path: root/arch/arm/dts/zynq-zc702.dts
2016-04-13ARM: zynq: Align spi and qspi node locationsMichal Simek
Keep nodes alphabelitally sorted. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
2016-04-13ARM: zynq: zc702: Add adv7511 on i2c busChristian Kohn
Add bindings for adv7511. Signed-off-by: Christian Kohn <christian.kohn@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: DT: Add ethernet phy reset informationPunnaiah Choudary Kalluri
Added phy reset gpio information for gem0. Signed-off-by: Punnaiah Choudary Kalluri <punnaia@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Fix bootargs in board dtsiMichal Simek
- Sync with Linux kernel - Remove rootfs - Remove earlyprintk Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-07zynq: sdhci: Move driver to DMMichal Simek
Move driver to DM Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-04arm: zynq: dts: Add U-Boot device tree additionsSimon Glass
We need to mark some device tree nodes so that they are available before relocation. This enables driver model to find these automatically. In the case of SPL it ensures that these nodes will be retained in SPL. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-25dts: zc702: Enable zynq qspi controller nodeJagan Teki
Enabled zynq qspi controller node for zc702 board. Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Simon Glass <sjg@chromium.org> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-07-28ARM: zynq: DT: Add zc702 pushbuttons to DT as gpio-keysMichal Simek
Adds the two MIO connected pushbuttons on the zc702 board to the devicetree as a single multi-key device for us with the gpio-keys driver. Signed-off-by: Ezra Savard <ezra.savard@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-28ARM: zynq: DT: Sync zc702/zc706/zed/zybo DT with kernelMichal Simek
Syncup with the latest DT from the Linux kernel. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-15zynq: add UART nodes to device tree to initialize UART with OFMasahiro Yamada
Commit c9416b92 added OF UART initialization support but aliases nodes are missing in device tree. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [on ZC706 board] Tested-by: Michal Simek <michal.simek@xilinx.com> [on ZC702 board] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-15zynq: add memory nodes to device tree to initialize DRAM with OFMasahiro Yamada
Commit 9e0e37ac added OF RAM initialization support but memory nodes are missing in device tree. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [on ZC706 board] Tested-by: Michal Simek <michal.simek@xilinx.com> [on ZC702 board] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
