path: root/arch/arm/dts/sun8i-a83t-sinovoip-bpi-m3.dts
2016-04-12sunxi: Enable usb ports on the Sinovoip BPI M3Hans de Goede
DLDO3 is used to provide Port-D power and PD is used for the usb-hub / sata-5v enable pins. The 2.5V comes from the schematic and matches the factory image fex file. The dts changes are the minimal changes needed for u-boot to pick-up the usb host controllers. The upstream kernel does not (yet) have usb host support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-01-26sunxi: Add suport for A83T based Banana-pi M3 BoardVishnu Patekar
Add dts and defconfig for Banana-pi M3 board. It has 2G LPDDR3, UART, ethernet, USB, HDMI, USB Sata, MIPI DSI, mic, AP6212 Wifi, etc on it. It is paired with AXP813 PMIC which is almost same as AXP818. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> [hdegoede@redhat.com: rename to Sinovoip_BPI_M3_defconfig/sun8i-a83t-sinovoip-bpi-m3.dts] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
