path: root/arch/arm/dts/sun7i-a20-olimex-som204-evb.dts
2019-04-17arm: allwinner: dts: a20: Sync A20 dts(i) files from Linux 5.1-rc2Jagan Teki
Sync sun7i-a20 dts(i) files from Linux 5.1-rc2 Linux commit details about the sun7i-a20* sync: "ARM: dts: sun7i: bananapi: Add GPIO banks regulators" (sha1: 09c6572290f018d73ec2e812e28bada34d41815f) Here are U-Boot specific dts changes. - s/uart0_pins_a/uart0_pb_pins for sun7i-a20-ainol-aw1.dts sun7i-a20-m5.dts sun7i-a20-primo73.dts sun7i-a20-yones-toptech-bd1078.dts sunxi-itead-core-common.dtsi - s/gmac_pins_mii_a/gmac_rgmii_pins for sun7i-a20-m5.dts - drop i2c0, i2c1 pins from sunxi-itead-core-common.dtsi - drop mmc0 pins from sun7i-a20-primo73.dts Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-09-28ARM: dts: sun7i: Update A20 dts(i) files from Linux-v4.18-rc3Jagan Teki
Update all A10 devicetree dtsi and dtsi files from Linux-v4.18-rc3 with below commit: commit 5d9ef839f874f4e3923c8a9ae7b136c6c3912cd5 Author: Stefan Mavrodiev <stefan@olimex.com> Date: Wed May 16 14:38:08 2018 +0300 ARM: dts: sun7i: Add Olimex A20-SOM-EVB-eMMC board Note: - Update sun7i-a20-primo73.dts as per Linux, since this dts is U-Boot specific. - Drop sun7i-a20-olimex-som-evb-emmc.dts since no board added for this. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-03-13sunxi: Add A20-SOM204-EVB boardStefan Mavrodiev
This is new System-On-Module platform with universal dimm socket for easy insertation. The EVB board is designed to be universal with future modules. Base features of A20-SOM204 board includes: * 1GB DDR3 RAM * AXP209 PMU * KSZ9031 Gigabit PHY * AT24C16 EEPROM * Status LED * LCD connector * GPIO connector There will be variants with the following options: * Second LAN8710A Megabit PHY * 16MB SPI Flash memory * eMMC card * ATECC508 crypto device The EVB board has: * Debug UART * MicroSD card connector * USB-OTG connector * Two USB host * RTL8723BS WiFi/BT combo * IrDA transceiver/receiver * HDMI connector * VGA connector * Megabit ethernet transceiver * Gigabit ethernet transceiver * SATA connector * CAN driver * CSI camera * MIC and HP connectors * PCIe x4 connector * USB3 connector * Two UEXT connectors * Two user LEDs Some of the features are multiplexed and cannot be used the same time: CAN and Megabit PHY. Others are not usable with A20 SoC: PCIe and USB3. This patch adds defconfig and dts files for this board. The dts is same with mainline kernel, except some nodes are removed to make file compatible with existing dtsi file. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
