path: root/arch/arm/dts/sun7i-a20-m3.dts
2019-04-17arm: allwinner: dts: a20: Sync A20 dts(i) files from Linux 5.1-rc2Jagan Teki
Sync sun7i-a20 dts(i) files from Linux 5.1-rc2 Linux commit details about the sun7i-a20* sync: "ARM: dts: sun7i: bananapi: Add GPIO banks regulators" (sha1: 09c6572290f018d73ec2e812e28bada34d41815f) Here are U-Boot specific dts changes. - s/uart0_pins_a/uart0_pb_pins for sun7i-a20-ainol-aw1.dts sun7i-a20-m5.dts sun7i-a20-primo73.dts sun7i-a20-yones-toptech-bd1078.dts sunxi-itead-core-common.dtsi - s/gmac_pins_mii_a/gmac_rgmii_pins for sun7i-a20-m5.dts - drop i2c0, i2c1 pins from sunxi-itead-core-common.dtsi - drop mmc0 pins from sun7i-a20-primo73.dts Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-09-28ARM: dts: sun7i: Update A20 dts(i) files from Linux-v4.18-rc3Jagan Teki
Update all A10 devicetree dtsi and dtsi files from Linux-v4.18-rc3 with below commit: commit 5d9ef839f874f4e3923c8a9ae7b136c6c3912cd5 Author: Stefan Mavrodiev <stefan@olimex.com> Date: Wed May 16 14:38:08 2018 +0300 ARM: dts: sun7i: Add Olimex A20-SOM-EVB-eMMC board Note: - Update sun7i-a20-primo73.dts as per Linux, since this dts is U-Boot specific. - Drop sun7i-a20-olimex-som-evb-emmc.dts since no board added for this. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2015-06-04sunxi: Sync dts files with the linux kernelHans de Goede
Copy over all the latest dts changes from mripard/sunxi/dt-for-4.2 , this gives us a proper dtsi file for the A33 rather then abusing sun8i-a23.dtsi for this. And this replaces our minimal (dummy) sun7i-a20-mk808c and sun8i-a33-astar-mid756 dts files with proper ones. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: dts: Sync all dts files with upstream kernelHans de Goede
Bring all the sunxi dts files (and update existing ones) from mripard/sunxi/dt-for-4.1 (which will be merged into upstream master any day now). This is necessary so that we can move all sunxi boards over to the driver model. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
