path: root/arch/arm/dts/zynq-zybo.dts
2019-02-15ARM: dts: zynq: correct and improve the model property of dt filesLuis Araneda
Replace the current value of the model property by a more accurate description of each board (which includes the manufacturer), as some of the boards had the same value ("Xilinx Zynq") Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm: zynq: Sync up licenses with mainline kernelMichal Simek
Use different location for SPDX line. Also update dates for new mainline DTS files. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Sync location of DT properties with LinuxMichal Simek
This is trival change which only ensures the same location with Linux kernel. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Add device-type property for zynq ethernet phy nodesSai Pavan Boddu
Mention device-type = "ethernet-phy", as qemu will need this in absence of compatible. Signed-off-by: Sai Pavan Boddu <saipava@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM: zynq: Remove DTC 1.4.2 warningsMichal Simek
DTC 1.4.2 reports these warnings: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property This patch is fixing them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Fix usb phy node for ZyboMichal Simek
Compatible property should be the first. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Align spi and qspi node locationsMichal Simek
Keep nodes alphabelitally sorted. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
2016-04-13ARM: zynq: Fix bootargs in board dtsiMichal Simek
- Sync with Linux kernel - Remove rootfs - Remove earlyprintk Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-02-22ARM: zynq: Add reset-gpio property for USB on ZyboMichal Simek
DTS syncup with Linux kernel. Add missing reset-gpio property. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18arm: zynq: Update ZYBO config optionsNathan Rossi
Update the ZYBO device tree and enable config options that relate to the added devices in the device tree. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18ARM: zynq: Enable u-boot,dm-pre-reloc for sdhciMichal Simek
Enable u-boot,dm-pre-reloc for sdhci for zc706, zed and zybo. And create aliases for it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-04arm: zynq: dts: Add U-Boot device tree additionsSimon Glass
We need to mark some device tree nodes so that they are available before relocation. This enables driver model to find these automatically. In the case of SPL it ensures that these nodes will be retained in SPL. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-28ARM: zynq: DT: Sync zc702/zc706/zed/zybo DT with kernelMichal Simek
Syncup with the latest DT from the Linux kernel. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-11-11arm: dts: zynq: Add digilent ZYBO board dtsPeter Crosthwaite
It's a Zynq board similar in design to the currently supported ones. 512MB of RAM and UART1 is used. Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
