path: root/arch/arm/dts/zynqmp-zc1232-revA.dts
2020-04-06arm64: zynqmp: Fix addresses in partition definitionsMichal Simek
Node name should be <name>@<address> which is not how partitions are described. Issue was found by running dtbs_check as: flash@0: 'partition@qspi-device-tree', 'partition@qspi-fsbl-uboot', 'partition@qspi-linux', 'partition@qspi-rootfs' do not match any of the regexes: ... Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-06arm64: zynqmp: Update Copyright years to 2020Michal Simek
Trivial change. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-11-29arm64: zynqmp: Wire spi-flash compatible string with flashesMichal Simek
Enable reading tx and rx buswidth from DT via spi-uclass. To get these from uclass spi-flash compatible string has to be added to flash node. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm64: zynqmp: Add support for zc12xx boardsMichal Simek
Add support for zc12xx boards. All of them are internal boards for silicon validation and share very similar base platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
