path: root/arch/arm/dts/tegra124-jetson-tk1.dts
2019-06-05ARM: tegra: Rename pcie-controller to pcieThierry Reding
Recent versions of DTC have checks for PCI host bridge device tree nodes that are named something other than "pci" or "pcie". Fix all occurrences of such nodes for Tegra boards to avoid potential warnings from DTC. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-07-11tegra: fdt: Ensure that the console UART is enabledSimon Glass
Many tegra boards have the console UART node disabled. With livetree this prevents serial from working since it does not 'force' the console to be bound. Updates the affected boards to fix this error. The boards were checked with: for b in $(grep tegra boards.cfg |grep -v integrator | \ awk '{print $7}' | sort); do echo $b; fdtgrep -c nvidia,tegra20-uart b/$b/u-boot.dtb |grep okay; done Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1
2016-09-27mmc: tegra: use correct alias for SDHCI/MMC nodesStephen Warren
The Tegra MMC driver currently honors "sdhci" entries in /aliases. The MMC core however uses "mmc" entries in /aliases. This difference will be relevant once the Tegra MMC driver is converted to DM, and the MMC core handles alias lookups. To avoid issues during that conversion, fix the Tegra MMC driver and all Tegra DTs to use the same alias name as the MMC core does. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27ARM: tegra: fdt: Add 'non-removable' property to all eMMC nodesTom Warren
During debug of the DM_MMC changes to the Tegra MMC driver, I noticed that the 'removable' property wasn't being set correctly for the eMMC parts on most Tegra boards. Since the kernel DTS has this property set correctly, it should be in U-Boot's Tegra DT too. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-16tegra: dts: Sync up the tegra124 device tree files with LinuxSimon Glass
Sync up these files with Linux v4.4. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-01-29dm: tegra: dts: Use TEGRA_GPIO() macro for all GPIOsSimon Glass
This new method is much easier and matches the kernel. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-18ARM: tegra: Enable PCIe on Jetson TK1Thierry Reding
The Jetson TK1 has an ethernet NIC connected to the PCIe bus and routes the second root port to a miniPCIe slot. Enable the PCIe controller and the network driver to allow the device to boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Enable XUSB pad controller on Jetson TK1Thierry Reding
Add the PCIe and SATA lane configuration to the Jetson TK1 device tree, so that the XUSB pad controller can be appropriately configured. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-10tegra: dts: Add serial port detailsSimon Glass
Some Tegra device tree files do not include information about the serial ports. Add this and also add information about the input clock speed. The console alias needs to be set up to indicate which port is used for the console. Also add a binding file since this is missing. Series-changes; 5 - Add full serial port nodes from Linux tree (commit fc9d4dbe) - Use /chosen/stdout-path instead of /aliases/console to specify the console Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-05ARM: tegra: enable USB device mode and UMS on some boardsStephen Warren
For each of Jetson TK1, Venice2, and Beaver: - Enable the first USB controller in DT, and describe its configuration. - Enable USB device/gadget support. This allows the user to type e.g. "ums 0 mmc 0" at the command-line to cause U-Boot to act a USB device implementing the USB Mass Storage protocol, and expose MMC device 0 that way. This allows a host PC to mount the Tegra device's MMC, partition it, and install a filesystem on it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: add Jetson TK1 boardStephen Warren
Jetson TK1 is an NVIDIA Tegra124 reference board, which shares much of its design with Venice2. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
