path: root/arch/arm/dts/uniphier-pxs3.dtsi
2020-08-18ARM: dts: uniphier: resync DT with Linux 5.9-rc1Masahiro Yamada
2020-07-11ARM: uniphier: sync with Linux 5.8-rc4Masahiro Yamada
2020-02-29ARM: dts: uniphier: add reset-names to NAND controller nodeMasahiro Yamada
Import Linux commits: 37f3e0096f71 ("ARM: dts: uniphier: add reset-names to NAND controller node") e98d5023fe1f ("arm64: dts: uniphier: add reset-names to NAND controller node") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-02-29ARM: dts: uniphier: rename DT nodes to follow json-schemaMasahiro Yamada
Import the nodename changes I made in Linux for avoiding dt-schama warnings. This follows the $nodename patterns in the dt-schema. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10arm64: dts: uniphier: add reserved-memory for secure memoryMasahiro Yamada
[ Linux commit aa38571246c6ac279ebebd141157297bcb959d76 ] The memory regions specified by /memreserve/ are passed to early_init_dt_reserve_memory_arch() with nomap=false, so it is not suitable for reserving memory for Trusted Firmware-A etc. Use the more robust /reserved-memory node with the no-map property to prevent the kernel from mapping it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-04-17ARM: dts: uniphier: sync with Linux 5.1-rc4Masahiro Yamada
2018-12-29ARM: uniphier: dts: sync with Linux 4.20Masahiro Yamada
Currently, the DWC3 USB node is out of sync because the bindings for the UniPhier DWC3 PHY diverged between Linux and U-Boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-11mmc: uniphier-sd: sync with LinuxMasahiro Yamada
Sync with the driver code and the binding recently merged in Linux. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-11ARM: dts: uniphier: sync DT with Linux 4.19-rc1Masahiro Yamada
2018-06-23ARM: dts: uniphier: sync DT with Linux 4.18-rc1Masahiro Yamada
Now that the clock-frequency information has been moved to the driver, more DT sync is possible. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-23ARM: dts: uniphier: sync with Linux 4.17-rc6Masahiro Yamada
2018-05-23ARM: dts: uniphier: add clock-names and reset-names to ethernet nodeKunihiko Hayashi
Add clock-names and reset-names because this node recognizes multiple clocks and resets. ("ether", and so on, for each) Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-23ARM: dts: uniphier: add syscon-phy-mode property to each ethernet nodeKunihiko Hayashi
Add syscon-phy-mode property specifying a phandle of system controller to each ethernet node. Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-18ARM: dts: uniphier: sync DT with Linux 4.17-rc1Masahiro Yamada
2018-03-15ARM: dts: uniphier: sync with Linux 4.16-rc5Masahiro Yamada
2017-11-29ARM: dts: uniphier: Sync with Linux 4.15-rc1Masahiro Yamada
2017-10-15ARM: dts: uniphier: update GPIO nodesMasahiro Yamada
Switch to the single node design. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-30ARM: dts: uniphier: update PXs3 SoC/board DTMasahiro Yamada
Support PXs3 SoC and its reference development board. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-17ARM: dts: uniphier: sync DT with LinuxMasahiro Yamada
Fix the following DTC warnings: Warning (simple_bus_reg): Node /soc/system-bus@58c00000/support_card@1,1f00000/ethernet@00000000 simple-bus unit address format error, expected "0" Warning (simple_bus_reg): Node /soc/system-bus@58c00000/support_card@1,1f00000/uart@000b0000 simple-bus unit address format error, expected "b0000" Warning (simple_bus_reg): Node /soc/smpctrl@59800000 simple-bus unit address format error, expected "59801000" Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-03-14ARM: dts: uniphier: fix no unit name warningsMasahiro Yamada
Fix warnings reported when built with W=1, by DTC 1.4.2 or later: Node /memory has a reg or ranges property, but no unit name Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-22ARM: dts: uniphier: add PXs3 SoC/board supportMasahiro Yamada
Initial commit for the PXs3 SoC DT. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
