path: root/arch/arm/dts/uniphier-ref-daughter.dtsi
2017-06-25ARM: dts: uniphier: sync DT with Linux next-20170622Masahiro Yamada
2017-03-14ARM: dts: uniphier: more re-sync DT with LinuxMasahiro Yamada
For better maintainability. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02ARM: dts: uniphier: sync Device Trees with upstream LinuxMasahiro Yamada
I periodically sync Device Trees for better maintainability. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-07-23ARM: dts: UniPhier: add device-specific compatible string for EEPROMMasahiro Yamada
For the record, describe exactly which device of which vendor is used on this board. I2C EEPROM is bound by the generic compatible string, "i2c-eeprom", so this commit has no impact on the functionality. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-07-02ARM: dts: UniPhier: re-license device tree files under GPLv2+/X11Masahiro Yamada
The current GPL only licensing on the device trees makes it very impractical for other software components licensed under another license. To make it easier to reuse them, the device trees for UniPhier SoCs and boards have already been dual-licensed in Linux. Follow this trend in U-boot too. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-15ARM: UniPhier: adjust device trees for business transferMasahiro Yamada
Panasonic's System LSI products, UniPhier SoC family, have been transferred to Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-07ARM: UniPhier: set I2C offset length of on-board EEPROM in DTSMasahiro Yamada
The EEPROM chips on UniPhier reference daughter boards expect 2-byte offset address. Since 7132b9fd68a1 (dm: i2c: dts: Support an offset-len device tree property), I2C sub-nodes can have "u-boot,i2c-offset-len" property. It is convenient to set the default I2C offset address length in Device Tree, so that we do not have to set it on the command line. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-07ARM: UniPhier: move EEPROM device node into a separate DTSMasahiro Yamada
This EEPROM chip is installed on the expansion board commonly used on UniPhier platform. To avoid duplicated description, move the EEPROM node to a separate file and include it from other device tree sources. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
