path: root/arch/arm/dts/zynq-topic-miami.dts
2018-01-30arm: zynq: Remove ethernet alias for topic-miamiMichal Simek
Ethernet is not enabled that's why this alias should be completely unused. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-04-27zynq-topic-miami.dts: Add usbotg0 alias to make USB actually workMike Looijmans
Fixes the following problem: zynq-uboot> run dfu_ram Setting bus to 1 g_dnl_register: failed!, error: -19 The cause appears to be that the USB framework is looking for a usbotg aliases, so add the alias to point to our USB device. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM: zynq: Remove DTC 1.4.2 warningsMichal Simek
DTC 1.4.2 reports these warnings: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property This patch is fixing them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM: zynq: Add support for the topic-miami system-on-modules and carrier boardsMike Looijmans
The topic-miami SoMs contain a Zynq xc7z015 or xc7z030 SoC, 1GB DDR3L RAM, 32MB QSPI NOR flash and 256MB NAND flash. The topic-miamiplus SoMs contain a Zynq xc7z035, xc7z045 or xc7z100 SoC, 2x 1GB DDR3L RAM, 64MB dual-parallel QSPI flash, clock sources and a fan controller. The "Florida" carrier boards add SD, USB, ethernet and other interfaces. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
