Trivial change for all files I have touched recently.
Enable gpio driver on these boards. GPIOs can be used on any board.
This patch add ethernet node gem1 to zcu1275 RevB.
GMII to RGMII converter sits between MAC and external
phy connected over GMII to MAC and RGMMI to external phy.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
s/xlnx,mio_bank/xlnx,mio-bank/g
DT binding is describing mio-bank not mio_bank that's why fix all DTSes and
also driver itself.
Acked-by: Peng Fan <peng.fan@nxp.com>
Node name should be <name>@<address> which is not how partitions are
described.
Issue was found by running dtbs_check as:
flash@0: 'partition@qspi-device-tree', 'partition@qspi-fsbl-uboot',
'partition@qspi-linux', 'partition@qspi-rootfs'
do not match any of the regexes: ...
Trivial change.
Removed no-1-8-v property from zynqmp sdhci devicetree nodes to
allow UHS-I capable SD cards to work in SD3.0 UHS modes.
Boards that does not have level shifter for SD, does not support 1.8v.
so no-1-8-v property to sdhci dt nodes should be present in zcu102 Rev-A,B,
zcu104 Rev-A,C, zcu100, zcu1275 Rev-B boards.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Name of this platform has changed and released to customers that's why
name has also changed.
Series-to: uboot
