path: root/arch/arm/dts/zynq-zc770-xm010.dts
2019-02-15xilinx: dts: Remove additional empty linesMichal Simek
Trivial fix. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-15ARM: dts: zynq: correct and improve the model property of dt filesLuis Araneda
Replace the current value of the model property by a more accurate description of each board (which includes the manufacturer), as some of the boards had the same value ("Xilinx Zynq") Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm: zynq: Use fixed partitions for spi flash for zc770 xm010Michal Simek
Sync with mainline. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm: zynq: Fix eeprom dt nodesMichal Simek
- Use eeprom for node name - Use atmel compatible string instead of at. - Add missing labels Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09arm: zynq: Sync up licenses with mainline kernelMichal Simek
Use different location for SPDX line. Also update dates for new mainline DTS files. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Add device-type property for zynq ethernet phy nodesSai Pavan Boddu
Mention device-type = "ethernet-phy", as qemu will need this in absence of compatible. Signed-off-by: Sai Pavan Boddu <saipava@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM: zynq: Remove DTC 1.4.2 warningsMichal Simek
DTC 1.4.2 reports these warnings: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property This patch is fixing them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Align spi and qspi node locationsMichal Simek
Keep nodes alphabelitally sorted. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
2016-04-13ARM: zynq: Fix bootargs in board dtsiMichal Simek
- Sync with Linux kernel - Remove rootfs - Remove earlyprintk Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Fix all remaining zynq platform to use stdout-pathMichal Simek
Fix console setup for all remaining zynq boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04arm: zynq: dts: Add U-Boot device tree additionsSimon Glass
We need to mark some device tree nodes so that they are available before relocation. This enables driver model to find these automatically. In the case of SPL it ensures that these nodes will be retained in SPL. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-25dts: zc770-xm010: Enable zynq qspi controller nodeJagan Teki
Enabled zynq qspi controller node for zc770-xm010 board. => sf probe 0 -- bus1 for selecting qspi controller => sf probe 1 -- bus0 for selecting spi controller Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Simon Glass <sjg@chromium.org> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-08-19ARM: dts: Rename memory@0 to memoryMichal Simek
zynq-7000.dtsi include skeleton.dtsi which contains memory node with base address and size zero. If you add memory@0 node to the platform DTS in final DTB there are two memory nodes and U-Boot works with the first one (with zeros) which end up in failing in dram_init because size is zero. Platform memory node should rewrite default memory node setup from skeleton.dtsi that's why platfroms needs to also use memory as node name instead of memory@0. Reported-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-28ARM: zynq: DT: Update zc770 dtsesMichal Simek
Platform DTSes are missing content needed for platform to be able to use OF binding and DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-01dts: zynq: Enable spi1 for zc770_xm010 boardJagan Teki
This patch enables spi1 for zynq zc770_xm010 board dts Signed-off-by: Jagan Teki <jteki@openedev.com> Tested-by: Jagan Teki <jteki@openedev.com>
2014-05-15zynq: add UART nodes to device tree to initialize UART with OFMasahiro Yamada
Commit c9416b92 added OF UART initialization support but aliases nodes are missing in device tree. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [on ZC706 board] Tested-by: Michal Simek <michal.simek@xilinx.com> [on ZC702 board] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-15zynq: add memory nodes to device tree to initialize DRAM with OFMasahiro Yamada
Commit 9e0e37ac added OF RAM initialization support but memory nodes are missing in device tree. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [on ZC706 board] Tested-by: Michal Simek <michal.simek@xilinx.com> [on ZC702 board] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
