path: root/arch/arm/dts/vf.dtsi
2019-04-13ARM: DTS: vybrid: Update vf.dtsi file to descibe more vf610 hardwareLukasz Majewski
This patch allows moving vf610 based boards to a device tree and model. Ported from Linux kernel - v4.20 (tag) Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-01ARM: DTS: Add iomux node to vf.dtsi for Vybrid devicesLukasz Majewski
This node is in sync with v4.20-next tree: e4dda4f5a4df "x86/kaslr, ACPI/NUMA: avoid including asm/kaslr.h on arm64" Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-16ARM: dts: vf: Fix warning about missing reg propertyStefan Agner
Add proper reg values for the two AIPS bus nodes. This avoids this two warnings: Node /soc/aips-bus@40000000 has a unit name, but no reg property Node /soc/aips-bus@40080000 has a unit name, but no reg property Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-06pcm052: add new BK4r1 target based on PCM052 SoMAlbert ARIBAUD \(3ADEV\)
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-09-27ARM: dts: vf: Add device tree node for USB on VybridSanchayan Maity
Add device tree node for USB peripheral on Vybrid. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2016-02-02arm: vybrid: Update the license stringBhuvanchandra DV
Since SPDX license is already there, drop the full one. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-02arm: vybrid: Enable lpuart supportBhuvanchandra DV
Add device tree node's for lpuart on Vybrid platform Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-08vf610: dts: Add device tree supportBhuvanchandra DV
Add device tree files for Freescale Vybrid platform and Toradex Colibri VF50, VF61 modules. Device tree files are taken from upstream Kernel. Removed the stuff which are not used/supported yet in U-Boot. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
