On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
Add the device tree node for the PCIe controller found on Tegra30 SoCs.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add a device tree node for the GIC found on Tegra30. U-Boot doesn't use
it directly but subsequent patches will add device tree nodes that
reference it by phandle.
Some Tegra device tree files do not include information about the serial
ports. Add this and also add information about the input clock speed.
The console alias needs to be set up to indicate which port is used for
the console.
Also add a binding file since this is missing.
Series-changes; 5
- Add full serial port nodes from Linux tree (commit fc9d4dbe)
- Use /chosen/stdout-path instead of /aliases/console to specify the console
These files are taken from Linux 3.14.
Add DT node for USB EHCI function.
Add support for T30-Cardhu, T30-Beaver, T114-Dalmore boards.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Took these values directly from the kernel dts files.
Minor edits to clock, apbdma and SPI, make I2C match kernel DT, and add gpio
dts Makefile has the arch & board include paths added to DTS_CPPFLAGS.
This allows the use of '#include "xyz"' in the dts/dtsi file which
helps the C preprocessor find common dtsi include files.
Add tegra30 SPI SLINK nodes to fdt.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Add apbdma node for tegra20 and tegra30, copied directly from tegra
Linux dtsi files.
These nodes are unused.
Note that T30 does not have a separate/different DVC (power I2C)
controller like T20 - all 5 I2C controllers are identical, but
DVC_I2C is still used to designate the controller intended for
power control (PWR_I2C in the schematics). On Cardhu, it's used
to access the PMU and EEPROM, as well as the audio codec, temp
sensor, and fuel gauge devices from the OS.
These are stripped down for bringup, They'll be filled out later
to match-up with the kernel DT contents, and/or as devices are
brought up (mmc, usb, spi, etc.).
