2022-07-25 | ARM: DTS: bk4r1/pcm052: prepare to synchronise device trees with linux | Marcel Ziswiler | |
As a preparatory step rename the included SoC dtsi from vf.dtsi to vf610.dtsi as this is how it is named in Linux upstream. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2019-04-13 | ARM: DTS: Update pcm052 based dts files (bk4r1/pcm052) | Lukasz Majewski | |
This commit provides update and renames the bk4r1.dts to vf610-bk4r1.dts file with more on SoC HW description. The pcm052.dts has been renamed to vf610-pcm052.dts as well. Moreover, a new vf610-pcm052.drsi file has been introduced to reuse the common code between devices based on Phytec's pcm052 modules. Ported from Linux kernel - v4.20 (tag) Signed-off-by: Lukasz Majewski <lukma@denx.de> |
