path: root/arch/arm/dts/vf610-bk4r1.dts
2019-04-13ARM: DTS: Update pcm052 based dts files (bk4r1/pcm052)Lukasz Majewski
This commit provides update and renames the bk4r1.dts to vf610-bk4r1.dts file with more on SoC HW description. The pcm052.dts has been renamed to vf610-pcm052.dts as well. Moreover, a new vf610-pcm052.drsi file has been introduced to reuse the common code between devices based on Phytec's pcm052 modules. Ported from Linux kernel - v4.20 (tag) Signed-off-by: Lukasz Majewski <lukma@denx.de>
