dp_aclk is not used anywhere that's why remove it.
There are several changes which happen in mainline kernel which should get
also to U-Boot. Here is the list of patches from the kernel:
- ARM: zynq: Fix leds subnode name for zc702/zybo-z7
- arm64: dts: zynqmp: Fix leds subnode name for zcu100/ultra96 v1
- arm64: dts: zynqmp: Fix u48 si5382 chip on zcu111
- arm64: dts: zynqmp: Wire up the DisplayPort subsystem
- arm64: dts: zynqmp: Add DisplayPort subsystem
- arm64: dts: zynqmp: Add DPDMA node
- arm64: dts: zynqmp: Enable phy driver for Sata on zcu102/zcu104/zcu106
- arm64: dts: zynqmp: Enable si5341 driver for zcu102/106/111
- arm64: dts: zynqmp: Add DT description for si5328 for zcu102/zcu106
- arm64: dts: zynqmp-zcu100-revC: correct interrupt flags
- arm64: dts: xilinx: align GPIO hog names with dtschema
- arm64: zynqmp: Add Xilinx AES node
- dt: bindings: dma: xilinx: dpdma: DT bindings for Xilinx DPDMA
but also some other changes have been done.
- Using only one compatible string for adxl345 on zturn
- Remove Xilinx internal DP bindings
- Remove USB3.0 serdes configurations
- Remove SATA serdes configuration for zc1232
- Resort nvmem_firmware
- Update nand compatible string
- Aling power-domains property for sd0/1
Sync DP subsystem with the latest state in Xilinx U-Boot repository.
This binding hasn't been approved in mainline Linux but it is much better
than ancient version which this patch removes.
Sync zynqmp fpga manager with mainline.
Signed-off-by: Nava kishore Manne <nava.manne@xilinx.com>
Trivial change.
Just fixing indentation and update year in Copyright.
There are use cases where lpd watchdog can be configured for APU use. By
design this IP should be listed in zynqmp.dtsi to make sure that node is
properly enabled by DTG.
Use prepared header instead of hardcoded values.
PS clock(LPD_APB_CLK) is default clock for TTC. Add this clock
entry in TTC nodes.
Signed-off-by: Rajan Vaja <rajan.vaja@xilinx.com>
Mainline Linux kernel has adopted SPDX header license in a different
format then was used before. This patch is syncing it up.
Also update years in License text and remove Nathalie's email because it
is no longer valid.
Use zynqmp clock driver instead of fixed clocks.
