path: root/arch/arm/dts/tegra210-p2371-0000.dts
2017-07-11tegra: fdt: Ensure that the console UART is enabledSimon Glass
Many tegra boards have the console UART node disabled. With livetree this prevents serial from working since it does not 'force' the console to be bound. Updates the affected boards to fix this error. The boards were checked with: for b in $(grep tegra boards.cfg |grep -v integrator | \ awk '{print $7}' | sort); do echo $b; fdtgrep -c nvidia,tegra20-uart b/$b/u-boot.dtb |grep okay; done Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1
2016-09-27ARM: tegra: remove "0, " from DT unit addressesStephen Warren
Apparently the unit address in a DT node name is now supposed to be a single integer value, rather than a comma-separated list of individual cell values. Fix the U-Boot DTs to comply with this naming convention. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27mmc: tegra: use correct alias for SDHCI/MMC nodesStephen Warren
The Tegra MMC driver currently honors "sdhci" entries in /aliases. The MMC core however uses "mmc" entries in /aliases. This difference will be relevant once the Tegra MMC driver is converted to DM, and the MMC core handles alias lookups. To avoid issues during that conversion, fix the Tegra MMC driver and all Tegra DTs to use the same alias name as the MMC core does. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: fdt: Add 'non-removable' property to all eMMC nodesTom Warren
During debug of the DM_MMC changes to the Tegra MMC driver, I noticed that the 'removable' property wasn't being set correctly for the eMMC parts on most Tegra boards. Since the kernel DTS has this property set correctly, it should be in U-Boot's Tegra DT too. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-06ARM: tegra: Add p2371-0000 boardStephen Warren
P2371-0000 is a P2581 or P2530 CPU board married to a P2595 I/O board. The combination contains SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, Ethernet via USB3, USB3 host port, SATA, a GPIO expansion header, and an analog audio jack. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
