path: root/arch/arm/dts/sun6i-a31s-yones-toptech-bs1078-v2.dts
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Sync dts files with the upstream kernelHans de Goede
Sync dts files with the upstream kernel including changes queued for 4.6: https://git.kernel.org/cgit/linux/kernel/git/mripard/linux.git/commit/?h=sunxi/dt-for-4.6 Note this adds a number of new unused board dts files. I've asked the authors of the kernel commits adding these to submit a matching defconfig to u-boot. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
