path: root/arch/arm/dts/zynqmp-zcu102.dts
2016-11-15ARM64: zynqmp: change sdhci compatible string.Sai Krishna Potthuri
This patch changes the compatible string for sdhci node, adds "xlnx,device_id" and "xlnx,mio_bank" property to sdhci node. Signed-off-by: Sai Krishna Potthuri <lakshmis@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM64: zynqmp: Remove note about level shifter on zcu102Michal Simek
i2c device is just level shifter. Remove reference from dts. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM64: zynqmp: Add dcc port to dtsiMichal Simek
Add dcc to dtsi for supporting system without serial port. DCC is enabled by default on ZynqMP. Adding dcc to zcu100 and zcu102 which were tested. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM64: zynqmp: Add gpio-keys for zcu102Michal Simek
There is gpio push button on MIO22. Add it to DTS to have full board description. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM64: zynqmp: Enable gpio-led as heartbeat on zcu102Michal Simek
Show user that Linux is alive on the board. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM64: zynqmp: Remove DTC 1.4.2 warningsMichal Simek
DTC 1.4.2 reports these warnings: Warning (unit_address_vs_reg): Node /amba_apu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /amba has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /amba/usb@fe200000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/usb@fe300000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-video0channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-video1channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-video2channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-graphicschannel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-audio0channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-audio1channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name This patch is fixing them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Add support for ZCU102 platformMichal Simek
Add new board support. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
