path: root/arch/arm/dts/sun8i-h3-orangepi-lite.dts
2020-01-24sunxi: H3/H5 Sync DT files from upstream Linux kernel as of next-20200108Chen-Yu Tsai
Sync the device tree files and device tree header files from upstream Linux kernel, as of 2020-01-08. The commit synced to in the sunxi repo 98d25b0b266d Merge branch 'sunxi/dt-for-5.6' into sunxi/for-next which is also part of next-20200108. Changes brought in include: - cleanup of pinmux node names - addition of Security ID, MBUS, CSI, crypto engine, video codec, pmu, and thermal sensor device nodes for both SoCs - addition of deinterlacing engine device node on H3 - cleanup of RTC device node and addition of its clocks - various board cleanups and improvements - removal of pinmux node for GPIO lines - cpufreq / DVFS - HDMI output - UART-based Bluetooth - audio codec - USB ports - new boards Most of the changes don't concern U-boot. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-16sunxi: DT: H3: update board .dts files from LinuxAndre Przywara
Update the .dts file for the various boards with an Allwinner H3 SoC. This is as of v4.18-rc3, exactly Linux commit: commit 721afaa2aeb860067decdddadc84ed16f42f2048 (HEAD) Merge: 7c00e8ae041b 87815dda5593 Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Mon Jun 11 17:57:38 2018 -0700 Merge tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc This also includes the OrangePi Zero .dts, which technically has an Allwinner H2+ SoC. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-16sunxi: DT: update device tree files for Allwinner H3 and H5 SoCsAndre Przywara
Update the device tree files from the Linux tree as of v4.18-rc3, exactly Linux commit: commit 55c5ba5e49a0a124ed416880e8227b493474495e Author: Chen-Yu Tsai <wens@csie.org> Date: Tue Apr 24 19:34:22 2018 +0800 arm64: dts: allwinner: h5: Add cpu0 label for first cpu Since the H3 and H5 are very similar (aside from the actual ARM cores), they share most the SoC .dtsi and thus have to be updated together. One tiny change is the removal of the "arm/" prefix from the include path in the sun50i-h5.dtsi, which is needed because we don't share the same sophisticated DT directory layout of Linux. Also we need to fix up the board .dts files already, since the .dtsi removes some pins, so the .dts can't reference them anymore. This is to maintain bisectability. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-07-15sunxi: Add defconfig and dts file for the Orange Pi Lite SBCHans de Goede
The Orange Pi Lite SBC is a small H3 based SBC, with 512MB RAM, micro-sd slot, HDMI out, 2 USB-A connectors, 1 micro-USB connector, sdio attached rtl8189ftv wifi and an ir receiver. The dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
