This converts all Tegra boards over to use driver model for I2C. The driver
is adjusted to use driver model and the following obsolete CONFIGs are
removed:
- CONFIG_SYS_I2C_INIT_BOARD
- CONFIG_I2C_MULTI_BUS
- CONFIG_SYS_MAX_I2C_BUS
- CONFIG_SYS_I2C_SPEED
- CONFIG_SYS_I2C
This has been tested on:
- trimslice (no I2C)
- beaver
- Jetson-TK1
It has not been tested on Tegra 114 as I don't have that board.
Acked-by: Heiko Schocher <hs@denx.de>
Nyan-big is a Tegra124 clamshell board that is very similar to venice2, but
it has a different panel, the sdcard cd and wp sense are flipped, and it has
a different revision of the AS3722 PMIC.
This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, NVIDIA
Tegra K1, 2GB). The display is not currently supported, so it should
boot on other nyan-based Chromebooks also, but only the device tree for
nyan-big is provided here.
The device tree file is from Linux but with features removed which are
unlikely to be supported in U-Boot soon (regulators, pinmux). Also the
addresses are updated to 32-bit.
Signed-off-by: Allen Martin <amartin@nvidia.com>
(rebase, change to 'nyan-big', fix pinmux that resets nyan-big)
Sync this up with Linux v3.18-rc5. Exclude features that are unlikely to
supported in U-Boot soon (regulators, pinmux). Also the addresses are
updated to 32-bit. Otherwise it is the same. Also bring in the dt-bindings
for pinctrl.
This will be used by nyan-big, but bring it in in a separate patch since it
will be common to other boards.
Add I2C controller and NAND controller devices. Fix indentation too.
If CONFIG_OF_CONTROL is defined, search device tree nodes that are
compatible with "panasonic,uniphier-ehci" and take the base address
from their "reg" property.
This commit implements the ofdata_to_platdata handler for the UniPhier
serial driver and adds serial device nodes to the device tree sources.
This commit adds basic device tree sources for UniPhier SoCs/boards.
This change adds support for enabling the USB host features of the board.
This includes the USB3503A hub and the SMC LAN9730 ethernet controller
as well.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
The current vbus GPIOs on snow make very little sense, their number is
far above the maximum. As a result, USB doesn't work on snow.
Correct the GPIO numbering so they match the current scheme for exynos5.
Tested both EHCI and XHCI to correctly work after this change.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
We have a new board Peach-Pi similar to Peach-Pit. Peach-Pi
differs from Peach-Pit in configuration factors like display
resolution, memory size, SoC version etc.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
It's a Zynq board similar in design to the currently supported ones.
512MB of RAM and UART1 is used.
Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com>
Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This patch includes the latest DT sources for socfpga from the current
Linux kernel. And enables CONFIG_OF_CONTROL for the new build target
"socfpga_socrates" (the EBV SoCrates board) to make use of this new DT
support.
Until this patch, the only SoCFPGA U-Boot target in mainline is
"socfpga_cyclone5". This build target is not (yet) changed to support
DT. So nothing changes for this target. Even though the long-term
goal should be to move all SoCFPGA targets over to DT.
One of the reasons to enable DT support in SoCFPGA is, that I need to
support multiple different SPI controllers for this platform. This is
the QSPI Cadence controller and the Designware SPI master controller.
Both are implemented in the SoCFPGA. And enabling both controllers is
only possible by using the new driver model (DM). The DM SPI code
only supports DT based probing. So it was easier to move SoCFPGA to
DT than to add the (deprecated) platform-data based probing to the
DM SPI suport.
Note that the image with the dtb embedded is u-boot-dtb.img. This needs
to be used now for those DT enabled boards instead of u-boot.img.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Vince Bridgers <vbridger@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Pavel Machek <pavel@denx.de>
Add a driver for the designware serial UART used on sunxi. This just
redirects to the normal ns16550 driver.
Add a stdout-path to the device tree so that the correct UART is chosen.
For now we won't want to mess with the existing configurations. Create a
new one which will enable device tree and driver model. Note that this
brings the device tree binary into u-boot-sunxi-with-spl.bin.
These are from Linux 3.17-rc7 (commit fe82dcec). U-Boot only uses a small
portion of these, but we may as well have something to look forward to.
The total compiled size is about 25KB.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Odroid is based on Exynos4412.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
There is no gaps in exynos gpio enum after rework, so the gpio
numbers should be adjusted to the new numbering.
The gpy0 don't need any additional register offset,
but the gpx0 does, so now it is fixed.
The gpf0 offset was bad and it's now fixed.
After fix gpio order in *pinctrl.dts , the gpy0 offset is not required now.
The pinctrl dts was imported from the kernel, but the order
of GPM and GPY is wrong. The gpio enum in: asm/arch/gpio.h
is proper.
These ended up in arch/arm/dts/dt-bindings temporarily, but in fact the
correct place is now include/dt-bindings. Move them to be consistent.
Select serial0 as the console.
Acked-by: Tom Rini <trini@ti.com>
All boards with a SPI interface have a suitable spi alias except the tegra30
boards. Add these missing aliases.
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Adjust this board to use the driver model soft_spi implementation.
Move the exynos SPI driver over to driver model. This removes quite a bit
of boilerplate from the driver, although it adds some for driver model.
A few device tree additions are needed to make the SPI flash available.
We will need the console before relocation, so mark it that way.
These describe the GPIOs in enough detail for U-Boot's GPIO driver to
operate.
operate.
The pinctrl bindings used by Linux are an incomplete description of the
hardware. It is possible in most cases to determine the register address
of each, but not in all cases. By adding an additional property we can
fix this, and avoid adding a table to U-Boot for every single Exynos
SOC.
We don't include the pinctrl functions for U-Boot as they use up quite
a bit of space and are not used.
We could instead perhaps eliminate this material with fdtgrep, but so far
this tool has not made it to upstream.
Bring in required device tree files for pinctrl from Linux v3.14. These
are initially unchanged and have a number of pieces not needed by U-Boot.
Note that exynos5420 is renamed to exynos54xx here since we want to
support exynos5422 also.
We should be consistent about this. The kernel has moved to #include
which breaks error reporting to some extent but does allow us to include
binding files.
Update Apalis T30 as per the following commits
c369139234c03b1494394d12cd27009f47aa6606
tegra: dts: Add serial port details
461be2f96e4b87e5065208c6659a47dd0ad9e9f8
kconfig: remove redundant "string" type in arch and board Kconfigs
f1ef2b62339526df3b921bcfefd174ce76d4c624
kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfig
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add missing chosen stdout-path device tree node. This got missed by
commit
This patch adds board support for the Toradex Apalis T30 a computer on
module which can be used on different carrier boards.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot and environment storage
- Gigabit Ethernet (once Thierry's PCIe as well as my E1000 resp. i210
fixes hit mainline)
- MMC/SD cards (both 8-bit as well as 4-bit slot)
- USB client/host (dual role port as client e.g. for DFU/UMS, other two
ports as host)
Change this board to add a device tree.
This also adds a pinmux header file although it is not used as yet.
Most of the smdkv310 features are common with other exynos4 boards. To
permit easier addition of driver model support, use the common file and
add a device tree file.
Add a keyboard definition so that the keyboard can be used on pit.
The device seems to hang in SPL if the full speed is used when booting from
USB, perhaps because the PMIC has not been set to the maximum ARM core
voltage yet. Slow it down to a reliable speed.
