path: root/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts
2018-07-16sunxi: DT: H3: update board .dts files from LinuxAndre Przywara
Update the .dts file for the various boards with an Allwinner H3 SoC. This is as of v4.18-rc3, exactly Linux commit: commit 721afaa2aeb860067decdddadc84ed16f42f2048 (HEAD) Merge: 7c00e8ae041b 87815dda5593 Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Mon Jun 11 17:57:38 2018 -0700 Merge tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc This also includes the OrangePi Zero .dts, which technically has an Allwinner H2+ SoC. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2018-04-04arm: dts: sunxi: update H3 to new EMAC bindingAndre Przywara
The U-Boot driver for the sun8i-emac was using some preliminary DT binding. Now since Linux got its own driver in v4.15 and our driver can now cope with both bindings, let's convert the DT nodes used by the various H3 boards over to the new bindings used by the kernel. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-09-03sunxi: Add defconfig and dts file for the Orange Pi Plus2E SBCHans de Goede
The Orange Pi Plus2E is an extended version of the Orange Pi Pc Plus, with 2G RAM and an external gbit ethernet phy. The dts file is identical to the one submitted to the upstream kernel, except that it has the pending patch to enable the ethernet controller squashed in, as u-boot already has sun8i-emac support. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
