The node names should be generic and DT schema expects certain pattern
(e.g. with key/button/switch).
It is based on kernel commit (228e8a88b1915a2b467c83d8d0976605f1272fae).
Signed-off-by: Michal Simek <michal.simek@amd.com>
Link: https://lore.kernel.org/r/ae23999097553acb21dfca9288a913bb8b24587a.1670590595.git.michal.simek@amd.com
With ethernet-phy-id driver ETH phy reset can be properly handle that's why
describe it in DT.
Link: https://lore.kernel.org/r/5bfd92827033d19617113f4117f37dcf79699a0f.1662721547.git.michal.simek@amd.com
TI DP83867 is using strapping based on MIO pins. Tristate setup can influce
PHY address. That's why switch description with ethernet-phy-id compatible
string which enable calling reset. PHY itself setups phy address after
power up or reset. Reset description will be added in separate commit.
Link: https://lore.kernel.org/r/52bf9ac0453d4e4896d8edd2618e684bb1ff6012.1662721547.git.michal.simek@amd.com
As per design, all input/rx pins should have fast slew rate and 12mA
drive strength. Rest all pins should be slow slew rate and 4mA drive
strength. Fix usb nodes as per this and remove setting of slow slew rate
for all the usb gorup pins.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Link: https://lore.kernel.org/r/b245c165f05845c1f3ab41a92c82b7ec1538cee4.1655288171.git.michal.simek@amd.com
Origin DT binding just specify driver but wasn't aligned with DT binding
which came later. Extend description for zcu102 and zcu106 to cover latest
binding.
Link: https://lore.kernel.org/r/db66a4bb501183ffbd033da4dd263afdb214f8ec.1652262769.git.michal.simek@amd.com
In all the ZynqMP boards dts files tx-buswidth is by default set to 1. Due
to this the framework only issues 1-1-1 write commands to the GQSPI driver.
But the GQSPI controller is capable of handling 1-4-4 write commands, so
updated the tx-buswidth to 4 in ZynqMP boards dts files. This would enable
the spi-nor framework to issue 1-4-4 write commands instead of 1-1-1. This
will increase the tx data transfer rate, as now the tx data will be
transferred on four lines instead on single line.
Signed-off-by: Amit Kumar Mahapatra <amit.kumar-mahapatra@xilinx.com>
Link: https://lore.kernel.org/r/ad61199f55e5e00f29de6206d9d1872a52a7657e.1652193179.git.michal.simek@amd.com
Move the PHY properties from DWC3 node to USB node in ZynqMP DTs as here
the USB3 PHY used is PSGTR, which is connected to Xilinx USB core. This
PHY initialization should be handled from Xilinx USB core as the
prerequisite register configurations are done here only.
Signed-off-by: Manish Narani <manish.narani@xilinx.com>
It is not recommended to have aliases for gpio. In past it was used in
Linux for assigning numbers via sysfs which is deprecated and libgpiod
should be used instead.
In U-Boot this number is used for seq number but gpio offset are not
counted from this number. That's why having these aliases only for seq
number is not needed. As is done in Linux it is the best to use full gpio
name instead of sequence number which depends on sequence in binding.
There are no drivers for these devices that's why remove that nodes
completely. This change is done based on Linux kernel.
Link: https://lore.kernel.org/r/20210308115437.2232847-1-quanyang.wang@windriver.com
Convert all boards to use nvmem alias instead of xlnx,eeprom. The change is
done based on discussion in the link below.
Link: https://lore.kernel.org/r/CAL_JsqLMDqpkyg-Q7mUfw-XH67-v068Q6e9wTq2UOoN=0-_coQ@mail.gmail.com
Trivial change for all files I have touched recently.
Mainline kernel has psgtr driver that's why it is good to add description
to DT files. Some boards are just missing description for USB3 and sata.
zc1751-dc1 and p-a2197 are also missing clock descriptions for input
clocks.
ZynqMP pinctrl Linux driver has been merged to 5.13-rc1 kernel. Based on it
DT files can be extended by pinctrl configurations.
There are several changes which happen in mainline kernel which should get
also to U-Boot. Here is the list of patches from the kernel:
- ARM: zynq: Fix leds subnode name for zc702/zybo-z7
- arm64: dts: zynqmp: Fix leds subnode name for zcu100/ultra96 v1
- arm64: dts: zynqmp: Fix u48 si5382 chip on zcu111
- arm64: dts: zynqmp: Wire up the DisplayPort subsystem
- arm64: dts: zynqmp: Add DisplayPort subsystem
- arm64: dts: zynqmp: Add DPDMA node
- arm64: dts: zynqmp: Enable phy driver for Sata on zcu102/zcu104/zcu106
- arm64: dts: zynqmp: Enable si5341 driver for zcu102/106/111
- arm64: dts: zynqmp: Add DT description for si5328 for zcu102/zcu106
- arm64: dts: zynqmp-zcu100-revC: correct interrupt flags
- arm64: dts: xilinx: align GPIO hog names with dtschema
- arm64: zynqmp: Add Xilinx AES node
- dt: bindings: dma: xilinx: dpdma: DT bindings for Xilinx DPDMA
but also some other changes have been done.
- Using only one compatible string for adxl345 on zturn
- Remove Xilinx internal DP bindings
- Remove USB3.0 serdes configurations
- Remove SATA serdes configuration for zc1232
- Resort nvmem_firmware
- Update nand compatible string
- Aling power-domains property for sd0/1
s/xlnx,mio_bank/xlnx,mio-bank/g
DT binding is describing mio-bank not mio_bank that's why fix all DTSes and
also driver itself.
Acked-by: Peng Fan <peng.fan@nxp.com>
Node name should be <name>@<address> which is not how partitions are
described.
Issue was found by running dtbs_check as:
flash@0: 'partition@qspi-device-tree', 'partition@qspi-fsbl-uboot',
'partition@qspi-linux', 'partition@qspi-rootfs'
do not match any of the regexes: ...
Sync DP subsystem with the latest state in Xilinx U-Boot repository.
This binding hasn't been approved in mainline Linux but it is much better
than ancient version which this patch removes.
Modify dts files to add 'no-1-8-v' property for all the ZynqMP boards.
User can remove this property to enable the UHS mode. This is to keep
the same speed (HS) modes across all the stages of the Linux Boot. Due
to power cycling limitation of some of the ZynqMP boards, some SD cards
don't get power cycled and are failing in Linux.
Trivial change.
Most of the legacy "gpio-key,wakeup" boolean property is already
replaced with "wakeup-source". However few occurrences of old property
has popped up again, probably from the remnants in downstream trees.
This patch replaces the legacy properties with the unified
"wakeup-source" property introduced by:
"Input: gpio_keys - switch to using generic device properties"
(sha1: 700a38b27eefc582099fdf69effacfad0ad738a4)
Cc: Michal Simek <michal.simek@xilinx.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
s/_/-/ for node names.
It fixes warnings like this:
... Warning (node_name_chars_strict): /cpu_opp_table:
Character '_' not recommended in node name ...
Issues reported by make dtbs W=12
Label gpio lines properly.
Label property is adding capability to distiguish chips from each other
when iio framework is used.
ina226 hwmon driver is deprecated and it is recommended to use new iio
based driver. The patch is enabling iio-hwmon driver to export
functionality from IIO to hwmon interface to be able to use lm-sensors
package.
Add gpio phy reset via I2C expander TCA6416 on board ZCU102.
A warning call trace is observer in probe when this reset is called
from context that can sleep. Keep this commented until that is
resolved in phylib.
Signed-off-by: Harini Katakam <harini.katakam@xilinx.com>
The DP83867 strap control workaround is already present in Linux kernel
mainline binding. All these Xilinx boards require this quirk.
Ethernet phys based on devicetree specification should be using
ethernet-phy@ node name instead of pure phy@.
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot
dts files. This compatible has been added in sf_probe, let use it.
This patch switches to jedec,spi-nor when spi-flash is used in the DTS
and DTSI files, and removed spi-flash when jedec,spi-nor is already
present.
The x86 dts are switched in a separate commit since it depends on a change
in fdtdec.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Fix the below warning as the core looks for the compatible
string.
[ 5.198919] i2c i2c-18: of_i2c: modalias failure on
/amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@19
[ 5.207454] i2c i2c-18: Failed to create I2C device for
[ 5.216394] i2c i2c-18: of_i2c: modalias failure on
/amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@30
[ 5.224986] i2c i2c-18: Failed to create I2C device for
[ 5.233927] i2c i2c-18: of_i2c: modalias failure on
/amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@35
[ 5.242527] i2c i2c-18: Failed to create I2C device for
[ 5.263880] i2c i2c-18: of_i2c: modalias failure on
/amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@36
[ 5.272477] i2c i2c-18: Failed to create I2C device for
[ 5.281415] i2c i2c-18: of_i2c: modalias failure on
/amba/i2c@ff030000/i2c-mux@75/i2c@3/dev@51
[ 5.290008] i2c i2c-18: Failed to create I2C device for
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com>
Trivial fix.
CONFIG_PCA953X is not needed because of PCA953X is integrated in gpio
subsystem already. That's why also remove CMD_PCA953X which is only for
this driver.
zcu102/zcu104-revC/zcu106/zcu111 contain links to eeprom which stores MAC address.
DM_I2C is not enabled for the whole SoC because it increase size for
mini configurations and there is no I2C symbol present to setup
dependencies.
If there are more instances of si570 clock-output-names property
should be used for differentiation of clock output.
The patch is adding this optional properties for all zynqmp boards with
si570 chip.
This patch adds qspi driver support for all ZynqMP ZCU102
boards.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
dtc is showing some warnings and this change was also done in
the Linux kernel as "Input: gpio-keys - clean up device tree binding
example"
with this fragment in commit message
"Drop #address-cells and #size-cells, which are not required by the
gpio-keys binding documentation, as button sub-nodes are not devices."
This part hasn't been pushed to mainline yet that's why remove it.
The patch can be reverted in future when this is pushed there.
Reported-by: Alexander Graf <agraf@suse.de>
Reviewed-by: Alexander Graf <agraf@suse.de>
Add vendor prefix to si5341.
There shouldn't be a number appended based on spec.
U-Boot commands shouldn't be the part of kernel DTS files.
This changes was done in mainline and this patch is just following it.
Instead of hardcoding numbers.
Remove additional comments which were removed as the part of upstreaming.
Mainline Linux kernel has adopted SPDX header license in a different
format then was used before. This patch is syncing it up.
Also update years in License text and remove Nathalie's email because it
is no longer valid.
Based on review from mainline i2c-mux is standard name for i2c switches.
Use vendor prefix for Maxim chips.
Use zynqmp clock driver instead of fixed clocks.
Remove overfetch, ratectrl, include-sg and src-issue dma properties.
Driver is not using them and they are also not documented in the binding
doc.
Acked-by: Kedareswara rao Appana <appanad@xilinx.com>
Enable USB3.0 and SATA phy for zcu102 boards.
Enable watchdog in dts for zcu102.
Add comment about irq present on the board connected to PL.
The AMS includes an ADC as well as on-chip sensors that can be used to
sample external voltages and monitor on-die operating conditions, such as
temperature and supply voltage levels.
Signed-off-by: Rajnikant Bhojani <rajnikant.bhojani@xilinx.com>
