay
Remove the override for usbotg_hs on g-tx-fifo-size as the correct binding, used in the kernel device tree, is now supported in dwc2 device driver. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-06-19armv8: ls1046afrwy: Add support for LS1046AFRWY platformVabhav Sharma
LS1046AFRWY board supports LS1046A family SoCs. This patch add base support for this board. Board support's 4GB ddr memory, i2c, micro-click module,microSD card, serial console,qspi nor flash,ifc nand flash,qsgmii network interface, usb 3.0 and serdes interface to support two x1gen3 pcie interface. Signed-off-by: Camelia Groza <camelia.groza@nxp.com> Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19arm: ls1028a: define the integrated PCI bus (ECAM)Alex Marginean
LS1028A includes an integrated PCI bus with 11 PCI functions residing on bus 0. ECAM plus the device register space takes up 256MB of address space. Signed-off-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19ARM: dts: ls1021a: Fixed reg for sata nodePeng Ma
This patch is to fixed the reg read to "0" for armv7 architecture. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: lx2160aqds: Enable eSDHC controllersYinbo Zhu
This patch is to enable esdhc controllers for lx2160aqds Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls1028a: Add ecc address node for sata.Peng Ma
Move the ecc addr from driver to dts Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: lx2160aqds: Enable sataPeng Ma
Change sata node status to enable sata. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-14arm: dts: Stratix10: Enable i2cLey Foon Tan
Enable i2c1 in Stratix 10 devkit. SOCFPGA_STRATIX10 # i2c bus Bus 0: i2c@ffc02900 SOCFPGA_STRATIX10 # i2c dev 0 Setting bus to 0 SOCFPGA_STRATIX10 # i2c probe Valid chip addresses: 14 4C 51 68 74 Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-06-12fdt: update bcm283x device tree sources to Linux 5.1-rc6 stateHeinrich Schuchardt
Updating the bcm283x device tree sources adds the device trees for - Raspberry Pi 3 Model A+ - Raspberry Pi 3 Model B+ - Raspberry Pi Compute Module IO board rev1 - Raspberry Pi Compute Module 3 IO board V3.0 - Raspberry Pi Zero Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-06-11Merge tag 'u-boot-stm32-20190606' of https://github.com/pchotard/u-bootTom Rini
- Add Ethernet support for STM32MP1 - Add saveenv support for STM32MP1 - Add STM32MP1 Avenger96 board support - Add SPI driver suport for STM32MP1 - Add watchdog support for STM32MP1 - Update power supply check via USB TYPE-C for STM32MP1 discovery board
2019-06-11Merge tag 'u-boot-imx-20190612' of git://git.denx.de/u-boot-imxTom Rini
u-boot-imx-20190612 -------------------- - Board fixes: - imx6logic - wandboard - mx6sabre boots again - imx8qm_mek - pico-* boards - Toradex apalis / colibri - engicam imx6 (environment) - KP MX53 - opos6ul - Switch to DM: - vining2000 - dh MX6 - Toradex colibri i.MX7 - Novena - Security : fix CSF size for HAB - Other: - imx: fix building for i.mx8 without spl - pcie and switch to DM mx6sabreauto: Enable SPL SDP support
2019-06-11arm: dts: imx6qdl-u-boot: Alias usb0 to usbotgSjoerd Simons
All i.mx6 boards seems to have moved to DM_USB, however gadget support for mx6 is still pre-DM as CI_UDC isn't converted yet. To make this work the usb otg controller used for gadgets needs to be usb number 0. Add an alias for this directly in the main u-boot mx6qdl dtsi so it doesn't need to be done for each board separately. This fixes regressions wrt. usb gadget functionality in several boards that have gadget functions enabled in their config, but no usb0 alias in their device-tree. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2019-06-11ARM: imx: vining2000: Convert MMC and block to DMMarek Vasut
Enable DM block and DM MMC support on iMX6SX VINING|2000 . Convert board code to match the DM support. This disables USB mass storage support due to missing DM USB, however that will be re-enabled in subsequent patch. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: dts: imx: vining2000: Import VINING|2000 DT from LinuxMarek Vasut
Import iMX6SX VINING|2000 device tree from Linux 5.1.1 b724e9356404 . Enable DT control in full U-Boot . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11imx: Extend PCL063 support for phyCORE-i.MX6ULL SOMParthiban Nallathambi
Extend PHYTEC phyBOARD-i.MX6UL for phyCORE-i.MX6UL SoM (PCL063) with eMMC on SoM. CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 38C Reset cause: POR Model: Phytec phyBOARD-i.MX6ULL-Segin SBC Board: PHYTEC phyCORE-i.MX6ULL DRAM: 256 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0 Working: - Eth0 - i2C - MMC/SD - eMMC - UART (1 & 5) - USB (host & otg) Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-06-11board: toradex: add apalis imx8qm 4gb wb it v1.0b module supportMarcel Ziswiler
This commit adds initial support for the Toradex Apalis iMX8QM 4GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0. Functionality wise the following is known to be working: - eMMC, 8-bit and 4-bit MMC/SD card slots - Gigabit Ethernet - GPIOs - I2C Unfortunately, there is no USB functionality for the i.MX 8QM as of yet. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11arm: dts: imx8qm: add support for i2c0, i2c1, i2c2, i2c3 and i2c4Marcel Ziswiler
Add support for i2c0, i2c1, i2c2, i2c3 and i2c4. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11arm: dts: imx8qm: add lpuart1, lpuart2, lpuart3, lpuart4Marcel Ziswiler
Add support for lpuart1, lpuart2, lpuart3 and lpuart4. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11ARM: imx: novena: Convert block devices to DMMarek Vasut
Enable DM block, DM MMC and DM SATA support on iMX6Q Novena convert board code to match the DM support. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: dts: imx: novena: Import Novena DT from LinuxMarek Vasut
Import iMX6Q Novena device tree from Linux 5.1-rc7 37624b58542f . Enable DT control in full U-Boot . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-11ARM: dts: imx: dh-imx6: Fix SPI CS polarity on DHCOM iMX6 PDK2Marek Vasut
The SPI nCS signal is active low, make it so. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11ARM: dts: imx: dh-imx6: Import DHCOM iMX6 PDK2 DTs from LinuxMarek Vasut
Import DHCOM iMX6 PDK2 device tree from Linux 5.1.1 b724e9356404 . Enable DT control in full U-Boot . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11colibri-imx6ull: fix usb host modeMarcel Ziswiler
This fixes an issue with USB host mode. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11colibri_imx7: migrate usb to driver modelIgor Opaniuk
Migrate USB to Driver Model (CONFIG_DM_USB=y). Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11apalis_imx6: add device tree to makefileMarcel Ziswiler
Add device tree to Makefile to avoid newly introduced error: Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument make[1]: *** [dts/Makefile:28: arch/arm/dts/imx6-apalis.dtb] Error 1 make: *** [Makefile:1009: dts/dt.dtb] Error 2 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-11ARM: dts: i.MX6ULL: U-Boot specific dts for u-boot, dm-splParthiban Nallathambi
u-boot,dm-spl property is specific to U-Boot, so created one for i.MX6ULL platforms. Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-06-11board: toradex: add colibri imx8qxp 2gb wb it v1.0b module supportMarcel Ziswiler
This commit adds initial support for the Toradex Colibri iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0. Functionality wise the following is known to be working: - eMMC and MMC/SD card - Ethernet - GPIOs - I2C Unfortunately, there is no USB functionality for the i.MX 8QXP as of yet. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-10Merge tag 'video-updates-for-2019.07-rc3' of git://git.denx.de/u-boot-videoTom Rini
- mxsfb DM_VIDEO conversion - splash fix for DM_VIDEO configurations - meson HDMI fix for boards without hdmi-supply regulator
