path: root/arch/arm/dts/zynqmp-zcu102-rev1.0.dts
2019-10-24arm64: zynqmp: dt: Delete no-1-8-v property from zcu102-rev1.0T Karthik Reddy
Currently zcu102 Rev1.0 board includes RevA sdhci dt node which has no-1-8-v property. Since Rev1.0 has level shifters delete this property to enable support for 1.8v. Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Remove double spaces from dts fileMichal Simek
There is no reason to have double spaces for indentation. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Use s/_/-/g in node name for zcu102 rev1.0Michal Simek
Follow spec for node names. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Sync up license with mainline kernelMichal Simek
Mainline Linux kernel has adopted SPDX header license in a different format then was used before. This patch is syncing it up. Also update years in License text and remove Nathalie's email because it is no longer valid. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm64: zynqmp: Add support for zcu102 1.0 revMichal Simek
1.0 rev is the latest rev. Describe information in eeprom. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
