path: root/arch/arm/dts/tegra124-u-boot.dtsi
2017-12-12binman: tegra: Convert to use binmanSimon Glass
Update tegra to use binman for image creation. This still includes the current Makefile logic, but a later patch will remove this. Three output files are created, all of which combine SPL and U-Boot: u-boot-tegra.bin - standard image u-boot-dtb-tegra.bin - same as u-boot-tegra.bin u-boot-nodtb-target.bin - includes U-Boot without the appended device tree The latter is useful for build systems where the device is appended later, perhaps after being modified. Signed-off-by: Simon Glass <sjg@chromium.org>
