Copy the devicetree source for the A20 SoC and all existing boards
verbatim from the Linux v5.18-rc1 tag.
This commit also adds the following new board devicetrees:
- sun7i-a20-haoyu-marsboard.dts
- sun7i-a20-linutronix-testbox-v2.dts
- sun7i-a20-olinuxino-lime-emmc.dts
This update includes changes to the USB PHY detection GPIO properties
which are needed to convert that driver to use the DM GPIO framework.
Signed-off-by: Samuel Holland <samuel@sholland.org>
[Andre: fix Mele M5 U-Boot only DT]
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Enable ahci node for sun7i-a20-m5.dts, this would require since
we have DM_SCSI enabled on the respective SoC.
No need to send patch to Linux for this change, since this
dts is U-Boot specific.
Cc: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Sync sun7i-a20 dts(i) files from Linux 5.1-rc2
Linux commit details about the sun7i-a20* sync:
"ARM: dts: sun7i: bananapi: Add GPIO banks regulators"
(sha1: 09c6572290f018d73ec2e812e28bada34d41815f)
Here are U-Boot specific dts changes.
- s/uart0_pins_a/uart0_pb_pins for
sun7i-a20-ainol-aw1.dts
sun7i-a20-m5.dts
sun7i-a20-primo73.dts
sun7i-a20-yones-toptech-bd1078.dts
sunxi-itead-core-common.dtsi
- s/gmac_pins_mii_a/gmac_rgmii_pins for
sun7i-a20-m5.dts
- drop i2c0, i2c1 pins from
- drop mmc0 pins from
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have multiple licenses (in
these cases, dual license) declared in the SPDX-License-Identifier tag.
In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A
or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B"
as per the Linux Kernel style document. Note that parenthesis are
allowed so when they were used before we continue to use them.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
u-boot has support for a number of boards for which a dts file still needs
to be written, add minimal dts files for these boards so that we can switch
them over to driver-model / fdt.
