path: root/arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dts
2018-09-28ARM: dts: sun6i: Update A31/A31s dts(i) files from Linux-v4.18-rc3Jagan Teki
Update all A31/A31s devicetree dtsi and dtsi files from Linux-v4.18-rc3 with below commit: commit b240b419db5d624ce7a5a397d6f62a1a686009ec Merge: 9c2dd8405c0c 518d2f43c358 Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Thu Apr 5 21:18:09 2018 -0700 Merge tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2015-10-20sunxi: Add defconfig for the Sinovoip BPI-M2 boardHans de Goede
The Sinovoip BPI-M2 is a SBC board based on the A31s SoC it features 1G RAM, a microsd slot, Gbit ethernet, 4 usb-a USB-2 ports, ir receiver, stereo headphone jack and hdmi video output. The dts changes are identical to the dts files submitted upstream. A few notes on the use if dldo and aldo regulators. DLDO1 is used for Vdd for the ethernet phy, ALDO2 is used for AVdd for the ethernet phy. ALDO1 is used to power the sdio wifi module. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
