path: root/arch/arm/dts/tegra30-cardhu.dts
2015-01-29dm: tegra: dts: Use TEGRA_GPIO() macro for all GPIOsSimon Glass
This new method is much easier and matches the kernel. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-18ARM: tegra: Enable PCIe on CardhuThierry Reding
The PCIe bus on Cardhu is routed to the dock connector. An ethernet NIC is available on the dock over the PCIe bus. Enable the PCIe controller and the network device driver so that the device can boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-10-22dm: tegra: dts: Add aliases for spi on tegra30 boardsSimon Glass
All boards with a SPI interface have a suitable spi alias except the tegra30 boards. Add these missing aliases. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-09-10tegra: dts: Add serial port detailsSimon Glass
Some Tegra device tree files do not include information about the serial ports. Add this and also add information about the input clock speed. The console alias needs to be set up to indicate which port is used for the console. Also add a binding file since this is missing. Series-changes; 5 - Add full serial port nodes from Linux tree (commit fc9d4dbe) - Use /chosen/stdout-path instead of /aliases/console to specify the console Signed-off-by: Simon Glass <sjg@chromium.org>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
